How many gallons per hour do you use? - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 23 Old 04-08-2011, 10:12 PM Thread Starter
mbrun's Avatar
Anybody out there keep track of how many hours of runtime per gallon of gas you get when using your lawn or garden tractor?
My previous tractor did not have an hour meter so I never really knew how much run time per gallon I was gettting. Now I have an hour meter I am going to keep track for a while.
Will be interesting to see if different tasks have noticably different results.
~~~~~~~ 2010 JD x500 ~~~~~~~~
..Brush Guard, 48" Snow Blade, Electric Blade Lift
..Custom Blade Squeegee & Dollie
..P796 Halogens
..JP Electric Sleeve Hitch
..RimGuard Loaded Tires (+92lbs extra, each)
..DR Power Grader
..Dual 50lb Wheel Weights, Chains
..PrecisionFit/Agri-Fab 45-0299 48" Core Aerator
..Brinly Aerator/Seeder, Moldboard Plow,
..Box Scraper, Dethatcher (On Loan)
..Craftsman 48" x 18" Roller
..Brinly 25-Gallon Tank Sprayer
mbrun is offline
post #2 of 23 Old 04-08-2011, 10:22 PM
Jon318's Avatar
Re: How many gallons per hour do you use?
Well, using a single cylinder 14 hp kohler, I used just under a gallon mowing at full throttle for just over an hour. Now that Ive throttled back to half throttle, it takes me about an hour and a half, but now Im only using half a gallon.
Jon318 is offline
post #3 of 23 Old 04-09-2011, 01:49 AM
Boyd's Avatar
Images: 10
Many riders will use just over 1 gallon per hour up to 1.50. Some diesel mowers will be as low as .90 gallons per hour.
Toro 5xi and NH GT18/20/22 owners can join my new Toro 5xi page on Facebook. My Horses: Toro 520xi & 522xi. Toro 5xi prototype hood. WTB: for Toro Xi series 52" deck 78370/78375 and a mule drive for a 79365 single stage snowblower. For sale: Toro 5xi Belly Blade & Toro 60" deck from a 724z.
Boyd is offline
post #4 of 23 Old 04-09-2011, 04:36 AM
15,000+ Posts & Climbing
Full throttle snowblowing with my 16 hp Onan twin cost me 1.25 gal/hr. Half to 2/3 throttle with the loader, that same engine used 3/4 gal./hr. It takes horsepower to run a snowblower, even just blowing air.
Rough fuel consumption for small engines is 0.4 - 0.6 lb/hr/hp, and I use 0.5 as a general calculator. Thats the brake specific fuel consumption (BSFC)and is dependent on the actual power generated by the engine. Backing up between passes while snow blowing doesn't require the engine to make max hp at full throttle. Gasoline weighs 6.0 lb/ gal.
A specific job will use a specific amount of fuel. Throttle position is not all that relevent except for how fast you want to do the job and if the engine can actually do the job at lower rpm and therefore lower horsepower.
My diesel does a little better. Half throttle loader work costs a little over a half gallon per hour. BSFC is around 0.35 - 0.45.
TUDOR is offline
post #5 of 23 Old 04-09-2011, 11:07 AM
The Travelin' Mod
davidg's Avatar
about 1 per hour on my X500 and my L130. my craftsman GT i never fill the tank all the way and i usually only run it about 1/3 throttle since it is just pulling a self powered tiller.
Check out our new HOMEPAGE
davidg is offline
post #6 of 23 Old 04-09-2011, 11:45 AM
My GX335, 20hp Kawa. mowing or blowing uses 1 gal. per hour.
2004 GX335, 48C mower, powerflow 7 bu. bagger, 42 snowthrower, 30 mech. tiller, 48 blade, 80 dump cart.
jim335 is offline
post #7 of 23 Old 04-09-2011, 04:20 PM
I'm amazed at how much gas some of the twin cylinders gassers can use over a gal/hr while some of my small diesel tractors burn very little.16HP Yanmar 1300d can't use much over a pint/hr. 31HP Yanmar 330 uses about 1/2 gal/hr.Even my 70HP Cockshutt/Oliver 1650D
only uses about 1 1/2 gal/hr while pulling a large round baler.
gburnett is offline
post #8 of 23 Old 04-09-2011, 04:33 PM
Kingwood990's Avatar
The John Deere X520 26hp Kawasaki V-twin uses about a gallon and a half per hour at full throttle. The MTD 990 16hp Brigg and Stratton single cylinder uses about two gallons per hour. Does not matter the throttle setting. Its a thirsty machine.
1977 MTD 990 with 3pt hitch
1974 MTD 990 with 3pt hitch, 42'' mower, 10'' sleeve hitch bottom plow (Sears/Brinly)
1991 Toro Wheel Horse 244-H with 38'' mower and mulch kit (grampa's tractor)
2006 John Deere X520 with 54'' mower, HDAP's front and rear, 10'' sleeve hitch bottom plow (Sears/Brinly)
19?? John Deere 214 with 46'' mower, 43'' blade, Dads project/money pit
year unknown IH Cub Cadet 100 thanks Jon318
1973 Homelite RM-7E 30'' mower
198? Yamaha XS1100
Stihl FS55R
Stihl FS55RC
Kingwood990 is offline
post #9 of 23 Old 04-09-2011, 05:05 PM
MTF Tractor Nut
wizzo's Avatar
Haven't tried to calculate it, but some tasks just take more fuel. If I had a bigger place, I'd surely go with a diesel X748...
How old is your X500? I've heard rumors on the Deere forum that after about 50-60 hrs the fuel consumption of the Kawa's drops off a bit. I guess we'll see...
2010 John Deere X500
  • 48X w/ Mulch Kit, Gators & HDAPs
  • Brinly Plug Aerator, JD Spreader & 10p Cart
  • 48" Front Blade, Wheel Weights & Suitcase Weights
  • 30" Mechanical Tiller
1994 John Deere 14SB
2000 John Deere JX75
Stihl KM 90R Kombi System
2005 Lawn Boy 10684 Insight Mower
wizzo is offline
post #10 of 23 Old 04-09-2011, 05:12 PM
PurplDodge's Avatar
I burn 5 gallons of gas in 12 hours while mowing in my Cub Cadet.
1986 John Deere 316 P218 18 hp Onan 50'' deck looking for 54 blade
1992 Cub Cadet 1440 44" deck, 2,300 hours, B&S Vanguard, Gator Blades, 42'' IH Dozer Blade, Custom Light Bar, Custom hole in side of engine
2001 Chevrolet S-10 4.3 V6 5-Speed ZQ8
PurplDodge is offline
post #11 of 23 Old 04-09-2011, 05:52 PM
evo803's Avatar
OP did not state a specific vehicle so
At wide open throttle ( 75 mph ) 60 gallons an hour , at a cruise(45mph) about 30 gallons per hour. Unfortunately I had to sell it because of my accident that disabled me.
Chris
" Friends don't let friends drive stock ! "
evo803 is offline
post #12 of 23 Old 04-09-2011, 06:02 PM
PurplDodge's Avatar
In that case...10 gallons per minute:
post #13 of 23 Old 04-09-2011, 09:51 PM
The Travelin' Mod
davidg's Avatar
mine's an '08 and has about 130 hours on it now. it did burn a little more initially, then after the first oil change it seemed to level on out.
davidg is offline
post #14 of 23 Old 04-09-2011, 10:03 PM
Still lovin' the 322!
PA318Guy's Avatar
I would guess the 318 at WOT was using about 1.5 gallons. I was able to snowblow about three times per tank and was out 45 - 60 minutes per event.
Current Machine JD 322
PA318Guy is offline
post #15 of 23 Old 04-09-2011, 10:19 PM
Carl's Avatar
Images: 3
My MTD 990 with 16 HP Briggs uses about 1 gallon per hour with disking and leveling ground.
My new Powerking with K361 uses a little more but haven't worked it enough to really tell.
My New Holland TC 24 DA uses about 1 gallon per hour working with the FEL. Next time am subsoiling will check cause that works it to the limit.
Believe
Carl is offline
