Cub Cadet Kohler vs, Kawasaki - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 14 Old 04-03-2011, 06:58 PM Thread Starter
I have between to an acre to mow, slightly hilly. I might want to get a snow blower eventualy. I am loooking for a quick comfortable ride low maintenance, and durability. I will not spend more than $2,000.00. I am leaning toward Cub Cadet. These two are my favorite. Which engin will last longer and have the power to throw snow? John Deer fans feel free to add your 2 cents.
LTX 1046 M 46" Cutting Deck 22 HP Kohler Courage V-Twin Engine
Sale Price $1,799.00
LTX 1046 KW 46" Cutting Deck 20 HP Kawasaki V-Twin Engine
Sale Price $1,899.00
tysdad14065 is offline
post #2 of 14 Old 04-03-2011, 08:12 PM
Re: Cub Cadet Kohler vs, Kawasaki
Kawasaki is a better engine. If you don't do maintenance neither will last very long. Roger
rhenning is offline
post #3 of 14 Old 04-03-2011, 08:16 PM
I agree. Kohler used to be the best, but not now. Kawasaki makes a great engine.
Romans 1:16 "For I am not ashamed of the Gospel of Christ..."
hodge is offline
post #4 of 14 Old 04-03-2011, 08:23 PM
scm
I have to agree also. You can't beat the Kawasaki engines. Both my mowers have them.
2007 John Deere 5203 2009 John Deere X500 48'' deck 2010 John Deere X300 42'' deck And too many attachments to list
scm is offline
post #5 of 14 Old 04-03-2011, 08:50 PM Thread Starter
Thanks to all.
post #6 of 14 Old 04-03-2011, 09:05 PM
I prefer kohler-old cast iron ones! new? I would not want either kohler or Kawi.
Don B. is offline
post #7 of 14 Old 04-04-2011, 06:26 PM
Onan18's Avatar
Kawasaki's are a good engine, the internal fit and finish is a little better, and if taken care of will last a LONG time. However, they are EXTREMELY sensitive to being kept clean. If you let it get dirty, even for a little while, it will burn up the top crank seal like that and blow oil everywhere. Also, Kawasaki's are not re-buildable; when they go, thats it, new engine. Reason being there are no replaceable bearings for the crank mains, they are made into the block. When they go, thats it. Kohlers are still a well made engine, they are more complicated than a Kawasaki, true. BUT, they are not as sensitive to being kept clean and are completely re-buildable. For my money, I would go with a Kohler.
Joe
Onan18 is offline
post #8 of 14 Old 04-04-2011, 06:38 PM
deeretek's Avatar
Go with the Kawasaki.The LTX 1046 has a 20 hp and the LTX1050 has a 22.
"If at first you dont succeed,Hire a friend to torch it.
deeretek is offline
post #9 of 14 Old 04-04-2011, 09:23 PM
OK, since you said you'd entertain JD I'll vote John Deere D130 (42" deck) or D140 (48" deck). $1,899/$1,999 respectively. Both 22hp, big tires, big seats.
I've been inside all three of these engines, and have no doubt that the custom-spec B&S in the D's is as good or better than either the Kawasaki or Kohler Courage. Kawaski's are great, but not very forgiving of debris or dirty oil (as has been said). The Courage's are cost-reduced Commands, and all the cool features they had (like hydraulic lifters) aren't there. The hardened/polished cranks in the Briggs seem to make them quite tough.
Just like today's Briggs isn't like your granddad's (much better)....neither are the new Kawasaki's or Kohler's (not quite as good).
I know a lot of Lowe's and Home Depots are having ride and drive events on Saturdays now, so go try them all out and see what you like.
Engine_Tech is offline
post #10 of 14 Old 04-05-2011, 06:09 AM Thread Starter
Thank you. This is the best place I have been to for honest information. You guys rock !
post #11 of 14 Old 04-09-2012, 12:53 PM
I just picked up the LTX1050KW for $1,899 from my local dealer. I also do about 1/2 to 3/4 of an acre that has a few hills. I did months of research to decide myself. I test drove Deere, Husqvarna, Craftsman, and Cub Cadet to start. I looked at the weight, wheels, frame, engine, deck, etc. and everything lead me right to the CC LTX1050KW. I'd have went with a 42" or 46" deck but hard to pass up the 50" given the small price difference for all the extra stuff. The 2012's have a few more HP this year and they jacked the cost up on them because of that. Your best bet is to find a new 2011 at a dealer like I did. Everything is the same except the engine and price. In the LTX1050KW's case the 2011 was 22HP and the 2012 is 23 HP. The price was $1,999 on the 2011 and $2,199 on the 2012. The dealer offered me a $100 off since it's last years model hence $1,899. Everything else is identical.
2011 Cub Cadet CC760 (Bought new in 2012)
2010 Troy-Bilt 175cc 21" rear wheel drive walk-behind
xcal78 is offline
post #12 of 14 Old 04-09-2012, 09:35 PM
JDTechn's Avatar
What motor is forgiving of dirt and debris inside the engine? There is a reason the cheaper mowers have briggs and the higher end have a kawasaki.
the D100 has a briggs for like 1700 bucks, while the x720 has a Liquid cooled kawasaki for about 10,000 bucks.
So i dont see where you find that the Briggs is as good or better than a kawasaki.
JD X320
JD LT190
JD L120
JDTechn is offline
post #13 of 14 Old 04-10-2012, 12:24 AM
Slowly turning green...
lobsterbox's Avatar
Images: 3
I will always be a Kawasaki fan, modern day japanese engineering is truly superb! IMO, Cub Cadet and Kawasaki are a perfect match.
My Youtube Channel: lobsterbox20
2000 John Deere 425 w/ 54" Deck, 54" Blade, 50" Tiller, 47" & 46" Snowblowers, Cosy Cab ~400hrs
1992 John Deere 322 w/ 50" & 48" Deck, 46" Snowblower, 42" Tiller, ~1300hrs
1981 Case 646 Loader w/ 44" Deck, 42" Tiller, 3 Point Hitch
1978 Sears SS/19.9 Twin w/ 42" Deck ~350hrs (trailer queen).
1975 Roper RT/16 w/ Tote Box, Sickle Mower & 3PH.
lobsterbox is offline
post #14 of 14 Old 04-10-2012, 06:46 AM
Ferg
fergus's Avatar
Yes kawasakki make great engines, I have had a boat engine from them and an engine on a small aircraft!
But lets be honest do briggs and stratton engines last for so long if you look after them, but I am not to sure about the newer ones.
Is there a diesel option??
fergus is offline
