Rustoleum truck bed lining on a mower deck - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 23 Old 03-30-2011, 12:36 PM Thread Starter
Through a search I came across a few threads where members have used truck bed liner to protect mower decks from chipping and rusting, with varying results. Has anybody tried the rustoleum brand rattle can liner, and if so how has it worked out? A quick Google search showed that the off-roader guys say it sticks better than the other off the shelf type bed liners. It also seems to have a finer texture than other bed liners I have seen which will hopefully help grass not stick like crazy to it. I'm thinking about using it top and bottom on my MTDs deck that I am rebuilding, what do you guys think?
bgkast is offline
post #2 of 23 Old 03-30-2011, 01:12 PM
Re: Rustoleum truck bed lining on a mower deck
I'd think the fact that it has texture at all would be a problem. On a mower deck you'd want as smooth and slippery a surface as possible. I'm looking at some Eastwood chassis black gloss paint for my mower. Tough enough to maintain a glossy black finish and prevent rust on a car or truck frame...should hold up to mowing...
TooTall999 is offline
post #3 of 23 Old 03-30-2011, 01:31 PM
locknut's Avatar
Bought the quart can and brushed it on under deck.Sticks and stones will chip it off,but it will protect the metal where stuff normally hangs and causes deck rot,so not all bad.
locknut is offline
post #4 of 23 Old 03-30-2011, 01:48 PM
Retired MTF Admin
Ken N Tx's Avatar
Images: 60
Many many paints and stuff have been tried (underside)...If you come up with a remedy you will be richer than Bill Gates!!
Everything that I have tried have been "sand blasted" off the underside of my decks..
Ken N Tx is offline
post #5 of 23 Old 03-30-2011, 01:56 PM
Addicted to seat time!
mistavp05's Avatar
You said it Ken. Each season I do another coat of whatever color paint I have hanging around in the shed on the underside of the deck, and after the season is over, there is no trace of that paint at all.
mistavp05 is offline
post #6 of 23 Old 03-30-2011, 02:49 PM
Onan18's Avatar
I got this Industrial grade metal primer from a metal fabrication shop that was going out of business, 100 gallons of it! When I re-built the deck for my suburban after all welding and grinding/sanding was done I mixed this primer 50/50 with thinner, (it is a gooey thick paste right out of the can) and after I chemically treated the bare metal with rust converter I brushed on this stuff THICK! I applied three coats and then painted my deck with Valspar Anti-Rust white (wasn't concerned about correctness) and three seasons later I am very pleased with how well it has held up.
Joe
Onan18 is online now
post #7 of 23 Old 03-31-2011, 12:10 PM
JRJ
The owners manual
JRJ's Avatar
Ken N Tx; yes look where you live, lots of sand in the ground, having your own sand blaster, I know for I lived in Ft.Worth for 5 yrs.
Dick
JRJ is offline
post #8 of 23 Old 03-31-2011, 12:52 PM
I have used the different spray bedliner coatings (although, not the Rustoleum), and have been disappointed in how it holds up. They chip easy, and they do have texture. Also, I made some battery hold downs for my truck, and painted them with spray bedliner coating, thinking that this would resist corrosion, and it hasn't. Both metal bars have corroded within months. I plan to use POR 15 on the underside of the deck of my B80. It may not hold up over time, but as has been stated, not much will. Perhaps you should test the Rustoleum on something besides the deck, to see how tough it is, and the texture, before applying it to the deck.
Romans 1:16 "For I am not ashamed of the Gospel of Christ..."
hodge is offline
post #9 of 23 Old 03-31-2011, 12:56 PM
zelda's Avatar
Images: 14
Friend of mine treated his with KBS on the underside of his Deer mower. He is very pleased with that results. I use POR 15, There were a couple spots it didn't hold up. I didn't sand blast it either. I would do it again.
149 Cub Cadet
990 Farm King
C-141 Wheel Horse (Sold)
Host of the "MTF Michigan Meet 2011"
zelda is offline
post #10 of 23 Old 03-31-2011, 01:06 PM
Desk by Day/Shop by Night
esnb74's Avatar
Images: 8
It holds up great on car frames quite well. Used it many times.
JD 318 H3
JD 140 H3
JD 110 RF
CC 124
CC 1250
Farmall H
Ford Mustang (64.5)
Attachments: 2 Brinly plows, Brinly cultivator, 4' Brinly Disc, 4' Land Pride back blade, IH 1 row planter, JB Sr, Johnson Loader, JD front 540 PTO, 2 JD 46" Snowblowers, Front blade, Swisher Box Blade, JD 80 Cart.
Past Equipment: JD 316, JD 318, JD 757 Ztrak, IHC 1100A Pickup, CC 3235
Future Wish List: JD X748/X595, CC 782D/982D, MF 12/14/16, Farmall Super C, Farmall AI, Farmall Cub, Case 224/222/446/448
esnb74 is offline
post #11 of 23 Old 03-31-2011, 01:22 PM Thread Starter
Thanks for the input. I am still preping the deck, so I will try painting some scrap with the liner material tonight and see how tough it seems.
bgkast is offline
post #12 of 23 Old 03-31-2011, 03:18 PM
sloweather's Avatar
Shiny, hard, smooth, abrasion resistant...
Get it chromed!
sloweather is offline
post #13 of 23 Old 03-31-2011, 08:22 PM
Collector of many tractors
Kbeitz's Avatar
I use slip-plate
Kbeitz is offline
post #14 of 23 Old 04-02-2011, 11:53 AM
Six years ago when I redid the mower under my 1650MF I painted the underside of the deck with the same paint (PPG) loaded with gloss hardner as I used on the tractor, so far it's holding up pretty well. Probably need to repaint it after this season, I noticed that the clover tends to stick to the mower now. Usually run over a few tree limbs (1"-2") and that keeps it pretty well cleaned out.
butchs_hobby is offline
post #15 of 23 Old 04-02-2011, 12:30 PM
Old Iron 1%er
what about getting a good 'base' paint (whatever you have, or choose to buy), then a couple coats of that graphite paint that some guys use in their snowthrowers?
http://www.agspecialty.com/EZslide.htm
AMCJavelin74 is offline
