Waterproof Tractor? - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 16 Old 11-17-2010, 10:26 PM Thread Starter
Waterproof Tractor?
I've just about had it with models which have their gas cap exposed to the elements. Why do so many have the gas cap out in the open?
I've had several Cub, Deere, Simplicity, Ford, MTD, Sears, and other tractors which take on water when it rains. The gauge caps are vented and trickle in water.
No matter how well you cover, tarp, or try to protect the cap, water seems to find it's way inside.
So far the only model I've found that's immune to this is my 1250 Bolens with the tank under the hood.
I've tried coffee can's laundry soap caps, tarps, nothing is fool proof.
We're going into what may be another snowy season and don't care to be outside for hours in the cold trying to clear out a frozen fuel system or tank full of water.
For example, I just drained the tank, replaced the fuel hose, rebuilt the carb on my Simplicity 3410. It got dark, so I tossed a trash bag over the tank, closed the hood, and tarped it over for the night. We got about 1/2" of rain and wind, the tarp was shredded by the next afternoon when I got back. The trash bag was still intact. I left the fuel tank bone dry after having flushed it out with clean fuel and blowing it out with air. It now had a 1/4" of water in it. The bag had gotten wet underneath somehow and the water still found it's way through the brand new gauge cap. There was still water sitting on the gauge surface.
I don't use the Bolens for snow, the plow set up is on the Simplicity. That's the machine that needs to be replaced. The Bolens is too big to fit in some places I need to go, and my Bolens has a FEL on it at all times.
The Simplicity does both trailer moving duty parking my boat, and snow plowing when needed.
I'd be open to looking for another model tractor and plow if I knew rain getting into the tank would be eliminated.
freeisforme is offline
post #2 of 16 Old 11-17-2010, 10:29 PM
wally2q's Avatar
Re: Waterproof Tractor?
What can I say ..... water hates you.
I bet Al Gore would blame global warming for the phenomenon you experienced....
LOL!!!
wally2q is offline
post #3 of 16 Old 11-17-2010, 11:04 PM
Professional amateur!
tranks's Avatar
Images: 19
you sure you don't have an enemy living next door?
i've never had a problem but i keep everything inside. maybe just keep your fuel mixed the "Heat" gas treatment.
mike
1971 John Deere 112--2000 New Holland LS55H (sold)
tranks is offline
post #4 of 16 Old 11-17-2010, 11:09 PM
tmaynard's Avatar
The older Deeres 110,112,120,140 all have the tank under the hood.
-Tom
1968 John Deere 140 H3 54 4 Way Blade, 3 Point Hitch, Brass Tag 33 Tiller
1981 John Deere 400 54 4 Way Blade, 60" Deck
And a bunch more John Deere Garden Tractors
tmaynard is offline
post #5 of 16 Old 11-17-2010, 11:12 PM
rvgary's Avatar
A bone dry tank is NO Good. You might better keep it clear full. You will get far more water in the tank when it is empty from condensation then you every will through that little air hole in the gas cap. Take a jar with a lid on it and poke a 1/16 inch hole in it and turn the garden hose on it full bore and see how much water you can get in the jar. Gas caps are normally domed so the water will not collect and run in. I will agree that OLD meter caps that have lost there seal can and will collect water and drain it into the tank. TOSS IT!!
I Good shed will solve your problem
1979 John Deere 314 with a 48" Mower and a 48" blade, Poulan ZT Pro 48" Deck, Old Farmall "M", 36" KINCO Sickle mower, 1991 Kawasaki Mule 500, Sears Log Splitter
rvgary is offline
post #6 of 16 Old 11-17-2010, 11:28 PM
chevysbest92's Avatar
anyway to rig an older wheeler gas cap on, or switch out the tank? the old 4 wheeler caps had a hose that you can run anywhere youd like
CCC 1210, Case 116yt, Poulan Pro, Sportsman 800, Can Am DS250, 2006 Silverado
chevysbest92 is offline
post #7 of 16 Old 11-18-2010, 11:26 AM
PurplDodge's Avatar
Build a shed?
1986 John Deere 316 P218 18 hp Onan 50'' deck looking for 54 blade
1992 Cub Cadet 1440 44" deck, 2,300 hours, B&S Vanguard, Gator Blades, 42'' IH Dozer Blade, Custom Light Bar, Custom hole in side of engine
2001 Chevrolet S-10 4.3 V6 5-Speed ZQ8
PurplDodge is offline
post #8 of 16 Old 11-18-2010, 01:46 PM
ACmowerguy's Avatar
The AC B-110, B-112, and early B-207 had the gas cap under hood. Best thing is to not leave them out in the rain.
SIMPLICITY- 700, 3410S, 3410H, 17GTH-L, 727, 738, 7116H, 75th anny Sovereign, '99 Landlord DLX
Allis-(2) B-10's, B12, (2) B110's, B-207, (2) B210's, B212, HB212, Homesteader 8, 416H, 710, 912H, 914S , 916H, 917H
Deutz-Allis 917H with PS
Massey-MF8 Executive, MF12, MF16,
Sears- 1971 HT14 hydro
JD - 110, 214
ACmowerguy is offline
post #9 of 16 Old 11-18-2010, 02:34 PM
Most of the older Sears tractors had the tank under the hood...but they aren't immune to water intrusion,as steel tanks like to sweat and make condensation...
I'd at least put a roof over the tractor if it must be left out to the weather--a full enclosure would be better...I've considered making one of my utility trailers into an enclosed one so I could store a tractor in it,yet still have it close to the garage so I can use it when it snows--my sheds are 75 feet out in the back yard and can be inaccessable if it snows deep enough!..
Tractor-Holic is offline
post #10 of 16 Old 11-18-2010, 09:41 PM
MTF New Poster
ben2go's Avatar
Sounds like condensation.My mower has the tank under the hood and I keep it inside a completely enclosed building.I still pick up a little water when it rains, or the humility,I mean humidity is high.My tank vent through the cap.
ben2go is offline
post #11 of 16 Old 11-19-2010, 07:16 AM
Collector of many tractors
Kbeitz's Avatar
I never let rain touch my tractors....
Kbeitz is offline
post #12 of 16 Old 11-19-2010, 08:16 AM
poncho62's Avatar
Images: 7
Your tractors are spoiled.......lol
I keep as many as possible in the shed/garage.....getting tougher to find room.
Ford LGT100
Ford LGT125
Ford LGT145(sold)
Ford LGT165
John Deere STX38
Ontario Rodders
poncho62 is offline
post #13 of 16 Old 11-20-2010, 10:29 PM
Condensation. I've never seen that happen to a JD, even those that never see a shed.
Engine_Tech is offline
post #14 of 16 Old 11-21-2010, 01:14 AM
Boyd's Avatar
Images: 10
If only John Delorean was alive to build stainless steel garden tractors,,,,,, with gulwing doors.
Toro 5xi and NH GT18/20/22 owners can join my new Toro 5xi page on Facebook. My Horses: Toro 520xi & 522xi. Toro 5xi prototype hood. WTB: for Toro Xi series 52" deck 78370/78375 and a mule drive for a 79365 single stage snowblower. For sale: Toro 5xi Belly Blade & Toro 60" deck from a 724z.
Boyd is offline
post #15 of 16 Old 11-21-2010, 06:38 AM
My Orange Jane Deere
orange j d's Avatar
Just build a ramp to the front door of your house, and puller her in like I do. And tell the ol lady to keep her yap shut. No wait buy a electric one, and come back and ask us, how do I keep everything from rusting.
Sent from my FREE MTF APP PROVIDED BY MY FRIENDS AT MTF*****
Remember: Marriage is the number one cause of divorce.
orange j d is offline
