adding lights? - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 32 Old 08-17-2010, 08:36 PM Thread Starter
JakeBlues652's Avatar
adding lights?
ive been toying with the idea of making a GT specifically designed for plowing snow in the winter months. you gotta have the duals if your gonna buld one for plowing itself. then i decided, well, when im plowing at night, so i dont get nailed, and for looks, you need to add a couple of lights.
just so happens, i got the northen tool catalog today! what timing?! after dinner i took a browse through the trailer lights. i found some nice ones. i narrowed it down to this one: http://www.northerntool.com/shop/too...4535_200324535
it says it operates from 9-16 volts. if i ran two of these, on an older cub cadet with the starter/genarator type system, i would need another power source wouldnt i? i figured id need some sort of alternator to keep up with the power demand. so lets figure i do need an alt. i could hook it up to the PTO and turn it on when the lights were on right? then i could just wire the alt into the battery and tie the lights into the battery with a switch on the dash.
with these lights being ones with an optional turn signal, is there a possible way to wire them to they are flashers sometimes and just solid others? i would need some kind of relay wouldnt i?
throw in your suggestions. im open to ideas of any kind.
sorry for the dumb questions..im new at this wiring stuff
Proud Owner and operator of:
1985 John Deere 212
2010 Polaris Sportsman 500 H.O.
1999 Chevy Silverado 2500 6.0
1967 Chevy C/10 4x4 5.0 with a 3" lift and 35's
2000 Chevy S-10 with the MASSIVE 2.2
I'll keep my guns, freedom, and money.
You can keep the 'change.'
-Hank Williams Jr.
JakeBlues652 is offline
post #2 of 32 Old 08-17-2010, 09:00 PM
jason4567's Avatar
Re: adding lights?
That page doesn't mention how much amperage those draw, so it is hard to say. I think that you would get away with it. As far as the blinker function, I don't know. I have never wired something like that. I had a Bolens 1050 that actually had 2 of the starter generators mounted on it to supply more power. The second one was wired completely independent from the first.
Jason
Bolens
Tube Frame: 600, 800 (2), 900 (2) 1000, 1050 (4), 1225, 1254 (2), 1256, G14, H14
Large Frame: 1250 (5), 2086
Others
Bolens RAM, Bolens FS-11, Copar Panzer, Sears SS12, Sears Custom 6, Gravely LI, L8, L, Comm.10a, Farmall Cub
jason4567 is offline
post #3 of 32 Old 08-17-2010, 09:05 PM
89YT12's Avatar
Images: 9
Re: adding lights?
the amp draw on dim is under 1 amp, they are LED you could power them off of a garage door opener battery if you wanted, thats how little amps they take,same goes for bright
you can wire in a flasher to get them to flash, but you have to get a eletronic flasher not a thermal, just the 2 blade one will work
Jason "J"
89YT12 is offline
post #4 of 32 Old 08-17-2010, 09:18 PM
10,000 +posts!
Re: adding lights?
... you gotta have the duals if your gonna buld one for plowing itself.
I'd forego that one right away and save the money for LED lighting and a set of chains. Duals are great for traction in the dirt but not so hot in snow/ice. Singles w/proper weight and chains will serve you far better this Winter.'
Funny, I was just looking at the page below for lights before I logged on here:
http://vehiclelight.com/clli.html
Might be an alternative...
HydroHarold is offline
post #5 of 32 Old 08-17-2010, 09:28 PM
89YT12's Avatar
Images: 9
Re: adding lights?
ohhh chicken lights
Jason "J"
89YT12 is offline
post #6 of 32 Old 08-17-2010, 09:28 PM
jason4567's Avatar
Re: adding lights?
I agree. Dual allow for wider weight distribution which means less pressing down on a small area which ultimately means less traction (at least that's how it was explained to me). You are best off with relatively narrow tires and plenty of weight.
Jason
Bolens
Others
post #7 of 32 Old 08-17-2010, 09:32 PM
89YT12's Avatar
Images: 9
Re: adding lights?
Jason
yea, thats what i been told too when i was wondering why my YT has narrow tires when i was replacing them with new one ....... im used to running performance cars at a drag strip where you want wide as can be to grip, compairing a drag setup to a tractor setup with tires is like apples and oranges
BTW NICE NAME
Jason "J"
89YT12 is offline
post #8 of 32 Old 08-17-2010, 09:41 PM Thread Starter
Re: adding lights?
am i right there?
1985 John Deere 212
-Hank Williams Jr.
post #9 of 32 Old 08-17-2010, 09:46 PM
89YT12's Avatar
Images: 9
Re: adding lights?
from your positive source, to your "flasher" switch, run wire to one terminal on the flasher, then one wire from the other flasher terminal to one light, branch off that wire with another one for the other light, i soder and use heatshrink
for the dim (running) mode, just leave the flasher out of the set up, i would just branch of my headlight wire, thats how i did mine
Jason "J"
89YT12 is offline
post #10 of 32 Old 08-17-2010, 09:55 PM
The Travelin' Mod
davidg's Avatar
Re: adding lights?
you could do it with 1 switch if you use a dual pole dual throw switch.
Check out our new HOMEPAGE
davidg is offline
post #11 of 32 Old 08-17-2010, 09:58 PM
The Admin from... Nowhere
littletractorguy's Avatar
Images: 6
Re: adding lights?
And don't forget, the VERY FIRST thing that should be hooked to the POS terminal of your battery (or to any accessory power outlet you plug these into) should be an in-line fuse holder/w a fuse of suitable amperage (I wouldn't think more than a 2 or 3 amp 12 volt fuse...) or fusible link... Safety first! Of course, if it were me, I'd be putting a switch after the fuse, before the relay, just so I could turn them off when I didn't need them....
littletractorguy is offline
post #12 of 32 Old 08-17-2010, 10:11 PM
89YT12's Avatar
Images: 9
Re: adding lights?
Originally Posted by littletractorguy View Post
And don't forget should be an in-line fuse or fusible link... Safety first!
DANG how did i forget that, and im the one always doing peoples wire work, and always saying bring me a relay and a fuse holder if you want me to do it
Jason "J"
89YT12 is offline
post #13 of 32 Old 08-17-2010, 10:13 PM
lynnr's Avatar
Re: adding lights?
My experience - duals don't help, ags don't help. Chains?
Lights...in my part of Michigan, not too much..if you frit 'em with too much they freeze like rabbits...arms, legs and eyes...and the vehicle maintains speed and direction until they snap out of it
Just another hacker - bits and bytes by day, iron by night, trees on weekends.
lynnr is offline
post #14 of 32 Old 08-17-2010, 10:22 PM
Re: adding lights?
Those LED lights draw a very small amount of amperage compared to the incandescent lights we have all used for years. The CC starter/generator should be giving you around 15 amps to do what you need.
The Stop/Turn/Tail lamps have two sets of elements (Diodes) in them. The tail lights are dimmer and are like the ones you see on many trucks. When the second set of elements are activated the light goes to full bright and works just like the tail and brake/turn lights on your car.
You could easily wire the tail lights to stay on as needed and activate the Turn/Brake elements as flashers just like the four way flashers to which you are accustomed.
You should have plenty of electricity from the S/G to operate half a dozen of these lights plus a couple of LED headlights with no problem.
Mike
A gun and a parachute are much the same. When you need one nothing else will really suffice.
Tencubed is offline
post #15 of 32 Old 08-17-2010, 11:22 PM
Professional amateur!
tranks's Avatar
Images: 19
Re: adding lights?
those tail lights would be pretty cool. you could wire the tail lights on when the key is on and then have a switch and flasher relay on the brake/turn lights.
heres an electronic flasher.
http://www.amazon.com/Bussmann-BP-55.../dp/B000BXMDRY
i have two beehive type amber lights on the front and one red marker light on the back. i want to add another red marker light on the back and then make some kind of removable light pole, maybe with two work lights, one point forward and one backwards.
i think i should switch over to leds marker lights front/back before i add any works lights though. i'll probably use some 35 watt fog lights for work lights.
mike
1971 John Deere 112--2000 New Holland LS55H (sold)
tranks is offline
