Grass Blowing Out from Under Deck - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 13 Old 08-14-2010, 03:14 PM Thread Starter
Hi, I recently traded in a 1995 Wheelhorse 13-38HXL on a new Toro LX468. I could mow on my old tractor without hardly getting a blade of grass on my lower legs. But on this new mower, my lower legs are covered in grass by the time I'm done. The grass seems to be blowing up from underneath the deck. I mow at exactly the same height (3 inches). Has anybody else experienced this issue when changing tractors, and could you do anything about it (other than wearing pants instead of shorts - LOL)?
Maybe the issue is the larger engine (23 hp Kohler Courage instead of 13 hp Briggs). I wasn't sure if any type of deflectors exist for this issue.
Thanks!
Gary
GWBlack is offline
post #2 of 13 Old 08-14-2010, 06:26 PM
skunkhome's Avatar
Images: 9
Re: Grass Blowing Out from Under Deck
It is likely that it is just the difference in the design of the mowers.
skunkhome is offline
post #3 of 13 Old 08-14-2010, 07:07 PM
MTF Junior Poster Esq.
attorney_barnabas_collins's Avatar
Images: 16
I had a new Huskee several years ago that cut bad and blew grass out. The blades were designed badly or the deck was. Solved my problem with aftermarket blades without the odd mulching curl to them, just straight with the angled up tips.
Mowed 100% better.
attorney_barnabas_collins is offline
post #4 of 13 Old 08-19-2010, 09:01 PM
A semi-retired senior cit
Mower_Man42's Avatar
Images: 3
Your new Toro LX468 is a lawn tractor that is built by MTD for Toro. Shame on Toro`s bean counter Did your dealer tell who made the tractor? The dealer I do business with refuses to sell any of those tractor. But this is besides the point, you need help, Toro use to make blow out shields.
If your mower has the wave mulching blades try exchanging them for another set maybe there`s a set of regular blades or a set of Gator blades made for your tractor. List the blade part number that your manual calls for and someone can look that number up for you. I just took a quick look under Toro and found nothing for a 46" deck, I took a look at Cub Cadet and I`m not sure of what blade you need, do you use 3 blades or 2 blades? Seems the mounting holes are star shaped or another style used.
_________________________________
1985 Lawn Boy commercial Model 8453
1991 Toro Re-cycler 3 speed model 20218
2005 John Deere G110/54" deck
2008 Cyclone Rake Command Pro
1981 Wheel Horse C-85 with snow plow
1969 Case 444 PK with 44" mower deck
2009 Honda HRX hydro Drive 21" Versamow system.
2006 Scag Wildcat 52" cut 25hp Kawasaki
Mower_Man42 is offline
post #5 of 13 Old 08-19-2010, 09:24 PM
standard issue neuralyzer
LLigetfa's Avatar
Ja, I'd try a set of Gator blades. You could also try dropping the RPMs a tad.
LLigetfa is offline
post #6 of 13 Old 08-19-2010, 10:17 PM
MTF New Poster
ben2go's Avatar
His Toro deck should be the same as my MTD/Bolens.I have yet to find a set of Gator blades for it.All I can find is those crappy wavy blades.I go through at least one set a year.This year I been through two sets.The edges of my blades get thin and split.When that happens I have grass flying every where.I have no debris in my yards to tare up blades,no sand or dirt either.
New set,old set,and first set of the year.The really rusty set has 10 cuts and the freshly worn blades have 6 cuts.
ben2go is offline
post #7 of 13 Old 08-21-2010, 12:01 AM
oriyen's Avatar
what are you cutting? sandy grass?
oriyen is offline
post #8 of 13 Old 08-21-2010, 09:40 AM
MTF New Poster
ben2go's Avatar
No sand in my area.If you break ground here,it's red clay.
ben2go is offline
post #9 of 13 Old 08-21-2010, 10:19 AM
Gravely bug bit.
You got wire grass in your yard? That stuff will wear a blade down fast.
Current L/C count = 38.
Fla Don is offline
post #10 of 13 Old 08-21-2010, 10:24 AM
LLigetfa's Avatar
That's some amazing wear. I bet Gators would stand up longer.
LLigetfa is offline
post #11 of 13 Old 08-22-2010, 03:04 PM
MTF New Poster
ben2go's Avatar
A little.The old timers around here call it creeping grass or Bermuda grass.
ben2go is offline
post #12 of 13 Old 08-22-2010, 03:06 PM
MTF New Poster
ben2go's Avatar
They will but I can't find any to fit my application.I may try those knock offs that Lowe's sells.I think they are made by Arnold.
ben2go is offline
post #13 of 13 Old 08-22-2010, 05:10 PM
LLigetfa's Avatar
I don't know if the knock-offs are as hard as the fusion technology that Oregon uses on their Gator blades. There's more to it than just the wing tips.
LLigetfa is offline
