23X10.5X12 ag tires, rim question - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 26 Old 03-03-2010, 07:06 PM Thread Starter
I bought a set of super lug carlisles in the above size for my John Deere 265. The rims I have seem to be too thin by about 1 to 2 inches. Do I have the right rim or are these tires just different from turf tires and are really hard to put on?
I bought these loose rims off ebay about a year ago and I'm positive the ad said they were for 10.5" wide tires. These tires don't flex like turf savers do, so that's why I'm posting what may be a very dumb question. Thanks!
Home Wood is offline
post #2 of 26 Old 03-03-2010, 07:11 PM
Run ahead of the pack
stladrill's Avatar
Images: 6
Re: 23X10.5X12 ag tires, rim question
If I remember good 23x10.50-12 go on 8.5 rim wide, someone can confirm that?
stladrill is offline
post #3 of 26 Old 03-03-2010, 07:33 PM
migraineman's Avatar
Images: 31
You can grab the Carlisle catalog. It lists the recommended rim dimensions for their tires.
migraineman is offline
post #4 of 26 Old 03-03-2010, 07:44 PM Thread Starter
Thanks for the help. The catalog doesn't list this size for the super lug. It does list this size for the true power tires. The rim width for the true power is 7 inches. I guess I have the right rims and these suckers are just really hard to put on. I got one of them almost all the way on with about 4 or 5 inches of bead left to roll on. I couldn't go any further. The rim lip bent! Any suggestions to get these on?
post #5 of 26 Old 03-03-2010, 08:33 PM
paul52446m's Avatar
I lot of 23 10.5 12 tires are only 9" wide, but the carlisles are just about the width they say they are. I ordered a set of lugs for a pulling tractor and the one a got were 8.5 wide sent them back and ordered the carlises. But for a pulling tractor using a 10.5 wide tire you build your wheels to be 11" wide.
Later Paul
paul52446m is offline
post #6 of 26 Old 03-03-2010, 08:42 PM
DeereMan's Avatar
It sounds like you might be installing them from the wrong side of the wheel. The tire has to go on the wheel on the same side as the valve stem. The tire bead has to be able to slip down into the drop center of the wheel in order to have enough clearance for the tire bead to clear the wheel rim. If you were applying enough pressure to bend the wheel you are doing something wrong.
1996 JD 345 w/custom electric sleeve hitch
1987 JD 332 w/3 point hitch and rear PTO
1987 JD 322 w/3 point hitch
1987 JD 318 w/3 point hitch
1980 JD 212H w/factory sleeve hitch
DeereMan is offline
post #7 of 26 Old 03-03-2010, 08:50 PM
You need to take them to a tire shop and let them put the tires on the wheels with the new style mounting machine. The "V" in the rim isn't out far enough to allow the tire to go in so you can stretch the tire over the outside of the rim.
2 cub 100's
1 cub 102
1 cub 122
1 cub 682
1 copar panzer tricycle on cub chassis
67' VW bug
79' VW bus
01 polaris xc 600
02 polaris xc 500
shorty is offline
post #8 of 26 Old 03-03-2010, 08:52 PM Thread Starter
Ok that makes sense. Thanks. I thought I was going to have to hunt for rims..again!
John Deere 265. 17hp Kawasaki (sold)
Tractor'less
post #9 of 26 Old 03-03-2010, 08:53 PM
The Magnificent
D-Dogg's Avatar
Mais bien sur!
My rims are 8.5" wide. Rule of thumb is 1.5" - 2.5" narrower than the tire.
D-Dogg is offline
post #10 of 26 Old 03-03-2010, 09:25 PM
Small Fry's Avatar
That is how it once was. Carlisle now is saying 7 inch rim for most of their 10.50 tires. They may have change the tires a little ?
Small Fry is offline
post #11 of 26 Old 03-03-2010, 09:49 PM
stladrill's Avatar
Images: 6
Originally Posted by D-Dogg View Post
Mais bien sur!
Bravo,,, I was all mix up at first
post #12 of 26 Old 03-03-2010, 10:14 PM
blown67's Avatar
These are 26x12x12's and they got mounted on 8.5" wide rims, they are 8 ply, I was able to get one side on by hand but no way I could even get the other side started, brought them to town fair tire and for 12 bucks they popped them right on for 12 bucks.
blown67 is offline
post #13 of 26 Old 03-03-2010, 10:46 PM
Where to find the 12x8.5" wheel?
Is there anyone that might offer a package deal, ie; AT101s mounted on 8.5 wheels for a Craftsman GT?
I take it the wheel is a common generic bolt pattern & BS....
Any help is appreciated...
Norm
High Cetane is offline
post #14 of 26 Old 03-03-2010, 10:53 PM
The Magnificent
D-Dogg's Avatar
Norm
Norm, those are very common rims. All over Ebay. Also I believe millertire sells rims and could most likely get you a package deal.
D-Dogg is offline
post #15 of 26 Old 03-03-2010, 11:00 PM
Protrucker's Avatar
Where'd you find those Super Lug's? If you don't mind, could you say what you paid for them?
If you meet me and forget me you have lost nothing.
If you meet God and forget him you have lost every thing.
Things may come to those who wait,
but will only be the things left behind from those who hustle....
_____________________________
(5) Allis Chalmers: (2) B's 1944 & 1949, D14, WC & G
(2) Case 444's 77 & 1969 PK
Ford LGT165
Ingersoll 4016PS
Case 580B
2 Brinly plows, 2 Brinly cultivators
Brinly single row disc, Spring harrows
Protrucker is offline
