Liquid-filled Tires? - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 30 Old 12-14-2009, 04:39 PM Thread Starter
willtractors101's Avatar
Question Liquid-filled Tires?
I have heard that you can put antifreeze into your tires to weight them down and get traction. A couple questions:
1) Is it worth it...does it actually work?
2) How do you get the anti-freeze in the tire?
3) Are they aloud in local tractor-pulls? (I know there are different rules for different towns...but I'm wondering in general)
Thanks!!!!!
"I have not failed. I've just found 10,000 ways that won't work." -Thomas Edison
1969 Sears Custom 10XL
-Dozer Blade
-26x12-12 Dick Cepek Pulling Tires (loaded 85lbs each)
-Concrete Wheel Weights
-Custom Rear Weight Bracket
My new toy:
1993 Dodge W250 Cummins Turbo Diesel
willtractors101 is offline
post #2 of 30 Old 12-14-2009, 04:51 PM
P B G's Avatar
Re: Liquid-filled Tires?
1: weighted tires do work (rim guard 11/lbs per gallon which depending on tire size could add 100's of pounds of fluid ballast)
2: there's a fitting that screws onto the tire stem and allows air to come out in exchange for fluid.
3: no clue, would have to check the rule books re: amount of ballast allowed.
The fluid isn't necessarily anti-freeze, and being that anti-freeze is toxic should probably rule that out.
The fluid used to be calcium chloride, which unfortunately tends to corrode wheels.
Rimguard is popular http://rimguard.biz/
also some have used windshield squirter fluid, which is also toxic (methanol) but not really something someone would be likely to drink, antifreeze is sweet tasting and as such some animals/children will drink it.
you could also probably use Pink RV antifreeze which is non-toxic.
But I believe rimguard is about the heaviest by volume solution on the market besides calcium chloride.
P B G is offline
post #3 of 30 Old 12-14-2009, 05:02 PM
1) for as long as there have been pneumatic tractor tires it has worked.
2) they sell a tool. or you can pull the valve stem core (the center part of the stem) and use a hose & funnel to pour it in which will take a while but is free.
3) don't know.
google: tire ballast for more info.
FoodPlotter is offline
post #4 of 30 Old 12-14-2009, 05:23 PM
1086's Avatar
Images: 11
Thanks!!!!!
To determine the value of fluid filled tires, fill one tire only and try driving up a slick incline.
This information was submitted by a branded site supporter.
1086 is offline
post #5 of 30 Old 12-14-2009, 05:26 PM
Wheeler09's Avatar
Images: 7
A lot of guys here put RV anti-freeze or Windshield washer solvent in for weight. If you have tubeless tires you can break the bead on the valve stem side and pour it in. The tires on my Wheel Horse B-100 took 5 gallons and it added 45 lbs per tire. There are a few threads on this site about it if you do a search.
1 - B 100
1 - Cub 1250
1 - 67 Simplicity 2 wheeler model "W"
2 - Toro S200
1 - Toro Snow Pup
1 - toro SnowMaster
1 - Lawn Boy 10327
1 - TroyBuilt Tiller
Wheeler09 is offline
post #6 of 30 Old 12-14-2009, 05:36 PM
Jon318's Avatar
Id love to have loaded tires but I run tubes in them...is it possible to fill the tubes? Seams like Id need a pump of some kind...
Jon318 is offline
post #7 of 30 Old 12-14-2009, 06:06 PM
1086's Avatar
Images: 11
Tubed tires were liquid filled long before tubeless tires were developed.
If you can find small plastic tubing that will go in the valve stem with the schrader valve removed and adapt about a 6 inch long piece to a little larger like 1/4" or 3/8" hose you can siphon it in from the gallon jug while you wax the tractor, change oil or play ball with the kids.
1086 is offline
post #8 of 30 Old 12-14-2009, 06:14 PM
Jon318's Avatar
Wow! Thanks Maybar, I learn something new everyday. I guess I have yet another project. lol
Jon318 is offline
post #9 of 30 Old 12-14-2009, 06:22 PM
MTF New Poster
ben2go's Avatar
If you use methanol,just remember that it is flammable.Using tubes will help slow the rust problems associated with liquid fill.
ben2go is offline
post #10 of 30 Old 12-14-2009, 06:31 PM
Run ahead of the pack
stladrill's Avatar
Images: 6
My tire size are 20x10x8, 66 pound (75% fill)
I include The chart for weight (HydroFlation Table AGTires PDF files)
Name:	Wheel wheight 5.jpg
stladrill is offline
post #11 of 30 Old 12-14-2009, 09:05 PM
P B G's Avatar
I was amazed when i went to get a leak fixed on two tires, one for a John Deere A, and another for a Farmall cub, that stinking Cub wheel with its calcium chloride weighed about the same as the empty wheel off the much larger john deere.
P B G is offline
post #12 of 30 Old 12-15-2009, 12:07 AM
I have 26x12x12's and filled them with none freezing ww fluid many, many years ago. Each weighs 180#'s.
mrcaptainbob is offline
post #13 of 30 Old 12-15-2009, 01:11 AM
Does anyone who uses windshield washer fluid ever find any signs of rubber damage due to the alcohol content in contact with the rubber?
I've often thought about RV antifreeze, since RV's often use rubber couplers, its most likely safe for rubber as well as metal?
I've had used machines with automotive antifreeze but it's a mess when the tire gets a leak and pretty toxic if it spills.
Forget Calcium Cloride, it eats up the rims too bad, and I prefer not to run tubes. Rimguard is too costly, as is Slime, which the local shops recommend here. I can also imagine a tire change after filling two back wheels with slime. Its got to be a real mess. Besides, if that stuff dries when it contacts air, what happens to it over time?
yardiron is offline
post #14 of 30 Old 12-15-2009, 01:20 AM
MTF New Poster
ben2go's Avatar
You can find enviro friendly RV plumbing antifreeze.I know people have run it without issues but it will cause rims to rust after awhile.
ben2go is offline
post #15 of 30 Old 12-15-2009, 02:19 AM
What is RV antifreeze made of?
Those with larger tractors here are steered towards Slime tire sealant for weight but it's not cheap.
I know a few guys that use regular car a/f but they still have rusty rims after a while. A few do use used a/f from the local gas station but most use pure ethylene glycol a/f straight. I've dismounted a few of these wheels/tires and it's a mess. I can't imagine Slime in a tire.
yardiron is offline
