Flywheel removal on Briggs horizontal engine - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Small Engines and Repair
Midwest Mower Pro
post #1 of 12 Old 10-20-2009, 11:04 PM Thread Starter
RideoutKSC's Avatar
I'm trying to remove the flywheel on my briggs engine in my snowblower. I removed the engine cover so far. A guy down the street told me to grab around the recoil starter with some water pump pliers and just unscrew it.
Well, I've tried that. I almost broke my hand doing it. Anybody have some tricks to doing this? I need to replace my points so I can start blowing snow!
RideoutKSC is offline
post #2 of 12 Old 10-20-2009, 11:55 PM
badfox9389's Avatar
Re: Flywheel removal on Briggs horizontal engine
reverse threads?
Lawn-Boy 7216 1966
Lawn-Boy 8238AE 1979
Lawn-Boy 7035 1986
Lawn-Boy L21ZPNB 1990
Lawn-Boy 10401 1996
1972 Jacobsen push mower Briggs 4 cycle
-----Sold-----
10518, 10304, 10201, 10323, 10302
badfox9389 is offline
post #3 of 12 Old 10-21-2009, 12:45 AM
Castor Freak
Croc's Avatar
Images: 8
With my Briggs horizontal engine, I had to wedge a piece of iron (like a chisel) between a flywheel fin and the concrete beneath it, then I took a piece of wood, placed it on one of the little "ears" (thats on the starter area that holds the flywheel screen on) and struck that with a hammer to get it off. It had right handed threads on mine so it should on yours.
My Lawn-Boy mowers
D-449 Engine, Model 8229F Self-Propelled
F-200 Engine, Model 5026
E-Engine, Silver series, DuraForce Model 10247
V-Engine, Silver series, Model 10201
F-Engine, Model L21ZPNA
F-Engine, Model S21ZPM
F-Engine, Model 6259 Commercial(x2)
D-Engine, Model 8253 Self-Propelled
C-Engine, Model 5250 Quiet-Flite
D-Engine, Model 5237
D-Engine, Model 5021 Bricktop
C-Engine, Model 3052 Buttercup
C-Engine, Model 5000 Bricktop
Croc is offline
post #4 of 12 Old 10-21-2009, 01:22 AM
You remove the spark plug, rotate the flywheel so the piston is "down", then stick a bunch of rope in the spark plug hole. This will jam the piston before it can reach top dead center and thus will not be able to rotate.
If it doesn't jam the piston just remove the rope and try sticking it in again. Can be a little tricky to get it into the cylinder but it's still pretty straightforward.
Chagrin is offline
post #5 of 12 Old 10-21-2009, 08:18 AM
Senior MTF Poster
"reverse threads?"
No.
Use suggestion above, stay off those cooling fins or you are likely to break one.
Question is how are you going to torque the flywheel when re-assembling? They sell a cheap tool that spans the recoil hub and adapts to a socket.
Walt Conner
Walt 2002 is offline
post #6 of 12 Old 10-21-2009, 10:53 AM
Stan the Air Man's Avatar
Model, type and code numbers would take the guess work out of my reply.
If the engine is a Briggs and Stratton Two-Cycle Snow Engine here is what the service manual says:
1. Remove flywheel nut and starter cup.
2. Reinstall nut flush with the end of the crankshaft.
3. Remove the flywheel by pulling up on the edge of flywheel while striking the flywheel nut with a soft mallet.
Stan the Air Man is offline
post #7 of 12 Old 10-21-2009, 10:49 PM Thread Starter
RideoutKSC's Avatar
Briggs and Stratton 4 cycle. I don't have the model number at this time. Well I did, but my cat took the business card I had that info written down on.
post #8 of 12 Old 10-21-2009, 11:16 PM
HeadCase For My Ingersoll
ClassicMotion's Avatar
Images: 11
Stupid question but do you have an impact... even an electric impact?
1968 Case 195
1974 Case 222
1975 Case 210
1978 Case 222... The one that started it all.-customized with a 44" deck and snowcaster.
1981 Case 220
ClassicMotion is offline
post #9 of 12 Old 10-22-2009, 09:40 AM Thread Starter
RideoutKSC's Avatar
Yea I have one. Where should I look for this special tool that spans the recoil hub?
post #10 of 12 Old 10-22-2009, 10:02 AM
I trust you have verified that the engine still has points before you go through the trouble of removing the flywheel. If the code # starts with 85 or higher, it should have electronic ignition. Also, do not hit the end of the crankshaft extension with a steel hammer, you'll mushroom the end of it.
rscurtis is offline
post #11 of 12 Old 10-22-2009, 05:43 PM
Senior MTF Poster
I got my tool to span the recoil hub from Stens, they are on line. I THINK you can add a "trigger" such as Atom to your coil , also from Stens, or B&S also has a conversion kit with no need to remove the flywheel IF you have points.
Walt Conner
post #12 of 12 Old 12-07-2009, 03:21 PM Thread Starter
RideoutKSC's Avatar
I got the flywheel off! Actually, I came home from class and my dad was in the process of taking it off. He used a giant monkey wrench and it came off very easily. As it turns out the ground wire was knicked and it was grounding out, which was preventing spark. I taped it off and put everything back together and the thing started up on the first pull.
