Another victory for MMO! Revived a seized motor - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Small Engines and Repair
Midwest Mower Pro
post #1 of 7 Old 08-30-2012, 10:25 AM Thread Starter
Ben's Lawn Mower Repair
benhogan's Avatar
So I get this email from my neighbor...
Hey Ben-
I have a new Toro, emphasis on new. Yes, I finally replaced my 14 year old craftsman mower. Unfortunately I was away when the new mower was purchased and my oldest didnít put enough oil in the engine so it burned out the first time it was used. Sadly the toro repair said there wasnít anything to do as a new engine would cost as much as a new mower. Costly lesson for my son to learn about having enough oil in an engine. Would you like the mower for your parts repair? If so, let me know when you will be around and I will drop it off. Thanks.
Tracy
he dropped off the mower yesterday and it was indeed seized up. I decided to overfill the crankcase and combustion chamber with MMO and then let it sit for an hour while i had supper. I drained the MMO (too expensive to dump) into the back into its jug. I put the normal 19.5 oz of HD30 oil in then I turned the mower on its side then slowly turned the blade back and forth. The dang motor was now "unseized"! It started right up. To really test it, I let it run for 30 minutes with no issues.
MMO is just awesome. I decided not to be a hog so I emailed the owner telling him it is fixed and he can pick it up.
Ben
1987 Mercedes 190d 2.5turbodiesel
1999 Buick LeSabre
benhogan is offline
post #2 of 7 Old 08-30-2012, 11:13 AM
Certified Technician
RED-85-Z51's Avatar
Images: 7
Re: Another victory for MMO! Revived a seized motor
It wont live very long...but it might last a few cuttings.
When something seizes, by definition there is galling or metal to metal contact, when this happens the softer metal will smear or transfer to the harder metal. I nthe case of the bottom end, the aluminum rod transfers to the hard crank. In the top end..the aluminum cylinder transfers to the chrome plated piston and rings.
While it may still function, odds are good that major damage has been done, and it will have a much much shorter life span.
1993 Wheel Horse 416-H
Onan P216G
1962 WH702
1997 K3500 Dually Sierra
1995 K3500 Silverado
TBI 454
1995 K2500 Silverado
6.5 Detroit Turbo Diesel
1994 GMC Sierra Z71
350 TBI
RED-85-Z51 is offline
post #3 of 7 Old 09-03-2012, 11:55 AM
Busted Knuckle
what is MMO?
Cohiba54 is offline
post #4 of 7 Old 09-03-2012, 12:06 PM
I Love All Color Tractors
DJ in WV's Avatar
Images: 6
Originally Posted by Cohiba54 View Post
what is MMO?
MMO = Marvel Mystery Oil
My YouTube Page
The Shops of Oak Point Farm
My Equipment:
1961 Gravely LI Postal
1967 Gravely 430
1970 Gravely C10A
1971 Gravely 430
1972 Gravely 816
1973 Gravely Model C8
Many other Gravely C's, L's, and LI's
1982 Gravely 8123
1983 Troy Bilt Junior
1988 Gravely Pro 12
DJ in WV is offline
post #5 of 7 Old 09-03-2012, 08:29 PM
I did something similar (seized by over-speeding) with an old Tecumseh. Freed it by hand with MMO, then had a major breakdown (rod, I assume), the very next time I used it (this was on a tiller).
Mike
mikeinri is offline
post #6 of 7 Old 09-03-2012, 09:24 PM
Ralphst16's Avatar
MMO is a good product. My neighbor has a 1968 ford backhoe with a 3 cyl gas engine that was seized due to water getting in the head. My dad fixed it for him by soaking the cylinders with MMO and cranking it slowly by hand. I agree though, seizing from rust is one thing, but once an engine seizes from lack of oil it's pretty much done.
1973 Sears ST16 (48" mower deck, front plow, snowblower, litter whisk, broadcast spreader, manual 3 pt hitch, penn line dump trailer)
1964 Bolens Husky 900 (38" mower deck, front plow, home made dump trailer)
1969 International Scout 800a
Ralphst16 is offline
post #7 of 7 Old 09-05-2012, 01:50 AM
I have a still running 1979 briggs 11 hp that had the top bearing seize due to lack of oil. That was about 16 years ago. On the other hand I got another 28 series seized from no oil with some rod to crank transfer. When cleaning it up I noticed a tiny tiny crack in the rod. Replaced it and got a summer of heavy cutting from it. Haven't used it much this summer. I expect that had I left the original rod in it then it would have blown.
38racing is offline
