17hp intek engine? - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Small Engines and Repair
Midwest Mower Pro
post #1 of 11 Old 07-06-2012, 07:42 PM Thread Starter
flash5153's Avatar
17hp intek engine?
I just got this on a Scotts mower. 17/42
I can't read the numbers on engine,,but it is single,17 hp briggs intek engine with OHV.
The oil chamber was full of gas when I looked at it. Drained it out ,,figured the carb has problems. I put a shut off on it for now.
Fresh oil,,fired it up and there is allot of blowback from the breather hose going to bottom of carb,,and it smokes from exhaust too.
I figured it might clean out after a bit of running ,,but no such luck.
I'm not sure what the head looks like as far as the problem being a head gasket. Since I can't look up parts or a diagram. Does the head gasket separate the valves from cylinder??
Anyone know the numbers on this engine?? looks like 31777 but i get no info for a engine with that number.
flash5153 is offline
post #2 of 11 Old 07-06-2012, 08:42 PM
Certified Technician
RED-85-Z51's Avatar
Images: 7
Re: 17hp intek engine?
Your model # is a digit short.
But it does sound alot like a blown head gasket.
1993 Wheel Horse 416-H
Onan P216G
1962 WH702
1997 K3500 Dually Sierra
1995 K3500 Silverado
TBI 454
1995 K2500 Silverado
6.5 Detroit Turbo Diesel
1994 GMC Sierra Z71
350 TBI
RED-85-Z51 is offline
post #3 of 11 Old 07-06-2012, 08:54 PM Thread Starter
flash5153's Avatar
If I take some pictures,,,wondering if someone could ID the engine??
There is a tag on the engine but it is worn to the point I cannot read it.
Maybe if I put this on the john deere(Scotts) forum someone else has a 1742 with this engine in it.
The guy at the parts store don't like it when you tell him,,,,ah,,,,,"I have this engine and I need parts for it""" And then you don't have any numbers!!! lol
post #4 of 11 Old 07-06-2012, 09:28 PM Thread Starter
flash5153's Avatar
I figured it out. It's 311777. And I found out a head gasket is about $8 and does separate the valves from cylinder. That is good news for me ,,I think!
The carburetor is similar (or the same)as one I have worked on before,,and it seems once they leak,,,they can't be fixed. Or maybe just my luck.
post #5 of 11 Old 07-07-2012, 11:05 AM Thread Starter
flash5153's Avatar
I'm going to get a head gasket soon,,they have it in stock.
The very nice older man that sold me this tractor,,told me it started smoking and just got worse over time. And he said he took it to a repair shop and they told him it needed to be rebuilt!!!Or a new engine. He also said,,they did not even look at it,,or start it. Yep,,,He had it with him,,and they did not even look at it.
The engine was completely full when I received it,,mostly gas!! I have never seen a engine with this much fluid in it.I'm guessing 4 quarts.(all the way up the dipstick)
It makes sense to me that the carb started leaking first,,filling the oil chamber,,(causing some smoke)then it was so full,,and running,,, it blew the head gasket! (causing more smoke)
PO was lucky this thing didn't blow up like a bomb!!
He told me when I went to buy it,,that he could start it up if I wanted. This is a reason I always insist that we do not start engines with problems.
They want $55 for a carb kit,,,wow!! I will wait til I change head gasket and clean the carb first,,to try solving this issue.
I'm hoping no other serious damage has been done,,But I don't think so,,because it sounds OK running it now.
post #6 of 11 Old 07-07-2012, 11:10 AM Thread Starter
flash5153's Avatar
One thing that I don't understand right now is how that much gas is getting into the oil chamber.
And without causing problems on start up in the combustion chamber. Usually if gas is flowing through carb into chamber ,,it fills it and will blow out muffler on start up.
I have none of that.
All I can figure is the bad head gasket is letting it by,,out of combustion chamber.
post #7 of 11 Old 07-07-2012, 08:13 PM Thread Starter
flash5153's Avatar
I put a head gasket on,,and it runs like new!!! It was definitely blown.
Unbelievable!!!
post #8 of 11 Old 07-07-2012, 09:54 PM
Senior MTF Poster
You installed a gas line shut off valve and I would make it a practice to use it to save possible future problems.
Walt Conner
Walt 2002 is offline
post #9 of 11 Old 07-07-2012, 10:03 PM Thread Starter
flash5153's Avatar
Walt Conner
Yes I agree,,,I did clean the carb while it was off,,,but I didn't see anything wrong. The solenoid was working as it should.
I am using the shut off. Although I don't know if the gas leak is fixed,,,there is only one way to find out,,and I don't like that way. lol
post #10 of 11 Old 07-08-2012, 01:31 PM
I assume you checked the needle and seat and carb bowl to be free of crap. I test mine when off the engine by mounting it to a bracket clamped to a bench with a fuel tank hanging above it. Mark the fuel line and see if it goes down or you see fuel run out of front of carb
38racing is offline
post #11 of 11 Old 07-08-2012, 01:46 PM Thread Starter
flash5153's Avatar
Yes I did,,it all looked very clean. I run some carb cleaner and air through it anyhow.
I never thought of doing a bench test like that. It would be very easy to do,,I have a extra tank there just for this type thing. Usually I eliminate the tank on a tractor ,I buy, with my own tank. (fresh gas to test a engine.)
