25cc Piston Installation - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Small Engines and Repair
Midwest Mower Pro
post #1 of 9 Old 07-05-2012, 02:11 PM Thread Starter
I'm replacing a piston in a leaf blower and the new piston is marked with a black dot (and also a dimple) which kinda tells me it wants to go in one way, mark toward the flywheel or mark away from the flywheel. Sorry, I didn't note the way it came out. Anybody know which way it installs, or if it matters. Thanks for your help.
Dave M is offline
post #2 of 9 Old 07-05-2012, 06:07 PM
Certified Technician
RED-85-Z51's Avatar
Images: 7
Re: 25cc Piston Installation
Whats it off of?
And it definitely matters. Piston rings on 2 strokes are pinned in so they can spin, so the piston needs to assemble in such a way that the end gaps do not catch either of the ports.
Generally, a mark would coincide with the exhaust port on the head. Or with the flywheel side of the engine, but not all.
1993 Wheel Horse 416-H
Onan P216G
1962 WH702
1997 K3500 Dually Sierra
1995 K3500 Silverado
TBI 454
1995 K2500 Silverado
6.5 Detroit Turbo Diesel
1994 GMC Sierra Z71
350 TBI
RED-85-Z51 is offline
post #3 of 9 Old 07-05-2012, 06:23 PM Thread Starter
Thank you for the response; This is a Poulan Pro BMV200VS leaf blower. Piston # is 545081864 which I think might be used on Weedeater and/or Craftsman brands with a 25cc motors. There is also a a small arrowhead stamped on the bottom of the piston on the wrist pin casting, pointing away from the connecting rod. The ring is indeed pinned and also has a white marking on it that I can view through the intake or exhaust port, depending on which way I install the piston. Does that help to determine the way the piston installs? Did you mean to say that the ring is pinned so it can't spin? Thank you again for your wisdom.
Dave M is offline
post #4 of 9 Old 07-05-2012, 06:53 PM
Just look to see which way the ring ends wont be at one of the ports.
3x Honda 4514, 2x Honda HT3813
2X JD L130, LX178
Roper YT16 Hydro,
Kubota G4200hst
Kubota B7100D
2X Kubota G5200HST
Cub Cadet 2518
Sears craftsman DGT6000
markusedma is offline
post #5 of 9 Old 07-05-2012, 08:27 PM
RED-85-Z51's Avatar
Images: 7
Right, pinned so the CANT spin, my bad.
When the white mark is viewed from the exhaust port, where is the mark on the top of thep iston?
Onan P216G
1962 WH702
TBI 454
1994 GMC Sierra Z71
350 TBI
post #6 of 9 Old 07-05-2012, 10:03 PM Thread Starter
When the white mark on the ring is viewed in the exhaust port, the dimple on the piston and the black (paint) mark on the top of the piston are facing the flywheel. That's the way I put it together, but I haven't tried to fire it up yet.
Dave M is offline
post #7 of 9 Old 07-12-2012, 10:41 PM Thread Starter
I didn't hear from anybody, so I thought I must have assembled this piston correctly in the motor. Fired it up and after it warmed, seemed to run okay. Fired it up today, and, not so good. Sounds like something ain't right, like a busted ring. It'll be a week before I can tear it back down, just to see what went wrong, but if I had to guess, I'd say I installed the piston backwards. Totally my fault for not noting the way the original piston came out. But, for sure, I'm not redoing this project. Shoulda just bought a new blower at the git-go. Education is a wonderful, albeit at times, an expensive thing.
Dave M is offline
post #8 of 9 Old 07-13-2012, 02:41 AM
RED-85-Z51's Avatar
Images: 7
it should be right, its how I would have assembled it, if I wasnt the one that disassembled it.
If there were a problem, id think you would have known there was a problem the first time it turned over.
Does it still have compression?
Onan P216G
1962 WH702
TBI 454
1994 GMC Sierra Z71
350 TBI
post #9 of 9 Old 07-13-2012, 09:35 PM Thread Starter
Thank you, Red. I appreciate you staying with me on this motor, but it's not like I did this to the Onan in the 316, or the Kohler Magnum in the Horse. Anyway, I'm away for a week, so until I get home, I won't know if has compression or what the issue might be. I'll definitely tear it back down just to see what's what. I'm just not gonna throw any more dough at it, that's all. I know you are the guru here, and I've seen a lot of guys give you well deserved accolades. You have my respect as well. Thank you again for taking time to respond and for your help.
Dave M is offline
