5 hp briggs engine ,tiller with reverse. - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Small Engines and Repair
Midwest Mower Pro
post #1 of 43 Old 06-03-2012, 10:41 PM Thread Starter
flash5153's Avatar
Had someone drop this off today with a big hole in the block. Ask me to buy a replacement engine and change it.
B&S 5 HP: 135292 025401
I figured it would not be a problem until I realized it has reverse via the cam. And when I started searching on the web for a replacement.
I have been having trouble lately with finding things I need. Or maybe its what I am working on.lol
I can't find a replacement engine.
Anyone have one?? Or know where I can get one.? A bigger engine that mounts up would work too.
I may have to eliminate reverse on this tiller.(gives me many more options)
flash5153 is offline
post #2 of 43 Old 06-03-2012, 10:51 PM
Senior MTF Poster
Re: 5 hp briggs engine ,tiller with reverse.
I doubt you will find a replacement, I am pretty sure they were discontinued probably quite awhile ago. I need three of them right now myself. MIGHT want to think about modifying a std. block and using the camshaft from the original IF it is OK.
Walt Conner
Walt 2002 is offline
post #3 of 43 Old 06-03-2012, 10:57 PM
Certified Technician
RED-85-Z51's Avatar
Images: 7
They dont exist, Briggs made a drop in INTEK replacment, but they only made them for a short period...and didnt make near enough.
1993 Wheel Horse 416-H
Onan P216G
1962 WH702
1997 K3500 Dually Sierra
1995 K3500 Silverado
TBI 454
1995 K2500 Silverado
6.5 Detroit Turbo Diesel
1994 GMC Sierra Z71
350 TBI
RED-85-Z51 is offline
post #4 of 43 Old 06-03-2012, 10:59 PM
Snowblowers and tillers that's all I can think of that use Cam pulley. you'll need a good donor and swap the case end from the blown engine or a block and rebuild what's there, providing it's all good.. Beyond that, reject the work or inform them reverse won't work after re-power.
matt167 is offline
post #5 of 43 Old 06-04-2012, 10:51 AM
I know just what you are going through I have a tec 3.5 and a B&S2.5 Im trying to locate motors with cam reverse, been weeks and still no go. ED
eedowens is offline
post #6 of 43 Old 06-04-2012, 11:12 AM Thread Starter
flash5153's Avatar
Well. hmm?
I can't get a replacement ,,that's a sure thing. But I do have ,almost,the same engine mounted on another tiller. It has no reverse cam drive.
I thinking I can change the cover and cam ,,and it will work. Am I correct???
I need to figure out if the cam is good in this engine,,or ,,is the cam available for parts,,,new???? Has anyone looked for that??
If I go a different way,,and eliminate reverse. Is there any engines available in a bigger size??? maybe a 8hp or so??? Will just about any horizontal shaft engine work???
post #7 of 43 Old 06-04-2012, 11:48 AM
jdrobison's Avatar
Post Re: 5 hp briggs engine ,tiller with reverse.
try this place.
http://www.brandnewengines.com/12S492-0070.aspx
1811 cub
1720 cub
147 cub
102 cub
soon a 214 JD
2 Farmall regulars
1928 & 1929
Farmall M
jdrobison is offline
post #8 of 43 Old 06-04-2012, 11:56 AM
jdrobison's Avatar
i called and they are in stock
1811 cub
1720 cub
147 cub
102 cub
soon a 214 JD
2 Farmall regulars
1928 & 1929
Farmall M
post #9 of 43 Old 06-04-2012, 12:12 PM
RED-85-Z51's Avatar
Images: 7
Id toss a 6.5 clone on it...will bolt up to the frame fine, measure from the crank, to the mounting surface on the new engine and the old engine...space the new engine up as required, briggs, hondas, clones, tecumsehs...generally all had lower crank centerlines than their Flathead predecessors.
Onan P216G
1962 WH702
TBI 454
1994 GMC Sierra Z71
350 TBI
post #10 of 43 Old 06-04-2012, 10:14 PM
Senior MTF Poster
"I thinking I can change the cover and cam ,,and it will work. Am I correct???"
There you go - just as I said.
Walt Conner
post #11 of 43 Old 06-05-2012, 12:22 AM Thread Starter
flash5153's Avatar
Walt Conner
Well if that works,,and I believe what you say,,and it will.
I could do that and sacrifice my engine for this tiller. And I could figure in the cost to buy me a replacement engine for my tiller. I'm thinking I can pick one up for $100-$150, Seems someone just has a post on here about it,,the same engine. And HF had one for $99. I went back to look and I can't find that post.
post #12 of 43 Old 06-05-2012, 06:00 AM
I had the $100 engine coupon in my Email but accidentally deleted it ( whole super coupon flyer ). It was valid thru this month.. you can find the coupons on Ebay, otherwise the super coupon will still be on the Harbor Freight website if you can find it, But I havn't been able to find it, only an expired coupon for $109 which I found in my browser history.
matt167 is offline
post #13 of 43 Old 06-05-2012, 06:40 AM Thread Starter
flash5153's Avatar
Is this engine worth having?? And how does it compare to a 5 hp as far as power? 212 cc???
http://www.harborfreight.com/predato...nia-68120.html
I now have permission from the owner of this tiller to eliminate reverse. So my options just got much bigger for a replacement . I think I want something bigger.
post #14 of 43 Old 06-05-2012, 06:48 AM Thread Starter
flash5153's Avatar
I am now looking for a engine that will NOT (have to)provide reverse for this tiller. And I would like to use a bigger engine. I want a new engine also. Do you know of a place that I can buy what you suggest???
Does harbor freight stock these?? I would rather not have to pay for shipping. But will if no choice.
I don't buy many "new" engines. lol And not sure what one looks like.
post #15 of 43 Old 06-05-2012, 09:49 AM
The 196-200cc Honda clones were rated at 6.5 HP, the 212cc are sometimes rated as high as 7hp, but Harbor Freight gives no rating.. I have 2 of these 212cc Predators and for the $100 they cost, there great. I would not buy 1 at full $179 price tho. Even a genuine Honda GX200 would do great and still make a very affordable repower.
matt167 is offline
