rebuilding 17.5 B&S - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Small Engines and Repair
Midwest Mower Pro
post #1 of 23 Old 04-25-2012, 12:11 PM Thread Starter
speedybmc's Avatar
rebuilding 17.5 B&S
I was given an craftsman mower with a 17.5hp single cylinder briggs and stratton. When i got the mower (last year) the engine was smoking a little. I ran it until now always checking the oil and adding if needed. Well this year it is a little worse and i want to overhaul it. I removed it from the mower and started tearing it down. I took the valves out and removed the old valve seal. Now, i don't know anything about a small engine but are the valves supposed to have slight play in them from side to side? With me holding the valves in and open just slightly i can wiggle them. Its not much but there is slight play in them. In other words they are not tight with in the valve guide. If this is ok and doesn't cause any problems i wont worry with it and continue the build.
What do i need to do to get the carbon build up from off the piston and around the valves/combustion chamber? I've heard things from oven cleaner to a wire brush. i don't want to do anything that'll hurt it.
I have not got to the bottom end yet so there may be more question on the way.
Thanks for all of your help
speedybmc is offline
post #2 of 23 Old 04-25-2012, 03:47 PM
Certified Technician
RED-85-Z51's Avatar
Images: 7
Re: rebuilding 17.5 B&S
I dont have the specs in front of me, but the valves shouldnt be sloppy in the guides.
I take some oil, and lube the stems, stick them in the guides until they are flush with the top of the guide, and seal off the other end with my finger, and pull the valve out...it should make a little suction as you pull it out.
1993 Wheel Horse 416-H
Onan P216G
1962 WH702
1997 K3500 Dually Sierra
1995 K3500 Silverado
TBI 454
1995 K2500 Silverado
6.5 Detroit Turbo Diesel
1994 GMC Sierra Z71
350 TBI
RED-85-Z51 is offline
post #3 of 23 Old 04-25-2012, 03:59 PM Thread Starter
speedybmc's Avatar
Ok i have the head with me so i'll go try that out now. Thanks
EDIT:There is a little suction when i pull it. Not alot but enough to tell it has some.
post #4 of 23 Old 04-25-2012, 06:36 PM
Senior MTF Poster
I have a Service Manual for your engine IF you would like a PDF copy. Address below, put in proper format and remind me, model number of engine and what you want. I think you will find that B&S has a go-no go Gage to check the valve guide but no specs. and the fix is a new head.
Walt Conner
wconner5 at fronter dot com
Walt 2002 is offline
post #5 of 23 Old 04-25-2012, 07:27 PM
RED-85-Z51's Avatar
Images: 7
I think Ive seen that gauge before Walt, I think its tapered with markings on it, and there is a line that if it is at or past that line, its too big, replace the head, or ream/replace the guide.
If its got some suction, its probably not an immediate problem, ive pulled apart high hours engines with the valves wobbling all over, but ran fine, no smoke or problems....but the guides were completely shot to **** and back. Eventually, if it gets bad enough, the valve wont seat and it will burn.
Onan P216G
1962 WH702
TBI 454
1994 GMC Sierra Z71
350 TBI
post #6 of 23 Old 04-25-2012, 11:19 PM
Senior MTF Poster
I don't worry about a little play and seldom replace valve guides. I do not believe valve guides are available for this engine, I think B&S says not replaceable.
Walt Conner
post #7 of 23 Old 04-25-2012, 11:39 PM Thread Starter
speedybmc's Avatar
Hmm thanks guys. i think I'm going to run it like they are and start saving up to get a head and valves.
Another question. Is there a way to get a little more hp out of these little engine? Like maybe porting the intake and exhaust port. A few guys i work with was wanting to do it for me and i noticed there is a slight lip of excess cast around the inside diameter of the intake port. Would porting it hurt it more than help? They just put the bug in my ear and i was curious if i could gain a little more horses out of it while i had it tore down waiting on parts.
post #8 of 23 Old 04-25-2012, 11:44 PM Thread Starter
speedybmc's Avatar
Walt Conner
Yeah they're not available. They just offer the head and valves.
post #9 of 23 Old 04-26-2012, 12:00 AM
Onan18's Avatar
BUT, a GOOD machine shop can make a set and shoulder them so they won't pull out of the head, a common problem on this series engine. I believe my machinist took a set for a Perkins and turned them down then reamed the inside and installed a liner to bring it into spec.
Joe
Onan18 is online now
post #10 of 23 Old 04-26-2012, 12:32 AM
RED-85-Z51's Avatar
Images: 7
Porting really helps to allow more flow at high rpms..but these are governed engines. At full speed no load, the carb is only opening about 10% tops...and even under 100% load, the engine speed doesnt exceed 3600rpms...so porting really would not help much if anything, as the engine cant demand more air.
If it were an ungoverned engine, on a racing mower that was going to be turned up to 5000, 6000 rpms...and it was built to handle it, Port away and put in bigger valves, roller rockers, slapper cam, etc...haha
Onan P216G
1962 WH702
TBI 454
1994 GMC Sierra Z71
350 TBI
post #11 of 23 Old 04-26-2012, 12:38 AM Thread Starter
speedybmc's Avatar
I see. Well i wont be doing any racing anytime soon (not on my mower anyway haha) so i'll keep it the way it is. Thank you all for all of your information.
post #12 of 23 Old 04-26-2012, 07:17 AM
daytona54's Avatar
might want to hone your cylinder and replace the rings speedybmc if your going that deep into the engine ( worn rings will make your engine smoke ) and connecting rod bearings as there not costly..........how bout some pic's of your rebuild,We love them here............
daytona54 is offline
post #13 of 23 Old 04-26-2012, 08:52 AM
Senior MTF Poster
" and connecting rod bearings "
Well that would be the entire connecting rod as there are no "bearings". $30 - $35.
Walt Conner
post #14 of 23 Old 04-26-2012, 05:21 PM Thread Starter
speedybmc's Avatar
There were no bearings on the rod. But it was in good shape along with the rings. The culprit causing the smoke was a blown head gasket and possible the valves. it was sucking oil from the push rod valley. Everything else except the valves was in good shape.
post #15 of 23 Old 04-26-2012, 06:36 PM
daytona54's Avatar
My bad about the 'connecting rod bearings' sorry to mis-inform you
hope the re-build go's well....
Daytona
