OHV briggs hard to turn over - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Small Engines and Repair
Midwest Mower Pro
post #1 of 10 Old 04-13-2012, 01:52 AM Thread Starter
Packrat's Avatar
I got a push mower with a 6.5hp ohv briggs. I was told its hard to turn over. I adjusted the valves to specs, easier to pull but still harder than it should be. If I rotate the engine by the blade, it turns easy, but use the pull rope while its on the compression stroke, and it almost feels like its jammed. Sometimes it will pull over normal, but it's unpredictable. Any ideas? The model # is 121601
1984 Craftsman GT6000 with snowblower - Got it free
1966 Snowbird S-228 - Got it free
1971 Homelite S-8 - paid $30
Packrat is offline
post #2 of 10 Old 04-13-2012, 08:00 AM
daytona54's Avatar
Re: OHV briggs hard to turn over
did you adjust your valves at top dead center and on compression stroke ?........if so make sure your flywheel to engine shaft 'key' is not sheared,that would be the first thing i would check after valves adjusted.let us know about the key........i will continue to check back on your post to further assist.
daytona54 is offline
post #3 of 10 Old 04-13-2012, 09:15 AM
should be 1/4" past top dead centre
38racing is offline
post #4 of 10 Old 04-13-2012, 10:30 AM
daytona54's Avatar
right you are 38racing...........I'd also check to see that the valves are seating properly
post #5 of 10 Old 04-13-2012, 10:47 AM
Certified Technician
RED-85-Z51's Avatar
Images: 7
Make sure the blade is the right length, a short or worn blade lacks the inertia to help pass the engine through compression stroke.
1993 Wheel Horse 416-H
Onan P216G
1962 WH702
1997 K3500 Dually Sierra
1995 K3500 Silverado
TBI 454
1995 K2500 Silverado
6.5 Detroit Turbo Diesel
1994 GMC Sierra Z71
350 TBI
RED-85-Z51 is offline
post #6 of 10 Old 04-13-2012, 10:47 AM
RED-85-Z51's Avatar
Images: 7
Also be sure the brake is fully releasing on the flywheel, if its dragging intermittently, it will make pulling the rope ****.
Onan P216G
1962 WH702
TBI 454
1994 GMC Sierra Z71
350 TBI
post #7 of 10 Old 04-13-2012, 11:13 AM
Remove the valve cover (and spark plug wire!) and slowly turn the engine over with the blade. Watch the valves on the compression stroke for operation of the compression release. If you don't see it, it may need a new camshaft, or possibly just the spring on the compression release weight reconnected.
I once had a new Ryan LawnAireIV aerator with a 3.5HP Industrial Plus on it, it could rip the starter grip right out of your hand. All it was was the spring on the camshaft was not connected.
rscurtis is offline
post #8 of 10 Old 04-13-2012, 03:23 PM Thread Starter
Packrat's Avatar
Yep. I don't think the key is sheared. It will start and run normally, just hard to pull.
Valves seem to seat ok. I had the head off to clean off any excess carbon build up. While it was off, I pushed on the valves to make sure they didn't sticking. They move freely and valve seat looks clean.
Yeah looked for that. Didn't see it, but I'm not sure if it has a ACR or not. If it does, its not working. Was the spring damaged?
Packrat is offline
post #9 of 10 Old 04-13-2012, 08:10 PM
Fairway's Avatar
I would venture to guess that he mechanical compression release is busted.
Ariens 924073
Ariens 10M6D
1972 Ariens Fairway 912003 RER.
1986 Toro 11/32 56170 RER.
Tecumseh TVM195
Tecumseh LH195SP
Tecumseh H60
Tecumseh HSK70
Tecumseh HMSK90
Tecumseh HM100
Tecumseh HMSK100
Briggs & Stratton 130202
Briggs & Stratton 190412
Subaru SP170
Fairway is offline
post #10 of 10 Old 04-13-2012, 08:38 PM
The spring was not damaged, just not connected when the engine was assembled. Never had a problem with it again.
rscurtis is offline
