5hp vertical briggs runs too fast - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Small Engines and Repair
Midwest Mower Pro
post #1 of 5 Old 04-11-2012, 06:06 PM Thread Starter
Hello all, my 1969 5hp briggs and stratton runs at very high rpm once started. The linkage is very simple. Spring from throttle to governor and linkage from governor arm to butterfly. I have a service manual for the new l-heads but I can't find this simple(old?) a linkage pictured. I want to be able to control how high the motor revs. Any suggestions?
luckylulujoe13 is offline
post #2 of 5 Old 04-12-2012, 11:17 AM
Re: 5hp vertical briggs runs too fast
The spring wants to open the throttle wide, and the governor linkage wants to close the throttle to limit rpms. The spring is normally on the butterfly, as is the governor 'rod'.
As the load increases, the rpms will start to drop, and the governor pulls on the throttle a little bit less. The spring tries to open the throttle butterfly more, to increase power, and will do so, until the governor pulls it closed again. If the load decreases, the governor will pull harder as the rpms start to climb, and will pull the throttle plate towards 'closed'.
If your governor is not pulling the butterfly closed, either the linkage is binding, or broken, or the governor has either come apart internally, or the governor arm is loose on the shaft coming out of the crankcase, and has become mis-adjusted.
tom
tomw0 is offline
post #3 of 5 Old 04-12-2012, 02:27 PM Thread Starter
I put this together from a box, but I think it goes like this. Please see pic. Look right?
So, I've also messed with the governor linkage. I loosened the arm and turned the rod a bit counter clockwise and tightened it again. The governor seems to be working OK. When I engage the blade and mow up a hill the motor increases rpm when it bogs and goes up the hill just fine.
The problem is more like the throttle is not sensitive enough. I can't get the mower to go medium or slow. It wants to run at high rpm or hits the kill switch by the time I get it down to a reasonable rpm. The throttle assembly is all original and moves smoothly from choke to kill.
ID:	208136   Click image for larger version
post #4 of 5 Old 04-14-2012, 11:38 PM
walfish's Avatar
From the pic, it looks like the idle screw is cranked in all the way and not allowing the butterfly to close down to a slower speed
walfish is offline
post #5 of 5 Old 04-14-2012, 11:44 PM Thread Starter
Doh!!! I'll give it a try. Thanks.
