14hp kohler hard to turn over - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Small Engines and Repair
Midwest Mower Pro
post #1 of 11 Old 01-07-2012, 09:17 PM Thread Starter
Packrat's Avatar
A friend of mine is having trouble with his riding mower. He got it about 6 months ago, was running and starting fine. Last week he goe's to start it after letting it sit for a month. Didn't want to turn over so he pulls the plug, it turned over but was stiff. After cranking it a while with no spark plug it loosened up a bit. He put the plug back in and got it running. Now it starts and runs fine when warm but when its cold, it has a hard time turning over. Any thoughts about what may be the problem? The battery is good. Starter appears to be ok. I think the model of the engine is a K321. Any ideas as to what the problem might be?
1984 Craftsman GT6000 with snowblower - Got it free
1966 Snowbird S-228 - Got it free
1971 Homelite S-8 - paid $30
Packrat is offline
post #2 of 11 Old 01-07-2012, 10:01 PM
larrybl's Avatar
Images: 32
Re: 14hp kohler hard to turn over
Change the oil and spark plug, New Battery, Adjust the points.
1990 18.5 Craftsman (RED)
1978 Roper 20T (Old Girl)
[/url]
larrybl is offline
post #3 of 11 Old 01-07-2012, 11:31 PM Thread Starter
Packrat's Avatar
I don't know about the plug and points, but I know the oil is fresh and the battery is good(starts all his other riders no problem) Should be turning over easy seeing how most of the older kohlers had a ACR
Packrat is offline
post #4 of 11 Old 01-07-2012, 11:37 PM
larrybl's Avatar
Images: 32
My K321 has an ACR, but beats me on how to trouble shoot it, as mine is working I will follow this thred for future reference.
http://www.mytractorforum.com/showthread.php?t=699657
[/url]
larrybl is offline
post #5 of 11 Old 01-08-2012, 03:56 AM
Certified Technician
RED-85-Z51's Avatar
Images: 7
Is there PTO dragging at all? If its a Hydro..cold hydro fluid is thick and if the pump is not perfectly in neutral it can drag the starter down.
1993 Wheel Horse 416-H
Onan P216G
1962 WH702
1997 K3500 Dually Sierra
1995 K3500 Silverado
TBI 454
1995 K2500 Silverado
6.5 Detroit Turbo Diesel
1994 GMC Sierra Z71
350 TBI
RED-85-Z51 is offline
post #6 of 11 Old 01-08-2012, 04:01 PM Thread Starter
Packrat's Avatar
Nothing is hooked to the pto so I don't think its dragging, but it is hydro so maybe thats causing the problem.
Packrat is offline
post #7 of 11 Old 01-08-2012, 08:05 PM
RED-85-Z51's Avatar
Images: 7
How hard would it be to disconnect the hydro?
Onan P216G
1962 WH702
TBI 454
1994 GMC Sierra Z71
350 TBI
post #8 of 11 Old 01-08-2012, 09:00 PM
caseguy's Avatar
If youve done all the tune up stuff , check the valve clearance. The arc run off the cam and if the clearance is to large it wont open the valve enough. If you think yopu have a issue you can pull the head and watch or measure the opening .. check the book. if you have points make sure they are good shape ..
caseguy is offline
post #9 of 11 Old 01-08-2012, 09:04 PM
poncho62's Avatar
Images: 7
Brushes or bearing in the starter may be worn......
Ford LGT100
Ford LGT125
Ford LGT145(sold)
Ford LGT165
John Deere STX38
Ontario Rodders
poncho62 is offline
post #10 of 11 Old 01-08-2012, 09:18 PM
10K and Climbin!
WNYTractorTinkerer's Avatar
Images: 14
Question Re: 14hp kohler hard to turn over
Main battery cable conections clean & tight??
[URL="https://www.youtube.com/watch?v=o9Or4QGI80Y"]Can You see the Real me?
WNYTractorTinkerer is offline
post #11 of 11 Old 01-08-2012, 09:30 PM
You could also try jumping it directly to the starter, I presume. That might help you rule out some wiring issues.
If it turns over slowly even with the plug removed, that would make me suspect either a problem with the starter, or some sort of parasitic drag, like RED-85-Z51 mentioned. For that matter, with the plug removed, how does it rotate if you try to turn the engine by hand?
RedOctobyr is offline
