Honda GX340/390 Oil Drain - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Small Engines and Repair
Midwest Mower Pro
post #1 of 8 Old 10-28-2011, 09:42 PM Thread Starter
Hello I have a Honda GX390 and a GX340 both, mounted on a trailer floor and very difficult to remove. I need to change the oil on them but there is no way to remove the drain plug and drain the oil without it draining all over the trailer floor. On my Kohler and ALL my Briggs engines, I can use regular NPT pipe nipples to extend the oil drain out to where I can use it correctly, but on the hondas I believe the oil drains are 10MM. I am not aware of any place atleast around here that sells a 10mm pipe nipple and cap/plug. I have seen some of those quick drain things that extend the oil drain out for these things, but I dont think they are long enough.
What should I do? Or does anyone know where I can buy 10mm pipe?
Torque454 is offline
post #2 of 8 Old 10-28-2011, 11:22 PM
Certified Technician
RED-85-Z51's Avatar
Images: 7
Re: Honda GX340/390 Oil Drain
Easiest way is to use a simple hand oil pump. Take off the filler, put the straw in the sump, pump a few times to build vacuum and let it lift the oil, cleanly into the hopper...no mess, no fuss
1993 Wheel Horse 416-H
Onan P216G
1962 WH702
1997 K3500 Dually Sierra
1995 K3500 Silverado
TBI 454
1995 K2500 Silverado
6.5 Detroit Turbo Diesel
1994 GMC Sierra Z71
350 TBI
RED-85-Z51 is offline
post #3 of 8 Old 10-28-2011, 11:27 PM
Go to Northern Tool, get the 10mm Drainzit...
http://www.northerntool.com/shop/too...1063_200311063
I put one on my Honda clone on my blower... Makes it nice and mess free.
If its not long enough its a standard automotive grade GoodYear rubber hose, you could easily cut and splice with some barbed fittings and more hose and make it whatever length you want.
kb0nly is offline
post #4 of 8 Old 10-29-2011, 01:37 PM
I used a lot of them on my rental equipment right from brand new. If the oil is easy to change, you'll be more inclined to do it.
rscurtis is offline
post #5 of 8 Old 10-29-2011, 04:03 PM
RED-85-Z51's Avatar
Images: 7
If the motors are mounted flush to the trailer floor, I dont think you can use a Quick drain type device. Could always put some washers under it though.
Onan P216G
1962 WH702
TBI 454
1994 GMC Sierra Z71
350 TBI
post #6 of 8 Old 10-29-2011, 06:48 PM
They were installable on flush-mounted engines without removing the engine. That's one of the things that made them so attractive.
rscurtis is offline
post #7 of 8 Old 10-29-2011, 08:19 PM
RED-85-Z51's Avatar
Images: 7
Personally I liked em, but I saw alot of blown engines from people not returning them to the closed position securely. And I never saw one on a flush mounted application I could get to to install. It was such a pain when Id short block an engine on a Z mower and forget to swap the drain and have to unbolt the engine, put a jack under the crank to lift it up a hair so I could spin on the ez drain.
Onan P216G
1962 WH702
TBI 454
1994 GMC Sierra Z71
350 TBI
post #8 of 8 Old 10-30-2011, 02:28 AM
The Drainzit is not a quick drain with a valve or such... It has a threaded fitting on the end and a cap with an o-ring. I wouldn't put one of those quick drain valve type devices on i don't trust them, but i know some swear by them.
The Drainzit doesn't take any more room than the stock drain plug, so it can go on an engine that is flush mounted onto a surface. Just spin it in like a drain plug, i didn't need to move the engine on my snowblower just pulled the plug, drained the oil, cleaned up the mess, then spun in the Drainzit hose and done. No problemo!
kb0nly is offline
