My next task,,Toro 421,,anyone know what motor this is??Pics. - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Small Engines and Repair
Midwest Mower Pro
post #1 of 22 Old 07-15-2011, 10:19 PM Thread Starter
flash5153's Avatar
It a older model,,lol. It runs and I used it last winter. It needs a tune-up and the carb cleaned /adjusted. It has no tags,,,,I'm not sure what size /make motor this is,,,anyone???
Also any info on this would be helpful. It seems to surge when running,,might not be getting enough gas. I'm going to tear it apart ,,clean it and check gaskets.
In the drive trans,,in picture,,,there is a plug for draining. What oil is in that??? Should I change it??
ID:	165910   Click image for larger version
ID:	165911   Click image for larger version
flash5153 is offline
post #2 of 22 Old 07-15-2011, 11:24 PM
Re: My next task,,Toro 421,,anyone know what motor this is??Pics.
Tecumseh HS40 was OE.
oldebonnie is offline
post #3 of 22 Old 07-15-2011, 11:52 PM Thread Starter
flash5153's Avatar
I just found some videos on U-tube showing a few of these all cleaned up ,,restored.
It said they are the 1981 model,,,, 4 hp motor with a 21 inch wide cut path. 421 Toro!! These things will really blow some snow!!! It's a 2 stage with 3 speed drive.
I am having a problem with the govener kicking in while idling. Making the engine rev up and down. I don't know why it does this.
post #4 of 22 Old 07-16-2011, 12:58 PM
Shryp's Avatar
I had a Toro 3521. Same machine, but mine had a Tecumseh H35 engine. But then I switched it out for a Harbor Freight 6.5 HP Greyhound
Mine just had grease in the front gearbox, no idea what was suppose to be there though. I sold it and upgraded to a bigger Ariens.
Shryp is offline
post #5 of 22 Old 07-16-2011, 01:26 PM Thread Starter
flash5153's Avatar
I see the tag on yours,,,I didn't realize it was there. Without going out to look I can scroll up and see in my picture that there is a tag on mine too.
I will punch the numbers in and see if I can come up with a manual or some info. on it.
If I can get this thing running perfect. I might just clean er up and throw a little paint on it.
post #6 of 22 Old 07-16-2011, 03:05 PM
Shryp's Avatar
If you check the top of the engine on the flat spot right by the spark plug you should see the engine numbers too. You will probably need some sand paper or a wire brush to knock the rust off.
Shryp is offline
post #7 of 22 Old 07-16-2011, 03:44 PM Thread Starter
flash5153's Avatar
I put my numbers into a search. It took me toro .com where they say you can download a manual. But I can't figure out how. Model: 38010 is there though.
Shryp: That is a good looking machine,,,it amazing how well these things blow snow,,for a 30 year old unit like mine.
I saved it from the scrap yard 2 years ago. A friend of mine was on his way,,had it loaded . I seen it and gave him $10 for it. I cleaned the carb ,put some gas in it and it started right up. Used it last year but noticed it still runs a little rough.
I figure it worth putting some time into it. Do a little maintenance which I don't think it has ever had. I can do all that without a manual,,but it would be nice to have one!! lol
post #8 of 22 Old 07-16-2011, 04:33 PM
Flash, I have a 421 too. Very well built, and powerful enough because it isn't too wide. The narrower two-stage fits my needs, because I have some narrow sidewalks and a couple of gravel drives.
I have been looking for a Toro shop manual for this model without success for a couple of years. Plenty of info is available on the engine.
Shryp, how involved was the engine swap? I presume the new engine has two ptos in roughly the same places as the HS40 and spinning the same directions?
post #9 of 22 Old 07-16-2011, 04:51 PM
Shryp's Avatar
My 3521 had a single shaft engine on it. The Greyhound was an exact replacement. The mounting holes, pulley and belts were same as the old ones. The only modifications I needed were a new bolt to hold the crankshaft pulley and the 2x4 spacer for the crank chute.
For the manual:
go to http://toro.com
click the homeowner link
bottom left second section click on owners manuals
type 38010 into the product search box
that should give you 3 choices based on year / serial
<hmm this works with firefox, but on chrome clicking the links does nothing?>
click your serial number
looks like the 1981 manual is the only one available for download
click on the manuals button and then the operators manual is available
Shryp is offline
post #10 of 22 Old 07-16-2011, 10:18 PM Thread Starter
flash5153's Avatar
I tore it apart today. The gas line,that runs through the middle of the motor,,needs to be replaced. I found a bearing ,for shaft to front gear box ,,is gone!!! The bearing is just inside the pulley,,I have to remove the pulley from shaft to get to it. Its going to be tough.
The whole front shaft is just flopping around because that bearing is not just worn,,but literally gone!!
I really wasn't planning on tearing it apart this far,,but,,,,hmmm,,I'm going to paint it up while it is apart.
Going to get some Toro red tomorrow,,and figure out how I'm going to get that pulley off there. I have no idea where I'm going to get the new bearing,,but I will figure it out when I get it apart.
ID:	166055   Click image for larger version
ID:	166056   Click image for larger version
post #11 of 22 Old 07-16-2011, 10:20 PM Thread Starter
flash5153's Avatar
Here's the pulley and the bearing,,the best I can take a picture of it.
ID:	166058   Click image for larger version
post #12 of 22 Old 07-16-2011, 11:01 PM
Shryp's Avatar
Here is how to change the bearing on a 5/24
http://www.youtube.com/watch?v=UU0aNSn_2Bs
Shryp is offline
post #13 of 22 Old 07-16-2011, 11:28 PM Thread Starter
flash5153's Avatar
Cool,,,,,I know what I'm in for. All though a different model,,it looks the same to me. Hopefully i can find a Toro parts dealer around me for the bushing.
post #14 of 22 Old 07-18-2011, 01:05 AM Thread Starter
flash5153's Avatar
Well because of the weekend I have not got parts yet. And I have not removed the pulley. Its on there good. All I have is a propane torch,,its not enough heat to get er done.
Tomorrow I will get the pulley off and get the bushing. But I have sanded and taped everything else off for a new paint job. Except the auger and assembly,,I'll save that till I fix it.
My restoration is going to OK,,,not professional but not bad. I looked up Toro red paint ,,and I see it has changed over the years,,,they bought wheel horse and I think are the same colors now.
I'm buying paint tomorrow too,,hope I can find the right color for this year!! 1980,,lol!!
When tearing something like this apart,,it cool to be able to see exactly how it all works. If it ever breaks,,I will know what has happened,,or at least have a very good idea.
Hope I'm not boring you all. I should have it done by the end of the week.
post #15 of 22 Old 07-19-2011, 10:27 PM Thread Starter
flash5153's Avatar
I can't get this pulley off. I have beat it up pretty bad. I was about to cut it off and just buy another,,but just looked at the price of a new one!! $94!!! yikes!!
Any ideas on how to get it off??? Pictures of it above^ I cut some boards on an extreme angle ,,and wedged them under pulley on each side.4 total coming from each side overlapping each other to force pulley up.. Then heated it with propane torch(all I have) and put large solid pipe(pointed) on shaft and hit it. It won't budge. But bent the pulley a little.
I know I need more heat,,that's next !!
I have a bushing on order, but have finished everything else. Just waiting on that part and getting this pulley off.
I rebuilt the carb,,new gas line ,,and changed oil. I found some problems in the carb,,,it runs great now!!! Got er painted up all nice and perty!!
ID:	166599   Click image for larger version
ID:	166600   Click image for larger version
