B&S keeps breaking flywheel key?????? - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Small Engines and Repair
Midwest Mower Pro
post #1 of 7 Old 06-11-2011, 12:40 AM Thread Starter
Hi all,
I have a Craftsman riding mower with a 16.5 horse Briggs and Stratton 31H777-0202-E1 030215za engine on it.
It broke a rod which we have replaced, everyting else looks good.
Problem is, now it keeps breaking the flywheel key. We thought maybe it was the valves but they have been adjusted and the key still breaks.
What could this be? The torque on the flywheel nut? How tight should it be? Or is there something else that could likely cause this?
Thanks in advance,
Dan
danriis is offline
post #2 of 7 Old 06-11-2011, 06:37 AM
Re: B&S keeps breaking flywheel key??????
Flywheel Nut torque spec is 100 ft/lbs. Make sure the crank and the flywheel taper are clean and dry.
Dave
DLF_IN is offline
post #3 of 7 Old 06-11-2011, 07:33 AM
k91
They shear pretty fast if they are not torqued down enough
k91 is offline
post #4 of 7 Old 06-11-2011, 08:47 AM
Senior MTF Poster
Dave
Many people make the mistake of thinking that the key is supposed to hold the flywheel from moving on the crankshaft. It is ONLY for positioning the flywheel on the crankshaft, the proper torque on the taper is what holds the flywheel.
Walt Conner
Walt 2002 is offline
post #5 of 7 Old 06-11-2011, 06:46 PM
4K Poster!!!
Fcubman's Avatar
Images: 5
If the nut torque is correct, you might want to lap the crank and flywheel together to make sure they are making good contact.
(Red Green)
Fcubman is online now
post #6 of 7 Old 06-12-2011, 02:32 AM Thread Starter
Now it will only run full throttle?
Thanks all, we tightened the flywheel and now it's not breaking the key, HOWEVER, for some odd reason it only will run at close to full throttle.
My friend and shade tree mechanic is working on it but is stumped.
According to him all the linkages to the throttle, governor etc etc look good.
What gives?
Thanks again!
danriis is offline
post #7 of 7 Old 06-12-2011, 10:44 AM
4K Poster!!!
Fcubman's Avatar
Images: 5
Have you tried running it with the choke partially closed? If it runs better, it's running lean. Try closing the choke varying amounts, see what happens.
(Red Green)
