Craftsman walk-behind won't stay running - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Small Engines and Repair
Midwest Mower Pro
post #1 of 8 Old 05-12-2011, 11:47 PM Thread Starter
KBrenz's Avatar
I have a craftsman walk-behind that will start fine but won't stay running. It has a new plug, air filter, and good gas in it. If you keep pushing the primer bulb it will run but will die if you don't push it for about a minute. Then when it does stay running it dies if you increase throttle. Is that just a fuel filter/delivery problem or is carb bad and need to be rebuilt. The motor is a 6.6hp model #143.976602 D.O.M. 7072K.
Life is hard, get a helmet!
JD STX38
KBrenz is offline
post #2 of 8 Old 05-13-2011, 05:16 PM
H-D
Re: Craftsman walk-behind won't stay running
An easy first try is to drain all the gas & refill with a mixture of SeaFoam & fresh gas at the recommended ratio. This could save you a carburetor rebuild. Older ethanol gas is only suitable for parts washing.
H-D is offline
post #3 of 8 Old 05-13-2011, 05:33 PM
I generally drop the float bowl when I have problems like you describe. Most times I have found gummy deposits in the bottom of the bowl. They can plug a pickup hole built into the side of the carburetor down in the float bowl, about the size of a small paperclip, or the pickup on the bottom of the boss that you screw the float bowl bolt into. The needle and seat can also get gummed up and then the fuel level will be too low in the carburetor, causing the engine to run poorly if at all. I would get some carburetor cleaner spray and make sure all the passages you can detect are clean. The fuel is drawn up the 'boss', and into an emulsion tube {a tube with holes in the sides} that mixes the liquid fuel with air drawn into the area to start to break the liquid up so it will get drawn into the intake as close to a gas as it can be made {cheaply..}. The whole thing can get gummed up, and you have to disassemble it to clean it. The symptoms make me think that the fuel is not getting into that area because of gum on the bottom or side hole blocking the flow. It is in the bowl, or the bulb would have no effect.
What you are doing with the primer bulb depends on the model. Some pressurize the float bowl, and force fuel through a passage up the the air filter and dribble fuel on the filter element. The older ones actually squirt fuel into the intake when the bulb is pressed.
tomw0 is offline
post #4 of 8 Old 05-14-2011, 06:36 AM Thread Starter
KBrenz's Avatar
HD, I already use sea-foam with my gas in everything. I have same gas in my rider and its running fine.
JD STX38
KBrenz is offline
post #5 of 8 Old 05-14-2011, 06:38 AM Thread Starter
KBrenz's Avatar
Tom thanks for the detailed info. I'll look into what you said the next few days after work and post if it doesn't help.
JD STX38
KBrenz is offline
post #6 of 8 Old 05-28-2011, 09:52 PM Thread Starter
KBrenz's Avatar
I pulled the bowl on the carb off and it was full of gas. I drained it out and sprayed carb cleaner in it and put it back together. Now I can get it to stay running with an occasional cough but the power is very lacking. Its like its on half throttle when its on full and barely running on minimun throttle. Any ideas?
JD STX38
KBrenz is offline
post #7 of 8 Old 05-28-2011, 10:22 PM
Pocketraisins's Avatar
Images: 3
I had a Poulan that did the same thing. I too dropped the bowl and hit it with carb cleaner and checked the float. I got a little gunk out of the bowl and blew out the orifice in the bowl nut. Still ran like junk.
I found out the primer bulb had a pinhole in it and was causing it to suck a little more air than it should and threw off the mixture and barely ran. It seemed fine when priming because my finger was over the hole and sealed it. I replaced the primer bulb and it ran like a champ!!
Just because my thought processes are different than yours DOESNT mean I cant break it as good as YOU can!!.
Cub Cadet LT1050 w/Johnny Bucket Jr./MTD Snowblower
JD 155C (YAY! Deck finally rebuilt and running!)
Generac 8000 Generator
Wheelhorse 416-H(Backwards Pheonix)
2-Wheelhorse C-101
Wheelhorse 520-H (Big Red)
7071, 7024 w/F engine, 8241AE, 10520 Lawn Boy, 8605A Scamp
Gravely 20-G "Almost There"
Pocketraisins is offline
post #8 of 8 Old 06-12-2011, 09:18 PM Thread Starter
KBrenz's Avatar
That sounds like an idea with the bulb. It is running better now, messed with the adjustment screws on the throttle linkage and that made a difference. still stutters a tiny bit and have to use the primer bulb to keep it running the first few seconds so i'll look at replacing the bulb. Thank you for your help!
JD STX38
KBrenz is offline
