Briggs OHV valve adjustment - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Small Engines and Repair
Midwest Mower Pro
post #1 of 17 Old 03-29-2011, 10:17 PM Thread Starter
I picked-up a nice looking White 1500 LT a couple months back, with the beginnings of a disassembled motor (just the tins and the ignition pick-up coil had been removed) and was told by the PO that it "wouldn't start". After some basic reassembly, I could see that it wouldn't turn over, much like a weak battery. But, the motor was free and it would spin without the spark plug installed. I thought it might be a valve adjustment issue, and as it turned-out, was a little deeper than that. It had a pretty badly bent exhaust valve push rod, and a destroyed push rod (plastic) guide. Recently, I thought I saw a pretty good video on MTF about adjusting the valves on a Briggs. I can't seem to find it using the search function, though. Can anybody give me the procedure and clearances to adjust the valves on this motor?
Model number on the motor is 28s777-1142-E1. Thanks for any help.
Dave M is offline
post #2 of 17 Old 03-29-2011, 10:42 PM
dab18351
dab18351's Avatar
Images: 14
Re: Briggs OHV valve adjustment
Set the piston at tdc then a 1/4 " below and adjust the exhaust at .005 and intake at .007...use a torx and hold center nut and loosen the outer nut and use a feeler gauge to correct adjustment with torx then hold torx and tighten the outer nut on both...run engine then check clearence again....that is how i do it...
Sears Custom 10XL
36" Snowblower
42" Snow Blade
38" Mower Deck
JOHN DEERE 111
42" PLOW
38" DECK
DAVE
dab18351 is offline
post #3 of 17 Old 03-29-2011, 11:42 PM
Jack of (some) Trades...
RamHD's Avatar
Your series engine, 280000 Series OHV single cylinder, the valve clearances are as follows..
Intake - 0.03"-0.05"
Exhaust - 0.05"-0.07"
How to Adjust Briggs & Stratton Overhead Valves
  1. Turn the flywheel to close both valves.
  2. Insert a narrow screwdriver into the spark plug hole and touch the piston. Turn the flywheel clockwise past top dead center until the piston has moved down 1/4". Use the screwdriver to gauge the piston's range of motion. PLEASE NOTE: This procedure must be performed for each cylinder on V-Twin engines.
  3. Check the valve clearance by placing a feeler gauge between the valve head and the rocker arm. Clearances differ for the two valves and typically range from .002 - .004" to .005 - .007". Use the correct clearances for your model engine.
  4. Adjust the clearances as required by turning the rocker screw. Once adjustments are completed, tighten the rocker nut.
  5. Install the valve cover, using new gaskets, as required, and make sure the cover is secure.
John Deere L110 Cub Cadet 86 Cub Cadet 108 Cub Cadet 126 Mahindra Max 28 4x4 w/FEL....
The majority as to numbers, wealth,and political influence are often wrong. If in such cases a person would do right, he must not be governed by public opinion, however it may be expressed, but by the law of God. {see Proverbs 4:14}
RamHD is offline
post #4 of 17 Old 03-29-2011, 11:46 PM Thread Starter
Great, thanks for the quick responses.
Dave M is offline
post #5 of 17 Old 03-30-2011, 06:57 AM
Shryp's Avatar
Shryp is offline
post #6 of 17 Old 03-30-2011, 10:23 AM Thread Starter
RamHD, thanks for the PM and the spec chart. That has a bunch of great info, all of which I need. Shryp, you hit the nail on the head. That was the video I was looking for. Thanks again for all the help.
Dave M is offline
post #7 of 17 Old 03-31-2011, 12:18 AM
Ummh, doncha think it might be worth it to figure out why the pushrod bent? Two things I can think of are: 1) over-revving the engine to where the valve hits the piston and stuff gets bent, or 2) a sticking valve. I would check how freely the exhaust valve moves in the guide, and also check that the guide has not started to push out of the head. I understand that some like to migrate to where the rubber valve stem seal gets smushed between the guide and the valve spring retainer as the guide has moved. Unless you know none of the above apply, that is.
tom
tomw0 is offline
post #8 of 17 Old 03-31-2011, 10:18 AM
Senior MTF Poster
"I understand that some like to migrate to where the rubber valve stem seal gets smushed between the guide and the valve spring retainer as the guide has moved."
There will be no seal on the exhaust valve however the guide may have worked up with the valve retainer hitting it. Guide should not extend more than 1/8" above the head casting.
Since exhaust valve push rods do not bend for no reason, as said above, finding the cause is very important.
Walt Conner
Walt 2002 is online now
post #9 of 17 Old 03-31-2011, 11:25 PM Thread Starter
I agree. Push rods bend for a reason. I'm not real familiar with this OHV motor-at least not as familiar as I'm about to become. This is the aluminum push rod that bent, which I believe is the exhaust side. I'll check for a sticky valve for sure. As far as over-revving, that could have happened with the PO, can't really say. There is a plate mounted below the tappets that has two square holes in it, that in-turn have two plastic pushrod guides mounted in those square holes. One of the plastic guides has been obliterated by whatever happened.
Can I see the valve guides from inside the pushrod chamber, or do I need to pull the head?
Dave M is offline
post #10 of 17 Old 04-01-2011, 10:05 AM
missing some zeros I think, should be .003-.005 and .005-.007
38racing is offline
post #11 of 17 Old 04-01-2011, 10:17 AM
GrandPa
K108Cub's Avatar
Images: 10
I noticed in the video, when he turned the engine past TDC, he just moved the flywheel and didn't check if the piston moved 1/4" down.
KennyP
KennyP
Proud Member of the 800 Posts Club
U.S. Army, RVN, 1968-1969
5th Battalion, 16th Artillery, Battery C
1971 Cub Cadet 108
1977 Ford LGT 165
1981 Craftsman GTV/16
198? Craftsman II
K108Cub is offline
post #12 of 17 Old 04-01-2011, 11:28 AM
RamHD's Avatar
You are correct sir.....Put the decimal in the wrong spot...never liked math anyway. My old eyes and brain don't catch things like they used to..lol
RamHD is offline
post #13 of 17 Old 04-01-2011, 08:58 PM Thread Starter
Further investigation has revealed that the boss that the upper (intake, I think) rocker stud screws into has broken away from the head. Needless to say it increased the valve clearance dramatically. I'm going to see if its weldable. Heads on ebay look to be kind of pricey. I did rig everything back together so I could see if the valves moved (or were stuck), and while the lower rocker moved the valve substantially, the upper rocker only opened the valve slightly. Is this normal? I always thought valve opening was supposed to be pretty equal. And, thanks for the corrected specs on the valve clearances. Approaching 1/16" (.06) sounded like a pretty big gap.
Dave M is offline
post #14 of 17 Old 04-02-2011, 08:41 PM Thread Starter
Walt Conner[/QUOTE]
I pulled the head and found that the exhaust valve guide is about 9/16" above the surface of the raised boss on the head that the guide travels through. No apparent valve seal on the guide, as you stated. I guess that explains the bent pushrod and the limited travel of the exhaust valve. A light tap with a hammer and a block of wood did not move the valve guide. It is tight. I'm wondering if I can just press the guide back into the head to the proper spec and be good to go, or if I need a machine shop to knurl the guide and press it back in. Any suggestions? The intake valve guide is about 3/8" above the surface of the head with a valve seal on top of it. It looks like it's where it's supposed to be. Are you sure about the 1/8" dimension above the head? If so, I'll need to reset both of the guides. Thanks. BTW, lots of debris inb the cooling fins. I'm pretty sure this motor got hot.
Dave M is offline
post #15 of 17 Old 04-03-2011, 03:02 AM
4K Poster!!!
Fcubman's Avatar
Images: 5
The excessive heat probably caused the guide(s) to move in the head. Yet another reason to allow the engine to idle for a couple of minutes before shutting down after a work session. And an annual check of the cooling fins is mandatory, in my book - if not more often. It's cheap insurance, especially in the spring after the rodents have nested in there all winter.
(Red Green)
Fcubman is offline
