Tecumseh H60 linkage - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Small Engines and Repair
Midwest Mower Pro
post #1 of 9 Old 12-11-2010, 10:52 AM Thread Starter
GusGT18's Avatar
Need help on the correct hookups for the spring and link on a tecumseh H60. When I got it the link was on backwards, so flipped it and it runs good now, but if anyone can verify the hole setup that would be great.
I sketched the hole pattern in the throttle. Right now I have it in the lower left hole.
Thanks,
Gus
Gus
1987 Craftsman II GT18 44"
1988 Craftsman II GT18
Accessories:
Craftsman II 14 Cu Ft. Dump Cart
Craftsman 40" Snowblower
Craftsman 48" Dozer\Snow Blade
GusGT18 is offline
post #2 of 9 Old 12-11-2010, 11:34 AM
The voice of reason !
ranchkingron's Avatar
Re: Tecumseh H60 linkage
Not sure because of the bracket but I can say if you give me the Engine number I can give you the linkage setup.
As near as I can tell you use the hole furthest out so you will get full throttle plate opening.
Ron
Sometimes a cigar is just a cigar. Sigmund Freud
ranchkingron is offline
post #3 of 9 Old 12-11-2010, 12:09 PM Thread Starter
GusGT18's Avatar
Thanks. The model number is H60-75264G
Gus
Accessories:
GusGT18 is offline
post #4 of 9 Old 12-11-2010, 10:05 PM
Ok this is what I found out 143.586012 - H60-75264G
Series 1 carb two different throttles on this one both have one hole which is out further than the rest and thats the one to use, so what I would do is is close the throttle to idle then hold the governor at it's lowest then see if it lines up with the hole on the outside of the throttle it should open all the way with movement from the governor.
As far as I can see you have it all in the proper locations.
Ron
ID:	133953   Click image for larger version
ID:	133954   Click image for larger version
post #5 of 9 Old 12-12-2010, 12:02 AM Thread Starter
GusGT18's Avatar
Wow. great info. Thanks again Ron.
Gus
Accessories:
GusGT18 is offline
post #6 of 9 Old 12-12-2010, 12:16 AM
No problem, but if anyone else has a better grasp of the layout (linkages) I hope they chime in.
Ron
post #7 of 9 Old 08-04-2016, 08:30 PM
bearbon's Avatar
Thanks for your help guys! I have a vintage Yard Man Snobird with a 5hp Tec engine and I was looking everywhere for this particular governor setup. This is just what I was looking for. I set up the gov and now it runs fine. I'm keeping a copy of this page for future reference.
bearbon is offline
post #8 of 9 Old 08-04-2016, 10:45 PM
Anyone can download a free copy of the Tecumseh engine book from the MTF library...over here: Tecumseh Technicians Manual - 3 to 11 HP 4 Cycle L-Head Engines
It shows the various governor linkages, but I think ranchkingron got it pretty close to where ya need to be.
wwxx
wwxx is offline
post #9 of 9 Old 08-04-2016, 11:53 PM
bearbon's Avatar
Wow, thanks for the link. What a great asset this manual will be. I looked at so many search leads I couldn't see the forest for the trees. Now I know where to find it. Much appreciated.
bearbon is offline
