Kohler CV15s not starting - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Small Engines and Repair
Midwest Mower Pro
post #1 of 14 Old 04-17-2010, 08:06 PM Thread Starter
Jak
Turns over and tries to start but makes a back-fire sound. I checked the plug, new from last year, and it is fine. I dropped the carb bowl and cleaned it; not dirty but some water drops. I used all new fuel.
The short tube connecting the carb to the engine was torn and I rigged up my own, which may leak. Would that cause a prob?
JakSuede is offline
post #2 of 14 Old 04-17-2010, 08:37 PM
H-D
Re: Kohler CV15s not starting
Yep!!! Vacuum leaks cause lean mixture & you need an over-rich mixture for starting. Not much use trying 'til you 'heal the leak'. Clearing the water from the bowl was a good start though! If you'll post the particulars (model & serial #s & type Kohler (Courage or Command), you'll find more help. Lotta Kohler specialists here!
H-D is offline
post #3 of 14 Old 04-23-2010, 07:27 AM Thread Starter
Jak
Ok, I fixed the hose. Same result. I know it isn't the choke since there is a diff when I pull it out (halfway or full).
Could it be a carb setting, or should I rebuild the carb?
Model: Kohler CV15s. (not sure what Courage or Command means)
JakSuede is offline
post #4 of 14 Old 04-25-2010, 10:57 PM
Master Service Technician
Look at he valves for a broken valve keeper., If you spray carb cleaner in the carb will it run momenarily and stop?
DTLMG is offline
post #5 of 14 Old 05-03-2010, 08:19 AM Thread Starter
Jak
I will have to try the spray while I start it. How do I get to the valves, tear down the engine?
JakSuede is offline
post #6 of 14 Old 05-03-2010, 09:43 PM
you simply remove the cover that is near the spark plug to see the valves. there are 4 or 5 bolts... the cover may be stamped OHV
DTLMG
Make sure your red wire goes to positive, and your black to ground
Master Senior Service Technician
30+yrs in Outdoor Power Equip Industry
DTLMG is offline
post #7 of 14 Old 05-20-2010, 12:03 PM Thread Starter
Jak
Help Re: Kohler CV15s not starting
I couldn't get it to run with the carb spray, and the lil backfire (I think) may have caused the flames that shot out of the carb. Not kidding!
So I guess I am to the valves now. What is it I am looking for?
JakSuede is offline
post #8 of 14 Old 05-20-2010, 02:14 PM
I'd look at the flywheel key first,sounds like its firing out of time,its probably broken or half sheared..a valve could be stuck open also too,intake most likely if flames shot out of the carb....at least you know it has spark now though!..
Tractor-Holic is offline
post #9 of 14 Old 05-20-2010, 06:01 PM Thread Starter
Jak
Ooooooh yeah, plenty of spark. Do you know where the shear pin is?
I will look at the valves, but how do I know if one is stuck open? Are they all supposed to be closed when the engine is off?
Nice pic, a real grabber
JakSuede is offline
post #10 of 14 Old 06-24-2010, 08:04 AM Thread Starter
Jak
Cool Re: Kohler CV15s not starting
Oooooooookay. I just dropped some $$ in it to get the valves fixed. I cut my grass for about 45 min, ran out of gas, and found that it would start but then stall out.
While I wait for my mechanic guy to call me back, are there any thoughts on this?
I dont expect he tweaked the carb, but maybe that is needed now?
JakSuede is offline
post #11 of 14 Old 06-24-2010, 07:30 PM
All Fired Up
Depending on the year, it might not be a carb adjustment to tweak.
madmantrapper is offline
post #12 of 14 Old 03-25-2012, 06:06 PM Thread Starter
Jak
Help Re: Kohler CV15s not starting; Changing deck now
I can't figure out how to post a new thread so I'll piggy-back on here. I need to change out my deck. Kohler engine is on a Yardman body. I can't get under it, so I thought I would flip it onto its back wheels and prop it up.
Will this cause oil, etc. to flow to bad places?
JakSuede is offline
post #13 of 14 Old 03-25-2012, 07:37 PM
flash5153's Avatar
Lol!!
First of all,,,to post a new thread. Go to the forum you want to post under,,,and hit the button at the top left that says,,,"New Thread"
And yes,,it causes problems to flip a mower up vertical. To change a deck ,,there is no need to lift the tractor,,,just pull pins and slide it out.
flash5153 is offline
post #14 of 14 Old 03-26-2012, 12:11 AM
Certified Technician
RED-85-Z51's Avatar
Images: 7
Oh man, Id break my back if I flipped a mower up to change the deck...
Pull pins, take loose any attachment points, slip off the belt...lift up the deck lift arm and slip that puppy out. 5-6 minutes tops depending on how many bent rusty nails are in place of where the hairpins should be...haha
1993 Wheel Horse 416-H
Onan P216G
1962 WH702
1997 K3500 Dually Sierra
1995 K3500 Silverado
TBI 454
1995 K2500 Silverado
6.5 Detroit Turbo Diesel
1994 GMC Sierra Z71
350 TBI
RED-85-Z51 is offline
