how to check oil properly on 11hp B&S motor - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Small Engines and Repair
Midwest Mower Pro
post #1 of 4 Old 10-24-2009, 02:04 AM Thread Starter
Slowly turning green...
lobsterbox's Avatar
Images: 3
hi i have an 11 horsepower Briggs&Stratton flathead motor with a dipstick for checking the oil. I believe i have overfilled the oil in this motor, but it doesn't seem to smoke or knock during normal operation and i am not sure how to properly check the oil on one of those motors. are you supposed to thread the dipstick all the way in? or just hold the cap on the end of the tube for a few seconds and then look. if you are supposed to thread it all the way in, then i believe i have overfilled it alot, and oil is leaking out around the dipstick seal. the engine is on an older mower which I purchased this season and changed the oil when I got it, only mowed with it twice and cut about an acre of yard in total. It preformed very well and only smoked when it was very warm and had just come of of mowing.
so these are my questions: **READ ABOVE FIRST**
how do you check the oil on a flathead Briggs&Stratton motor with a dipstick?
are there any negative consequences with overfilling the oil?
under light use have i done any irreparable damage to the engine?
if i know how to check the oil properly, I can fix things up, so please respond to this post and give me some help!!
thanks, lobsterbox
My Youtube Channel: lobsterbox20
2000 John Deere 425 w/ 54" Deck, 54" Blade, 50" Tiller, 47" & 46" Snowblowers, Cosy Cab ~400hrs
1992 John Deere 322 w/ 50" & 48" Deck, 46" Snowblower, 42" Tiller, ~1300hrs
1981 Case 646 Loader w/ 44" Deck, 42" Tiller, 3 Point Hitch
1978 Sears SS/19.9 Twin w/ 42" Deck ~350hrs (trailer queen).
1975 Roper RT/16 w/ Tote Box, Sickle Mower & 3PH.
lobsterbox is offline
post #2 of 4 Old 10-24-2009, 02:57 AM
4K Poster!!!
Fcubman's Avatar
Images: 5
Re: how to check oil properly on 11hp B&S motor
In my opinion, the slight difference in oil level (between screwing the cap in or not) doesn't matter. For the record, my two B&S engines (one Vanguard, one 8 HP flathead) want the cap screwed in for checking the oil level. I usually don't screw the cap in, and allow for the slight difference when I read the stick.
(Red Green)
Fcubman is offline
post #3 of 4 Old 10-24-2009, 09:44 AM
Senior MTF Poster
" are you supposed to thread the dipstick all the way in?"
As far as I know, ALL B&S engines stipulate screwing the dipstick in.
"and oil is leaking out around the dipstick seal. "
This is an indication that the rubber seal is "dead" and needs to be replaced, has nothing to do with oil level.
Walt Conner
Walt 2002 is offline
post #4 of 4 Old 10-26-2009, 09:08 PM
The general rule is screw in dipstick unless there is a sticker on the side of engine near the dipstick that says differently.
bser is offline
