best way to seal a frayed rope end - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Tool Time Tool questions and discussions
post #1 of 17 Old 01-07-2007, 10:50 AM Thread Starter
simple_john's Avatar
Images: 48
is there a clean way to stop a frayed end of a nylon or plastic rope?
i usually just take a lighter to it, it works ok but is far from even looking...
is there a better was to 'neatly' seal and prevent a rope end from fraying and breaking apart?
ID:	17959   Click image for larger version
simple_john is offline
post #2 of 17 Old 01-07-2007, 11:00 AM
10,000 +posts!
glenn27's Avatar
Re: best way to seal a frayed rope end
A lighter or little propane torch 'melts' it together-wearing work gloves as, soon as the heat is off-I twirl or twist the rope end in the way it lays....then just trim off any excess...
Jimmy Buffett
glenn27 is online now
post #3 of 17 Old 01-07-2007, 11:11 AM
Camaniac
Duct tape tightly around the rope about 6 inches from the fray so the rope ie tight then cut through tthe tape, works great!
1956 Cub Lo-Boy
JD LA175
JD LT133
JD RX73
Sears 16/6
If you can't fix it with a hammer, it must be an electrical problem!
freebird is offline
post #4 of 17 Old 01-07-2007, 01:00 PM
SJ, it really depends on how much effort you want to give it, the tape method works pretty good for most applications, unless the duct tape is exposed to any petroleum products.
There are lots of ways to accomplish this, here are a few ways I've used over the years.
You can try your hand at seizing/whipping the end.
http://www.scouting.org.za/resources...g/Whipping.pdf
Iv'e also used electrical shrink tube, it works pretty good. Or you can duct tape it, cut it and then dip it into liquid electrical tape (made by Star brite).
You can also use a silicon (or any) adhesive packed well into and around the strands, then duct tape over it, and if the duct tape does eventually wear off the silicone adhesive will still hold it together.
On small (under an inch or so) line or rope you can cut a piece of copper or aluminum tubing slip it over the rope and crimp it on with pliers or a vice if you don't happen to have the actual crimping tool, then trim the tag end as desired.
dirtyEd is offline
post #5 of 17 Old 01-07-2007, 01:31 PM
ex spelling bee champ
Ingersoll444's Avatar
Images: 14
I have always used whipping. Sounds funny, but know what I use? Waxed dental floss. Works awsome, and minty fresh to boot.
Paul B
SUPER Of The Month 10/2011
Ingersoll444 is offline
post #6 of 17 Old 01-07-2007, 02:15 PM
Deceased Oct.-2014
Mickey's Avatar
Images: 9
My approach is the same as Glen27's. Little flame to the end and it will melt into a ball. Since we cook with gas, there's no looking for a source of a flame.
Cub Cadet 3204 48" mower
1257 Bolens
Yanmar Fx24D
5' rotary mower
52" Yanmar RSB1300 tiller
Koyker 155 loader
Mickey is offline
post #7 of 17 Old 01-07-2007, 05:19 PM
Dan Lovell's Avatar
USN ED should have the answer to this post.
Dan
Dan Lovell is offline
post #8 of 17 Old 01-07-2007, 05:30 PM
Anything With Wheels
Argee's Avatar
Yep...propane torch on a plastic or nylon rope and whipping on hemp or sisal.
Randy G
Argee is offline
post #9 of 17 Old 01-07-2007, 05:58 PM
Just Have a Little Faith!
I usually use the torch but if you want to be fancy use a knife heated on the stove. Yes a knife you don't want.
LilysDad is offline
post #10 of 17 Old 01-07-2007, 06:07 PM
dyt4000's Avatar
Images: 12
1957 IH Cub Lo-Boy
1959 Ford 631 Workmaster
1967 Wheel Horse 857
2001 John Deere 425 3 point lift, rear PTO and Heavy Hitch with trash can option
dyt4000 is offline
post #11 of 17 Old 01-07-2007, 06:49 PM
A semi-retired senior cit
Mower_Man42's Avatar
Images: 3
If you have a Weller soldering gun they make a attachment that`s like a knife blade it gets hot and cut right throught the rope and seals the ends. We had one when I worked in a Taylor Rental and lawn mower repair shop, used it to cut starter cord all the time. You could make one using a hack saw blade and brazing it to the rod tips
_________________________________
1985 Lawn Boy commercial Model 8453
1991 Toro Re-cycler 3 speed model 20218
2005 John Deere G110/54" deck
2008 Cyclone Rake Command Pro
1981 Wheel Horse C-85 with snow plow
1969 Case 444 PK with 44" mower deck
2009 Honda HRX hydro Drive 21" Versamow system.
2006 Scag Wildcat 52" cut 25hp Kawasaki
Mower_Man42 is offline
post #12 of 17 Old 01-07-2007, 07:13 PM
I like to see the Scouters jump in on these things. I will go with the whipping on the one, but which one? English or Sail makers? I use a separate pull string like heavy waxed thread if I am whipping because I can go under as many turns as I want. I would also go the shrink tubbing route if I wanted a quick way.
Gene Wissink is offline
post #13 of 17 Old 01-07-2007, 07:16 PM Thread Starter
Images: 48
ok, now i get a reason to use my propane torch
btw: whats 'whipping'?
post #14 of 17 Old 01-07-2007, 08:50 PM
A technique for wrapping the end of the rope with a smaller cord
LilysDad is offline
post #15 of 17 Old 01-07-2007, 09:31 PM
Argee's Avatar
Like Ed said......
Randy G
Argee is offline
