bolt cutters - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Tool Time Tool questions and discussions
post #1 of 16 Old 10-14-2006, 09:01 AM Thread Starter
Peevee's Avatar
bolt cutters
I have a new job. I'm a service technician for a plumbing company. When we install a new toilet, they want us to cut off the toilet bolts. This is very time consuming trying to cut these bolts off with a hacksaw or mini saw. They want the bolts cut off and the plastic caps put on. I tried a dremel tool and the bolts will eat a cutoff wheel in no time. What makes them so hard to saw off is they are in a awkward position to start with. I'm thinking of trying some bolt cutters. What size would cut 1/4 bolts with ease and still fit in my tool bag? If you have any other suggestions they would be greatly appreciated.
Peevee is offline
post #2 of 16 Old 10-14-2006, 10:01 AM
Once was a Super Member
Wingnut's Avatar
Re: bolt cutters
The smallest bolts cutter I own have 12" handles they can easily handle a 1/4 bolt
H.K. Potter 12" bolt cutters available at the Home Depot
Celebrating 39 years of a Drug-Free Elvis! Adventures with Harry Ferguson!
How far you go in life depends on your being tender with the young, compassionate with the aged, sympathetic with the striving, and tolerant of the weak and the strong, because someday in life you will have been all of these.
Lose money while restoring a Farmall F-12 let me show you how!
CLICK HERE
Wingnut is offline
post #3 of 16 Old 10-14-2006, 03:48 PM
Dan Lovell's Avatar
Re: bolt cutters
I think if you used bolt cutters you would crush the end of the bolt, making it very hard for the next guy to get the bolts off. That could be an issue especially if the next guy is you. I use a mini hack saw, what kind of blades are you using?
Dan
Dan Lovell is offline
post #4 of 16 Old 10-14-2006, 04:12 PM
Deceased Oct.-2014
Mickey's Avatar
Images: 9
Re: bolt cutters
What might work out for you is to use a 4.5" right angle grinder. That's what I used last time. Fairly quick and does min damage to remaining bolt. What you do need to do is use some kind of guard to keep hot sparks from hitting the toilet as they will embed themselves in the porcelain.
Cub Cadet 3204 48" mower
1257 Bolens
Yanmar Fx24D
5' rotary mower
52" Yanmar RSB1300 tiller
Koyker 155 loader
Mickey is offline
post #5 of 16 Old 10-14-2006, 05:56 PM
Anything With Wheels
Argee's Avatar
Re: bolt cutters
Have you tried a battery operated sawzall???
Randy G
Argee is offline
post #6 of 16 Old 10-14-2006, 06:10 PM
1086's Avatar
Images: 11
Re: bolt cutters
I believe there are at least 3 different lengths to choose from at most plumbing supply stores. If the correct length still can't be found I recommend cutting them to length before installation. First run the nut on beyond where the cut will be and when the nut is backed off the rough cut will be a little smoother to re-install the nut later.
1086 is offline
post #7 of 16 Old 10-14-2006, 06:34 PM
slipshod's Avatar
Re: bolt cutters
Those bolts cut very easy, not very hard. What I do is make only 5 or 6 passes with the Hack saw and break them the rest of the way with a small pair of vise grips. The bolts break clean at the nut and it is not hard to unbolt later on.
slipshod is offline
post #8 of 16 Old 10-14-2006, 10:09 PM
10,000 +posts!
Re: bolt cutters
Don't give up on a Dremel just yet. They make a right angle adapter and if you use the laminated cutoff wheels they last all the way through a bolt that size. Keep the pressure light on the tool and you should be good to go with no problem threads.
HydroHarold is offline
post #9 of 16 Old 12-15-2006, 09:57 PM
Tractor Country
Rippers Customs's Avatar
Images: 3
Re: bolt cutters
I think if you have spent some time on this you would definitly made the right choice for the job....
1984 JD 318 50" Deck, 54" Power angled blade for fun
1988 WH 312-8 W/42"SD deck, 48" blade for fun
2000 Huskee garden tractor for mowing (gifted to a friend)
Rippers Customs is offline
post #10 of 16 Old 12-15-2006, 10:58 PM
Member Extraordinaire - Deceased March 2017
Durwood's Avatar
Re: bolt cutters
I just replaced a toilet and a battery operated sawzall was the perfect tool for the job. Cuts thru those bolts like butter.
Dur
Durwood is offline
post #11 of 16 Old 12-15-2006, 11:19 PM
Retired Mod
dirtybernie's Avatar
Re: bolt cutters
Yea but the dremel uses electricity. what if its in an outhouse?
dirtybernie is offline
post #12 of 16 Old 12-16-2006, 12:54 AM
Machiem's Avatar
Re: bolt cutters
I use the same method as slipshod.
I've cut them all the way off before until someone showed me the "score and snap-off" method.
I'd be leary of using bolt cutters since it might add extra tension on the bolt and crack the porcelain. Then, you get to replace the whole toilet again.
Machiem is offline
post #13 of 16 Old 12-16-2006, 10:16 PM
Snow Plow Junkie
itsgottobegreen's Avatar
Re: bolt cutters
I This is very time consuming trying to cut these bolts off with a hacksaw or mini saw. .
You get paid by the hour. So why would you want to get done faster.
Snow Plow Junkie
Kubota B7500 cab w/heat, loader, plow, blower, MMM, tiller, box, rear blade, brushhog, power broom, aerator
Walker 48" GHS 26efi
3-JD 110 (1964,65)
1-JD 112 (1972) Forsale $300
1-JD 214 (1986)
36/37a blower, 31 tiller, 42/43 blade, RF Cab, 7 mower decks
itsgottobegreen is offline
post #14 of 16 Old 12-18-2006, 09:06 PM Thread Starter
Peevee's Avatar
Re: bolt cutters
I finally tried some different blades for the mini hacksaw and that's what I'm using now.
Peevee is offline
post #15 of 16 Old 12-18-2006, 09:57 PM
Re: bolt cutters
Back in the days of American made toilet bolts, the bolts were prescored at a certain height so that all you had to do was grab the top of the bolt with a pliers and lever it back and forth a couple of times to snap the extra length off so that you could cover what was left with the plastic caps.
Do you carry unbendable soda straws with you?
You can put the straws on the bolts which makes it easier to guide the toilet base onto the bolts.
I recently found out the hard way that if you have to put a new toilet on a cast iron toilet flange, you had better put some wide washers on the hold down bolts because the little rectangular back on the bolt will pull right through the slots for the hold down bolts. The wider washers (Snip the washers part butting against the flange for a closer fit with some "bulldog" aviation snips.) give you more of a shoulder for the bolts base to pull against and won't let the bolt pull through.
Good luck, and live and learn.
Bountyhunter
Bountyhunter is offline
