Stihl MS250 leaks bar oil? - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Tool Time Tool questions and discussions
post #1 of 7 Old 06-28-2010, 09:55 PM Thread Starter
johndeere's Avatar
Images: 7
I recently bought a Stihl MS250 chainsaw.I notice it leaks a little bar oil when sitting?Is this normal?Reason I ask is because my other saw a Craftsman always leaked bar oil real bad.But that was a cheap $100.00 saw.The Stihl only leaks a little not a puddle like the Craftsman.But I paid over $300.00 for this one.Should I take it in and more then likley have to wait a lkong time to get it back.Or is it normal for it to leak a little?Every chainsaw I have ever owned has had this same problem.That why I am unclear if it is normal.
johndeere is offline
post #2 of 7 Old 06-28-2010, 10:06 PM
Happy To Be Here
motobike's Avatar
Images: 9
Re: Stihl MS250 leaks bar oil?
All of my saws drip a little if not used for a while, some more than others.
Motobike
We don't quit playing because we got old; we get old because we quit playing.
motobike is offline
post #3 of 7 Old 06-28-2010, 10:20 PM
ggsteve's Avatar
My Poulan leaks bar oil badly when sitting. Please tell me what you think of the MS250 overall. I'm planning on buying one soon. I want to get a MS250 with 18" bar and two chains. How does it compare to the Craftsman, or, as I have heard, is there really no comparison?
ggsteve
68 JD 112H 47 deck 43 blade
69 JD 110H 37A blower 50 cart
71 JD 140H1 80 Cart
72 JD 110 parts
78 JD 316K 49 blower
84 JD 214 39 deck 43 blade
Woods box blade
74 Concord (MTD) 990
ggsteve is offline
post #4 of 7 Old 06-28-2010, 11:01 PM Thread Starter
johndeere's Avatar
Images: 7
My Craftsman is a Poulan and it served me OK for about 5 years.Was getting hard to start and the Goofy gas cap had to be threaded in with pliers.It always leaked bar oil like the Exon Valdez.It came with a free case and im sure thats why.To catch all the bar oil.
The MS250 I bought it because I had some storm damage and was aggrivated with both the mess that needed cleaned up and the Craftsman.So I went on the spare of the moment and got what the dealer had.I knew I wanted a Stihl and I wanted a 16'' bar.I could have saved some money and went with the basic 14'' model forget the model number.But my Craftsman was a 16'' and I did not want anything smaller.I also did not want anything bigger.
The MS250 is a animal compared to the Sears.Although there both 16'' saws the chain is wider on the Stihl and I never felt like the Sears ever really cut well.Seemed to me I always had to push and rock it to get it to cut.Even with a new chain.The Stihl does the work you just hold on.The difference is like a sharpe chain Vs a dull chain.But even with a new chain on the Craftsman.
My MS250 has a 16'' bar I think most have a 18'' it also has the fast tension adjuster cover.Many do not like that but for my occasional use I did not care.It also has the Easy Start coil start.I would have just assume it not have that.It works OK but just feels strange.To pull the rope and there be a delay in the engine cranking.
What I like the most about it is it starts very easy.Full choke one pull it fires then release the choke and it starts on the second or third pull every time.Plus comes right to life no spitting or sputtering and cutting out or dieing.
My only concern is the slight bar oil leakage from sitting.
post #5 of 7 Old 07-22-2010, 11:29 PM
It's normal. All of my Stihl saws drip a bit over time. That is why I drain the oil tank when being stored away for extensive period of time, especially when there is winter grade oil in it. Because if you don't, it will leak oil like crazy in summer weather.
shamrock12 is offline
post #6 of 7 Old 07-23-2010, 08:04 PM
I just bought a Poulan Pro with 18" bar and the owner's manual says to drain the bar oil when not in use. Never heard that before.
junebug1701 is offline
post #7 of 7 Old 07-26-2010, 08:46 AM
GANG GREEN GIZMOW KILLER!
RaisedByWolves's Avatar
Loosen your oil cap when you store the saw.
http://jd318techforum.proboards.com/index.cgi
http://houseofhomelite.proboards.com/index.cgi?
POWERKING "79" 2416
ECONOMY "64" JD
KUBOTA 4200
"68" JD 140 H-3
And a restored JD318
RaisedByWolves is offline
