Chicken Coop - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 18 Old 07-01-2011, 07:54 PM Thread Starter
windfish's Avatar
Chicken Coop
Well, my mom has decided she wants chickens
So it fell to me to build her a coop. I looked around for a while trying to find plans, didn't find any free ones that looked worth following, so I just freehanded it.
Its about done, it sits on a roughly 5x10 frame which will have an enclosed run. Its ended up bigger and heavier than I originally intended, but it should last a little while.
Question, how much room should I have left for the chickens to get under the coop? I wasn't really thinking when I started it, but now that I look there's not a whole bunch of room. There's a 14.5" lip, and once they get under they'll have 18" of headroom. If I'm going to raise it, now's the time. Raising it won't be much fun, but its doable if needed...
Thoughts?
windfish is offline
post #2 of 18 Old 07-01-2011, 08:11 PM
Imagine it. Build it.
tiretrx's Avatar
Images: 8
Re: Chicken Coop
First, let me say, beautiful job there. As far as height, I guess it depends on the breed, bantams should be no worries, Jersey Giants will be an issue.
.....just call me Ellis
I was abandoned as an infant and raised by a family of opposums........does that explain things?
tiretrx is offline
post #3 of 18 Old 07-01-2011, 08:15 PM
SonnyT's Avatar
Images: 26
Re: Chicken Coop
Good job! I think there is enough room for them to dance around under it. JMO
RIP Sonny T.
1954-2015
SonnyT is offline
post #4 of 18 Old 07-01-2011, 08:39 PM Thread Starter
windfish's Avatar
Re: Chicken Coop
Thanks guys
She's getting Buff Orpingtons from a local breeder
windfish is offline
post #5 of 18 Old 07-01-2011, 10:05 PM
Re: Chicken Coop
Nice job! Now think "predator proof"! Coons have tried getting to my girls many times, consider ditching out around the perimeter and let your wire or hardware cloth run at least 6" down below grade to discourage digging. How many birds are you getting?
njjack is offline
post #6 of 18 Old 07-02-2011, 01:35 AM
Re: Chicken Coop
Question: why did the chicken coop have 2 doors?
Answer: because if it had 4 it would be a chicken sedan.
sanfordanddaughters is offline
post #7 of 18 Old 07-02-2011, 08:27 AM
Re: Chicken Coop
Buff Orpingtons are a good sized bird and good dual purpose birds. You need 4 sq.ft of floor space per bird to keep them from picking each other. If they are going to be de-beaked you can cut that down to about 3 sq.ft with out much trouble. If you put in a nest box, 1 box per 8 birds, that will cut down your available floor space.
If your chickens are just going to be sleeping in your coop then the floor space is not really that critical,they will just need room to roost. As long as you don't forget to open the door in the morning so they can get out.
I wouldn't worry about your height. I keep Meat Kings in a coop that's only 12-14 inch high and it doesn't seem to bother them. They use the coop for sleping and staying out of the rain.
hippycy is offline
post #8 of 18 Old 07-04-2011, 12:22 PM
ToolBoxTavern's Avatar
Re: Chicken Coop
Nice build. Here is a link to the one I built. Now I wish I made it bigger.
Hen House / Chicken Coop
ToolBoxTavern is offline
post #9 of 18 Old 07-05-2011, 06:37 PM Thread Starter
windfish's Avatar
Re: Chicken Coop
Whelp, its done.
Well, 95% done. Need a better latch on the run door and to make the door that opens from the coop to the run. For right now I just covered the opening with wire mesh.
The chicks my mom got this weekend are small enough the breeder recommended they not be put on the ground for another week or two. Except for one, which gets put out in a small xpen under supervision.
Might end up making the run larger, but for now...
Oh, and the hitch needs reinforcement if I'm going to keep it. Thing ended up pretty heavy so I opted to tow it over to where it'll sit. From now on it'll likely only be moved short distances, and the rear wheels are working great for now.
windfish is offline
post #10 of 18 Old 07-05-2011, 08:23 PM
gooberguy's Avatar
Re: Chicken Coop
Around here these are called Chicken Tractors.
gooberguy is offline
post #11 of 18 Old 03-19-2012, 01:50 PM Thread Starter
windfish's Avatar
Re: Chicken Coop
Whelp, 8 months later and its still standing -- and got an upgrade.
The original run ended up being a little cramped for 6 chickens, it had held just 3 up till this point (4 of the original batch were roosters, we didn't keep them).
The external run is detachable so everything is still movable. Latches hold it at the two sides. Will build a door between the main run and the external so the main can still be used on its own, for the moment I just cut a hole in the wire.
Bottom pic is of the nestboxes, looked around on the internet for plans and threw something together. They're using them as intended, so I guess they're good enough. There's another roosting pole between the one you can see and the wall.
The winged roof ended up being a good idea, nestboxes are easily accessible and it makes cleaning easier, put down linoleum and the old shavings slide out nicely.
windfish is offline
post #12 of 18 Old 03-20-2012, 12:38 PM
Re: Chicken Coop
Nice.
We ended up with a few more chickens and I am getting ready to make a upgrade on ours also.
post #13 of 18 Old 03-20-2012, 02:52 PM
Heavy Hitch's Avatar
Re: Chicken Coop
That's a great looking coop! Getting our first flock in a few weeks!
'12 JD 1026r, 60" MMM, FEL
'87 332
'52 661 Ford Workmaster
48" KK Tiller
Heavy Hitch is offline
post #14 of 18 Old 04-12-2012, 09:38 PM
thudpucker's Avatar
Re: Chicken Coop
ID:	208216 Click image for larger version
Name:	chicks in with hens.jpg
If they start laying on the ground your gonna need a long stick with an egg catcher on the end of it.
My Coop is in a Barn, plenty of room, the big blue Barell catches rain water off the roof and they drink it from the Drippers on that white plastic pipe.
I had too many Roosters. I put them out in a field inside this movable pen.
Name:	Gypsy Roosters.jpg
Your movable is a much better idea. Wait till dark to move them, and you wont hurt any of them.
thudpucker is offline
post #15 of 18 Old 03-22-2014, 09:48 PM Thread Starter
windfish's Avatar
Re: Chicken Coop
Heard a crash last night, tree branch came down and got the coop
The 'branch' that got it
Amazingly it only killed two chickens out of the 10 that were in there, probably the ones roosting directly below where it hit. Roof system is totally trashed (obviously) but the box survived remarkably well. Knocked one side panel down a few inches and sank the support leg on the opposite side, used a bottle jack to put it back in place.
It wasn't in my schedule today to put a new roof on it so I ran by the hardware store, picked up some metal braces, and repaired what I could. Its ugly but functional, will keep the rain off them until I have time to decide what to do with it. Its about time for a bigger coop anyways.
windfish is offline
