Tip Toe wheels - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 7 Old 01-18-2012, 04:27 PM Thread Starter
gears's Avatar
Tip Toe wheels
anyone running (or have run) tip toe rear wheels on a 9?
I'm looking at a set to run outboard of my 11.2X28 agris (yep duals - rubber on the inside, steel outside) I figure it'll give me weight for traction and if I sink to where the teeth bite - I'll have a heck of a lot more traction from them!
Comments, concerns, cautions?
Do it right or do it over.
gears is offline
post #2 of 7 Old 01-19-2012, 10:12 PM
Re: Tip Toe wheels
I've used duals on a 600 series tractor. but these were dual ags not a steel outter. the adapters are often on ebay but again these were for dual ag tires.
slip knot is offline
post #3 of 7 Old 01-20-2012, 06:51 AM
Kirk-NJ's Avatar
Images: 16
Re: Tip Toe wheels
You aint plannin to run them across the wife's lawn are you? Might be cheaper to run with chains on.
Kirk
Kirk-NJ is offline
post #4 of 7 Old 01-21-2012, 06:48 PM
No Bozo's
speedy1wrc's Avatar
Re: Tip Toe wheels
I've only gotten stuck once. It was soupy mud that was maybe 16" deep. I don't know if outers, steel or otherwise would have helped. Where I otherwise exceded grip I usually was at the pulling limit of the tractor anyway.
speedy1wrc is offline
post #5 of 7 Old 01-25-2012, 09:34 AM Thread Starter
gears's Avatar
Re: Tip Toe wheels
I can't seem to find any pics of an N with TipToes on! (much less duals)
Back yard's so tore up from the crane at my barn raising that the wife's given up.... till spring of course.
gears is offline
post #6 of 7 Old 01-25-2012, 11:20 AM
Kirk-NJ's Avatar
Images: 16
Re: Tip Toe wheels
Are these the tip toes your looking for? These are actually ferguson/sherman assister wheels. Best for use in mud and soft loamy soil conditions. Not to be confused with sand paddles, a whole different animal.
BTW it's not my tractor.
Kirk
Kirk-NJ is offline
post #7 of 7 Old 01-25-2012, 12:27 PM Thread Starter
gears's Avatar
Re: Tip Toe wheels
Nice Kirk - that's exactly what I intend to do (but mine will be red to match....)
gears is offline
