I am thinking about trying to mount this. Has anyone done it??
I am only using this for snow so it does not need to heavy duty. And I am going to use a Gravely GT snow blade. lol
It will need to be widened and frame modified to mount ,,,and work with the 3 point lift. A cable on each side up to the front,,arms on lift tighten cables(though pulleys and lift the blade,,, in the front)
I just slid the blade under tractor and took a peak. There is little to nowhere to mount any brackets. The hitch in the back would work for strength in pushing,,and the front bumper would work to attach pulleys/cables for lifting.
But I need something in the middle to hold blade frame up off ground,,would really have little tension on it. I don't see much to grab onto with a bracket.
If I'm going to keep this tractor,,I need to find a use for it!!!
The way it looks I will be able to modify the hand angle handle ,,,to be able to reach it from seat,,,so I can angle blade.
I got to admit though,,it looks awful small in front of the 8n.:sidelaugh
