Welding ring gear - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 20 Old 11-04-2011, 01:40 PM Thread Starter
WI_Jeff's Avatar
Welding ring gear
About 3 months ago, I changed the clutch in my 8N. While I was in there, I decided to change the ring gear as the one on there was starting to wear and someone had already pulled the "turning" trick. Last week, the starter would just spin. Simple minds think simple things. I checked out the starter and it was fine. Replaced the bendix with the new style. It still just turned free. After a little more investigation, I noticed that the ring gear is turning on the flywheel. DARN! I did notice that when I put the new ring gear on that when it "fell" on, after heating it was very loose when it bottomed out.
I may try to weld it in the tractor. That is if I can get the ground directly onto the flywheel. I don't want to "weld" any of the bearings together by grounding to any where else. Anyone have any ideas, I'm always open.
WI_Jeff is offline
post #2 of 20 Old 11-04-2011, 01:51 PM
SonnyT's Avatar
Images: 26
Re: Welding ring gear
Gotta be a better way than welding it on? IMO
RIP Sonny T.
1954-2015
SonnyT is offline
post #3 of 20 Old 11-04-2011, 01:59 PM Thread Starter
WI_Jeff's Avatar
I'm open for suggestions.
WI_Jeff is offline
post #4 of 20 Old 11-04-2011, 02:29 PM
monteman_73's Avatar
I understand your concern for the bearings, but what I don't understand is if you have enough room to put a ring gear on, why wouldn't you have room for the ground cable for the welder?
monteman_73 is offline
post #5 of 20 Old 11-04-2011, 02:39 PM
CADplans's Avatar
JB weld or Loctite gap sealer??
CADplans is offline
post #6 of 20 Old 11-04-2011, 02:43 PM
Never seen a ring gear welded on but don't see why it wouldn't work. Save tearing the tractor in half to replace the flywheel and ring gear again. If you just put some tack welds on it thru the starter mount hole you should be OK. I sure wouldn't get carried away with the welding and would tack one side, turn it 180 degrees, tack again and then turn 90 degrees. You get the idea. Four tacks about an inch long should do it.
Since the crank is bolted solid to the flywheel you should be able to ground the welder to the front of the crank and avoid any potential problems of arcing the bearing surfaces.
Worse case you end up pulling the flywheel again and grinding off the tack welds.
Just my opinion, never done it, hope I never have too.
Mike
A gun and a parachute are much the same. When you need one nothing else will really suffice.
Tencubed is offline
post #7 of 20 Old 11-04-2011, 03:46 PM Thread Starter
WI_Jeff's Avatar
"I understand your concern for the bearings, but what I don't understand is if you have enough room to put a ring gear on, why wouldn't you have room for the ground cable for the welder?"
I have the tractor together and plan on welding through the starter hole.
"Four tacks about an inch long should do it."
Plan on the 4 tacks at 90 degrees to each other. The ring gear has 134 teeth. So, first tack at 0, second at 67, third at 33 1/2 and the last at 100 1/2 ( or close to that anyway LOL)
WI_Jeff is offline
post #8 of 20 Old 11-04-2011, 04:22 PM
windowgoblin's Avatar
What about brazing or bronzing it on a few spots,won't hurt the bearings and easy to remove it you have too.
I have a rock garden. Last week three of them died.
my projects
1950 ford 8n
1967 gravely 430 commercial rider
kEMP woodchipper.
1949 ford 8n
Yard an 22 hp ride on
22hp craftsman ride on
2wheel simplicity with tiller,blower,sod plow,and saw bench.
2007 Kawasaki 650i brute force 4 wheeler.
windowgoblin is offline
post #9 of 20 Old 11-04-2011, 05:22 PM
JohnW's Avatar
Images: 3
There have MAY a ring gear tack welded, just be sure to ground to the flywheel some way and then tack it in 3 or 4 places. it won't take much to hold it. Try to get them equal distance.
JohnW is offline
post #10 of 20 Old 11-05-2011, 04:10 PM Thread Starter
WI_Jeff's Avatar
Whew Re: Welding ring gear
DONE! Welded through the starter hole. Four tacks about an inch long. Spaced at 33 and a half teeth apart. Grounded at the crank shaft. Needed a helper to hold the rig gear tight. Just used a pry-bar. WORKED GREAT. I though on this was that if the flywheel is messed up already, so, when a new ring gear is need the flywheel would have to be replaced anyway. It was fairly easy to do.
Thanks for all the input!
WI_Jeff is offline
post #11 of 20 Old 11-05-2011, 08:50 PM
JohnW's Avatar
Images: 3
even if you are the one to change it next time, the welds can be ground off and use the flywheel again.
JohnW is offline
post #12 of 20 Old 11-06-2011, 11:42 AM
oldsarge's Avatar
Tell us who you bought the crappy ring gear from.
oldsarge is offline
post #13 of 20 Old 11-06-2011, 11:23 PM Thread Starter
WI_Jeff's Avatar
I got it from Steiner Tractor. When I did contact them, they said it was a "bad Fly Wheel".
WI_Jeff is offline
post #14 of 20 Old 11-07-2011, 11:33 AM
oldsarge's Avatar
Of course ,the flywheel has been bad for 60 years and the ring gear is a top of the line Chinese product!!
oldsarge is offline
post #15 of 20 Old 11-07-2011, 05:59 PM
hey off topic but that is like the power steering pump i put on a tahoe the other day pulled the pulley off with the puller put the new pump on and went to put the pulley on the pump well it slid right on called the parts people and they treated me like i was dumb saying the pulley was too big, i said no when u measure the one shaft its 10 thou smaller then the pump i took off of it. then they proceeded to tell me i had to use their pulley, i guess they forgot i work on cars everyday of my life and their part was cra*. Basically chinese cra* sucks.
thenubsterman is offline
