2N dies when PTO engaged - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 15 Old 07-03-2011, 07:25 PM Thread Starter
My 2n will idle fine, run and turn brush hog when setting in neutral, but when you put it in gear and start to take off it bogs down and dies. Air filter has been cleaned and carb went through.
Thanks
Jeff
Lkyman is offline
post #2 of 15 Old 07-04-2011, 04:41 AM
dt5020's Avatar
Re: 2N dies when PTO engaged
i'm new here so i don't know your situation/skill level. but i had my 8n (had a 2n rear) in 1st gear, 3/4 throttle and engaged the bhog far enough away from the field to let the tractor and bhog get up to speed before getting into the hay.
you went through the carb, so i'm guessing you checked fuel flow. gov., vent holes & all linkage is hooked up.
I would then check for good spark at each plug, even if the plugs look good and appear to have good spark, i would still check the points, cap and rotor. since they are an easy to get to.
dt5020 is offline
post #3 of 15 Old 07-04-2011, 02:40 PM Thread Starter
Fixed!!!
Thought of it in the middle of the night. It had a complete tune up less then a year ago will all new parts. I had the carb rebuilt because it was running rich and wanted to flood out. Took out the plugs and cleaned them up and works perfectly. It does need new plugs but can get those tomorrow and get some mowing done today.
Happy 4th to everybody
Lkyman is offline
post #4 of 15 Old 07-04-2011, 02:49 PM
2_Late_I_Won's Avatar
Images: 3
awesome make sure you have the firing order correct too.
2_Late_I_Won is offline
post #5 of 15 Old 07-08-2011, 10:29 PM Thread Starter
Well, if it ain't one thing it's another!!
Started cutting out after mowing for an hour, died. I let bit cool down a nd it would run for just a bit and die. finally tonight pulled plug and no spark, pulled distributer and the points weren't opening. Got out my trusty FO-4 manual and there was no adjustment in the points, it looked like the plastic piece was wore down. Getting new points tomorrow.
Here is my question/s?
A) Is this common? the points are only 8mo old
B) Father-in-law put them in, could they have been put in to tight and cause the wear?
C) Having read the manual on installing points, I'm not to sure about the timing information. Do I install points and adjust to .015 opening?
Can someone explain figure FO83 to me and what it has to do with the points?
Lkyman is offline
post #6 of 15 Old 07-08-2011, 11:59 PM
As long as there is still a little bit of "finger" on the points, you could possibly adjust them to .015" and go again. No need for new points unless the finger is gone. If it is completely gone, check your distributor cam for rust or flaking. If it is rough, that is what is chewing your points up prematurely. Most of the time those Marvel Scheblers will not run rich unless the needle and seat is shot. They actually need to have the mainjet bored out a little bit to run really good.
Your governor may need rebuilt as well, as it may not be compensating properly for the additional load placed on the motor. This is a common problem in these old N series tractors.
Your coil may be a culprit as well if it is not applying the proper voltage to fire the spark plugs. This will give you a false "rich" reading on your spark plugs.
I am a vintage Ford tractor restoration mechanic. If you have any more questions, feel free to PM me. We have an original Sun distributor machine and I can rebuild your distributor for you without having the tractor here. I can also rebuild your governor as we have the original Ford governor tool from way back in our dealership days. Our shop is the midwest's specialty Ford restoration guys and have been keeping these things going for a long time. Check walthillservice.com if you want.
This is by no means to be read as a guy begging for work, only to let you know about our capabilities. There are a lot of tricks to these things that a lot of people dont know about. Believe me, I fix a lot of other "mechanic's" mistakes.
ShovelJockey is offline
post #7 of 15 Old 07-09-2011, 06:47 PM
souNdguy's Avatar
make sure the proper coil and resistor combo is present, otherwise points and coil will suffer and you will have degraded spark.
cam lobe lube will save the rubbing block too.
soundguy
souNdguy is offline
post #8 of 15 Old 07-09-2011, 07:58 PM
gears's Avatar
Mine did that too - I was figgerin that it was the cheap TSC points the PO put in, I reground the slot with a die grinder just to get it up and running - Napa points are next on my to purchase list.
ShovelJockey - could you make a post for the stickies section with some of these useful tips. like boring out the main jet and whatnot? Always like to learn tips & tricks!
Do it right or do it over.
gears is offline
post #9 of 15 Old 07-09-2011, 08:19 PM
souNdguy's Avatar
tsc sells tisco points.. with cheap rubbing blocks. deffinately have to use cam lobe lube and reset them when worn, as they usualy wear faster than a set of premium breaker contacts.
souNdguy is offline
post #10 of 15 Old 07-10-2011, 07:41 AM
gears's Avatar
That's what I figured
Thanks SouNdguy!
gears is offline
post #11 of 15 Old 07-10-2011, 11:04 AM
I've had a similiar experience with TSC points. Just put a set from NAPA in last month. We'll see how they hold up. The NAPA set was a bit pricier than the TSC parts but if you don't have to mess with em as much it $$$ well spent.
slip knot is offline
post #12 of 15 Old 07-11-2011, 05:08 AM
dt5020's Avatar
got mine from napa, used them for 2 years, then the resistor went bad, and burned them up? but never had to mess with the points after that.
Just cause it's orange don't make it a tractor, there's only one Allis Chalmers
dt5020 is offline
post #13 of 15 Old 07-11-2011, 11:24 PM
Yeah, I could do a few write ups. Working with my Grandpa who has been with Ford tractors since 1954 (as a dealer and mechanic) has afforded me a few little tips.
post #14 of 15 Old 07-12-2011, 11:49 AM
souNdguy's Avatar
yep.. many napa's sell standard ignition or bluestrak points. sometimes upwards of 18$.. way more money than 54 tisco points.. but.. I have blue strak poitns going on 10ys now.. and tisco points.. well.. lets jsut say I have a jar full of them from old ignition kits from tsc. i keep em handy for emergencies.. but i don't actually use them..
the rubbing blocks are a soft plastic compaired to a harder plastic or nylon, or a phenolic rubbing block found on premium sets.
again.. cam lobe lube is a must on all of them.
soundguy
souNdguy is offline
post #15 of 15 Old 07-18-2011, 07:36 PM Thread Starter
Inner arm on the governor is broken.
thanks
Lkyman is offline
