1952 Ford 8N value - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 20 Old 08-27-2010, 12:07 PM Thread Starter
1952 Ford 8N value
Guys, I have no idea about current day value of something such as this. Does having 12 speeds make that much difference? It's a tractor not a race car. Please give me your over all opinion regarding the price for the tractor and attachments...
Thank you very much. http://columbus.craigslist.org/grd/1921956370.html
Randy
One other thing, how much would this weigh with the cutter hanging on back? I'm thinking about what size of trailer I would need if I wanted to start cutting small fields etc.
Randy
Cubs: 71, 73, 127, 149, 1440, 2186, GT1554, and 1864
John Deere 110 round fender
Sears: GTV16
rwairforce is offline
post #2 of 20 Old 08-27-2010, 12:16 PM
Retired MTF Admin
Ken N Tx's Avatar
Images: 60
Re: 1952 Ford 8N value
Here are some going prices around the country..CLICK HERE..
I have never hauled one, but a neighbor has used his 16' tandem utility trail bumper pull with no problem.
Ken N Tx is offline
post #3 of 20 Old 08-27-2010, 12:24 PM Thread Starter
Thanks Ken.
Looks like there all over the place on the value meter.
Is that 12 speed trans something to avoid or is it ok, I'm thinking realiable when I say ok.
Randy
Sears: GTV16
post #4 of 20 Old 08-27-2010, 12:29 PM
Retired MTF Admin
Ken N Tx's Avatar
Images: 60
Originally Posted by rwairforce View Post
Thanks Ken.
Mine has an 8 speed..It comes in handy at times..
Ken N Tx is offline
post #5 of 20 Old 08-27-2010, 12:35 PM
Retired - Veteran Mod
Steve (Magnolia, TX)'s Avatar
Images: 13
...Is that 12 speed trans something to avoid or is it ok, I'm thinking realiable when I say ok.
I don't have an auxillary transmission in my 8N (and a 12-speed is the standard 4-speed transmission... with an over/under drive auxillary tranmission added in) so I can't speak "authoritatively" to it, but...
From what I've heard... the transmissions are quite reliable... as long as they are shifted by a lever rather than a cable (and I don't recall if there was ever an over/under with a cable shift or not)... and the only "unreliable" part of the cable shift was that after 50 or 60 years of use (and abuse?) the cable had a tendancy to rust through and break... and they were "challenging" (to say the least) to find replacments for.
post #6 of 20 Old 08-27-2010, 12:38 PM Thread Starter
Thanks Steve.
Finding parts is always a concern when looking at something so old. It's the same age as me but I could probably find parts for myself easier....but way more costly.
Randy
Sears: GTV16
post #7 of 20 Old 08-27-2010, 12:38 PM
Retired MTF Admin
Ken N Tx's Avatar
Images: 60
Steve, mine is the cable..
Ken N Tx is offline
post #8 of 20 Old 08-27-2010, 12:39 PM
Images: 13
Well... actually, the standard parts for the 8N are EASY to find... and pretty affordable (for the most part) too.
Now... add-ons (like the auxillary transmissions) and your "not commonly replaced" parts (such as castings, etc) are a bit harder to come by...
post #9 of 20 Old 08-27-2010, 12:45 PM
Retired MTF Admin
Ken N Tx's Avatar
Images: 60
My Hi/Lo cable.
Sherman 12 speed.
Ken N Tx is offline
post #10 of 20 Old 08-27-2010, 12:53 PM Thread Starter
Great, so that cable runs down inside the case, making it a big job to replace.
The seller mentions the PTO upgrade, is that still a standard size? I don't want to be limited to only special implements that can be attached.
Thanks a lot guys.
This little guy is interesting to me because I used to rake hay when I was 16 and it was just cool. It was the first spread frontend tractor I had driven and I felt safer on it than our IH Super C.
Would it be a good tractor to mow say a 5 to 10 acre field?
Randy
Sears: GTV16
post #11 of 20 Old 08-27-2010, 01:00 PM
Images: 13
Thanks a lot guys.
PTO upgrade. Kinda depends on who's telling you, as to what he's referring to.
I would call a PTO upgrade a replacement shaft... making it the SAE standard 1 3/8" (stock was 1 1/8")... making it easier to attach implements... although you WILL want to ensure that you've got an ORC (OverRunning Clutch) installed... speaking of which... this *may* be the 'upgrade' that the seller is referring to.
As to mowing... this tractor is ideal for mowing 5 - 10 acres. I just mowed about 10 acres of hay with mine (and my John Deere #5 Power Mower) on Sunday... then raked all that hay on Wednesday.
post #12 of 20 Old 08-27-2010, 01:04 PM
Retired MTF Admin
Ken N Tx's Avatar
Images: 60
The only PTO attachments that I have ever used were the mower and post hole digger. Thats about all that is used today.
Ken N Tx is offline
post #13 of 20 Old 08-27-2010, 01:10 PM Thread Starter
Thanks guys....
He does mention "new upgraded 1 3/8 pto shaft with new pto overrider clutch"
In his ad.
Is there anything else I should look for on this tractor? Any typical failure items that I should inspect?
Thanks again.
Randy
Sears: GTV16
post #14 of 20 Old 08-27-2010, 01:10 PM
Old 'n Cheap
ryork's Avatar
Images: 9
I finish mow my 10 acres weekly. Does a great job. If you have a lot of trees, shrubs, etc it makes it a little tougher.
Old 'n Cheap
Bad part of being older...you can remember when things that now cost $10 were only 50 cents
46 2n - waitin on me to do something to it.
47 2n - my relaxin tractor.
64 4000 - w/7 ft finish mower, scoop and bushhog.
ryork is offline
post #15 of 20 Old 08-27-2010, 01:15 PM
Retired MTF Admin
Ken N Tx's Avatar
Images: 60
Thanks again.
READ THIS
Ken N Tx is offline
