need advice on 5665 ignition switch install
3K views 3 replies 4 participants last post by  PA RedRider
#1 ·
I am trying to save 1980 5665 and bring it back to life to compliment my 1968 commercial 10a. I am trying to relace ignition switch.
I have matched up all but one of the wires. I got the gravely replacement part from jack's small engine and I think it is correct. The old switch has a terminal labeled ground but the new switch does not. It has S, I, A, B, R. Where should the G wire from old switch match up to? The old switch has G, Ign, Acc, Ign 2, Battery, S. There are only four wires. I have the B, I, A matched up. Should the ground from old ignition go to the S or R?
#4 ·
Does the wiring harness not have a Packard connector on it?
