Jd 2030 Pto - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 13 Old 08-05-2009, 09:37 AM Thread Starter
gaz
Jd 2030 Pto
Hi all have noticed a few members have this model. I have brought my dads 1975 JD 2030 back to life lately but have noticed that the PTO turns constantly i seem to remember when it was going years ago that when you attached an implement if the pto was not engaged with the lever. the weight of the attachement would stop the shaft turning.Now it turns all the time. Any body any ideas what could be wrong.
gaz is offline
post #2 of 13 Old 08-05-2009, 09:45 AM
Member
John Deere Addict's Avatar
Re: Jd 2030 Pto
We had 2 JD 2030's. Nice tractors!
Here is what I'd try..... since the tractor has sat (presumably by your mention of bringing it back to life) idle for some time, perhaps the disks have bonded together. Try running a piece of equiptment with the PTO lever in the off position and see if it will eventually break themselves loose.
Nothing runs like a Deere!
Where The Big Boys play..
John Deere Addict is offline
post #3 of 13 Old 08-05-2009, 02:24 PM
10,000 +posts!
Re: Jd 2030 Pto
Gaz, i have nothing to add to JDA's reply. BUT i am sure others would love this too. Some pictures of your part of the world. Can you snap a picture or two of your place? BTW come back to chat any time. It was nice talking with you.
Team_Green is offline
post #4 of 13 Old 08-05-2009, 09:23 PM
jd110's Avatar
Re: Jd 2030 Pto
There were a couple of options on types of PTO. Do you have the lever that you pull up in between the gearshift levers? That is the independent pto. With that type, there is a brake band inside the transmission that stops the pto. It is applied using transmission oil pressure. Chances are that you have a broken band or a brooken oil line that sends pressure to activate it. Either pproblem requires splitting the tractor between the transmission and clutch housings. If you don't want to split tractor, there should be a disconnect lever by your left heel you can disegage to stop from turning.
Some of the 2030's had a two stage clutch, that requires pushing clutch all the way to the floor to disconnect the clutch and it used the same lever by your left heel to engage and disengage the gears. If this is the type you have, then either the clutch is stuck or out of adjustment.
jd110 is offline
post #5 of 13 Old 08-06-2009, 06:30 PM Thread Starter
gaz
Re: Jd 2030 Pto
Thanks, my tractor has not got a lever at my left heel. I think i am going to eventually split the tractor, have discovered a more worring problem there is a big crack in the head! I have stripped the head off and am leaving it with someone to weld it hopefully it works.
gaz is offline
post #6 of 13 Old 08-06-2009, 09:22 PM
jd110's Avatar
Re: Jd 2030 Pto
That's a little unusual for these to crack. Do you think it froze? Is it gas or diesel? Where is the crack?
jd110 is offline
post #7 of 13 Old 08-07-2009, 04:23 AM Thread Starter
gaz
Re: Jd 2030 Pto
I dont think there was enough antifreeze! I have included a few photos hopefully the crack isnt in a difficult place.
gaz is offline
post #8 of 13 Old 08-07-2009, 04:27 AM Thread Starter
gaz
Re: Jd 2030 Pto
Dont think the photos worked by the way the tractors diesel petrol is way too expensive over here.
gaz is offline
post #9 of 13 Old 08-09-2009, 02:44 PM Thread Starter
gaz
Re: Jd 2030 Pto
I have cleaned the crack up and grooved it to take the weld hopefully it holds.Attached a photo hopefully it works.
gaz is offline
post #10 of 13 Old 08-09-2009, 08:55 PM
jd110's Avatar
Re: Jd 2030 Pto
Be sure to replace the freeze plug that is visible in the photo. It looks like it is pushed half-way out. I assume you are going to use nickel welding rod?
jd110 is offline
post #11 of 13 Old 08-10-2009, 02:28 PM Thread Starter
gaz
Re: Jd 2030 Pto
I have left it with a neighbour hes a mechanic he says he'll use special cast rods. I spoke to a breaker he has a head but hes looking 150! another breaker has a head off a 2140 he said it should fit hes looking 80. Will try the welded head and see how it works first.
gaz is offline
post #12 of 13 Old 08-10-2009, 04:33 PM
JD1010's Avatar
Re: Jd 2030 Pto
Keep us posted, I hope it works. I spent some time in Europe, and know how expensive fuel was back then (about 15 years ago). Can't imagine it got cheaper.
Phil
JD1010 is offline
post #13 of 13 Old 10-13-2009, 01:54 AM
BLUEPAINT's Avatar
Re: Jd 2030 Pto
We had 5 2030's and 2130's over the years including a OPU cab with the pto on the dashboard and i think we did the pto brakes in all of them at some point.......Nice to see a duncan cab we still have a 2030 with this cab..!
BLUEPAINT is offline
