Jd 5425 - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 7 Old 11-23-2008, 12:29 PM Thread Starter
Jd 5425
I have a JD 5425 that won`t start for the first time. Turn switch on, all dash lights come on and stay on until switch is turned off. This is not normal. Starter does nothing. What are the dash lights telling me? I mean all dash lights come on. This must be some kind of indicator. Thanks
bravo is offline
post #2 of 7 Old 11-23-2008, 12:54 PM
skcsbrh's Avatar
Images: 10
Re: Jd 5425
Sounds like it could be the ignition switch.
A Day Inport Is Like A Day Without Sunshine!
USS TULLIBEE (SSN-597), USS FULTON (AS-11), USS PAIUTE (ATF-159), USS BAINBRIDGE (CGN-25), USS ASHLAND (LSD-48), USS GRAPPLE (ARS-53) Naval Station Guam, US Forces Carribean Key West FL, EOD Group Two VA, Allied Command Atlantic (NATO), VA.
skcsbrh is offline
post #3 of 7 Old 11-23-2008, 09:10 PM
jd110's Avatar
Re: Jd 5425
Have you tried to jump-start it? Sometimes low voltage can cause the instrument panel to not complete it's bulb check. I would suspect a bad battery, cable, or dirty connection. Also be sure that neutral switches on transmission and pto are in neutral. Does the starter click at all? Is this a reverser or sync shift? Is it a cab tractor or open station?
jd110 is offline
post #4 of 7 Old 11-24-2008, 02:34 PM Thread Starter
Re: Jd 5425
My JD 5425 is open station, sync shift. I have not tried to jump start it. The battery seems to be OK. I did a slow 12hr. charge on it. I have not had any trouble starting the engine in the past, but the weather has gotten cold. In the thirty`s here, so the battery could be weak. There is no click, chatter, nothing at all that would indicate the starter is trying to kick in. Normal starting is when I turn the switch on, 4 beeps, gauges check, and I start the engine. Now I turn switch on all dash lights come on including signal directional arrows(not blinking) instrument panel illumination, indicator lights, and gauges, no beeps. I turn switch to start and nothing. The dash panel lighting up like this must be telling me something, but I don`t know what. It is possible it is the battery. Tractor has 540hrs. and is a 2005. Thanks for any help you can give me. All switches in neutral (PTO, Trans.), Cleaned battery terminals. ???????
bravo is offline
post #5 of 7 Old 11-25-2008, 06:49 AM
Just passing through
Upper5Percent's Avatar
Re: Jd 5425
I would have your battery tested...
Here are your manuals online...
http://manuals.deere.com/omview/OMRE260579_19/?tM=
http://manuals.deere.com/omview/OMRE260580_19/?tM=
DWIGHT D. EISENHOWER
Upper5Percent is offline
post #6 of 7 Old 11-25-2008, 12:56 PM Thread Starter
Re: Jd 5425
Paul, I had the battery tested today, it tested good. Thanks for the manuals. I did not know there is a fuse link at the battery. I will check this and hook up the battery and see what I can find. Thanks again.
bravo is offline
post #7 of 7 Old 11-25-2008, 05:42 PM Thread Starter
Re: Jd 5425
The fuse was good. I put the battery back in the JD, turned switch on, all was normal, hit start and she fired up. I don`t know what was wrong. She cured her self, so I`m a little nervous about that, but glad its running. Is it possible that something reset when I disconnected the battery, I don`t know. Anyway just letting you know what happened. Thanks to all for trying to help.
bravo is offline
