hydrolic problem on a 5300 - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 8 Old 07-05-2008, 03:40 PM Thread Starter
Brian H's Avatar
Images: 5
Hello I am new here but at work we have a JD 5300 with a JD 540 loader I use the tractor alot and I changed the hydrolc fluid a few week ago (10 gals) and it worked fine untill some one new used it now when you lower the loader bucket a hydric sqeal noise happens and it straineds the motor but you can lower the bucket slow with out the sqealing noise by not pushing the lever all the way forward, Any one had or heard of this problem?
Thanks ,
Brian
Brian H is offline
post #2 of 8 Old 07-05-2008, 03:53 PM
Just passing through
Upper5Percent's Avatar
Re: hydrolic problem on a 5300
You did use HyGard when you replaced the fluid, correct?
You have checked the fluid level, correct?
I assume you cleaned the screen as well as replacing the filter?
If you didn't clean the screen, then the squeal is probably the relief valve...
DWIGHT D. EISENHOWER
Upper5Percent is offline
post #3 of 8 Old 07-05-2008, 04:18 PM Thread Starter
Brian H's Avatar
Images: 5
No, I used "NAPA AW46" hydraulic oil oops did I screw things up? I told my superviser that the book called for the Hygard stuff but he sayed its all the same. and I did change the filter and cleaned the screen (some metal bits in it) Thanks for the quick reply
Brian
Brian H is offline
post #4 of 8 Old 07-05-2008, 06:42 PM
Brian
Well, I've never had a problem in JD equipment using HyGard...
https://jdparts.deere.com/partsmkt/d...nHydraulic.htm
Service Ratings
AGCO
Massey Ferguson: M1135, M-1141,
M1139, M-1143
White: MQ-1722, Q1766, Q-1766B,
Q-1802, Q-1826
Allis-Chalmers, Deutz-Allis, AGCO Allis:
Power Fluid 821XL
CNH
Case, Case-IH: MS-1207, MS-1209,
MS-1210, MS-1
Ford/New Holland: ESN-M2C41-B,
M2C134-D, M2C48-B, M2C48-C,
M2C159-B/C, 159B/C, M2C86-B,
FNHA-2-C-200, FNHA-2-C-201
Caterpillar: TO-2
Clark: MS68
Deutz: Hydraulic transmission fluid
Dresser: Transmission hydraulic fluid
(HMS B806-0002)
Eaton Hydraulic Division: Hydraulic transmission (Form3-401-123)
IHC: B-6
John Deere: All-weather hydraulic fluid
(JDM J21A)
Kubota: UDT hydraulic transmission fluid, Super UDT
Oliver: Type 55
Sunstrand: Hydrostatic transmission
Zetor: OT-H, GL-4
ZF: TE-ML03E, 06D, 06E
http://www.deere.com/en_US/parts/par...hydraulic.html
post #5 of 8 Old 07-05-2008, 07:24 PM Thread Starter
Brian H's Avatar
Images: 5
So the stuff I putin there is ok. Tomorrow I will look at the book and look at the valveing parts on it
Thanks
Brian H is offline
post #6 of 8 Old 07-05-2008, 08:22 PM
jd110's Avatar
It sounds like you have a restricted hose or fitting somewhere. I would look closely at all of the lines and hoses from the loader control valve to the loader boom. Make sure there are no kinked hoses or oil lines. Could also have a cylinder problem. I doubt the oil is the problem, although I do prefer using original equipment oil.
jd110 is offline
post #7 of 8 Old 07-06-2008, 06:35 PM Thread Starter
Brian H's Avatar
Images: 5
Ok thanks, I did not have time to look at today had to clean up after the 4th but I will start looking next week
Thanks
Brian H is offline
post #8 of 8 Old 07-10-2008, 03:29 PM Thread Starter
Brian H's Avatar
Images: 5
OK! Thanks for all the help it was a quick coupler had come loose. thank for all the help!!
brian h
Brian H is offline
