John Deere 5425 PTO question - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 8 Old 05-26-2011, 06:40 PM Thread Starter
I have a John Deere 2008 model 5425 cab tractor that I just bought. I noticed when hooking to my Vermeer 5410 baler the PTO shaft does not turn by hand to allow me to line the splines up and slide the drive train of the baler onto the PTO shaft. Every other tractor we have allows the PTO shaft to turn by hand. Dealer says this is just how the tractor is made, but same makes no sense to me. Anybody else have this issue or know of this issue? Thanks.
kf54830 is offline
post #2 of 8 Old 05-26-2011, 06:43 PM
SonnyT's Avatar
Images: 26
Re: John Deere 5425 PTO question
Sorry I don't know. I thought they all turned?
If you need easy Picture help
Be sure to Register for Your State!
RIP Sonny T.
1954-2015
SonnyT is offline
post #3 of 8 Old 05-26-2011, 07:11 PM
scm
Turn the engine off and see if it turns freely. I haven't had that problem with my 5203 but the New Holland 3930 i used to have if the engine was running it wouldn't turn by hand.
2007 John Deere 5203 2009 John Deere X500 48'' deck 2010 John Deere X300 42'' deck And too many attachments to list
scm is offline
post #4 of 8 Old 05-27-2011, 09:30 AM
MF283's Avatar
hmm, all these years, i've just turned the shaft on the implement because i always apply a lil grease to the PTO shaft & didn't want to get grease on my hands
Ronnie
MF283 is offline
post #5 of 8 Old 05-28-2011, 05:47 AM
Originally Posted by kf54830 View Post
I noticed when hooking to my Vermeer 5410 baler the PTO shaft does not turn by hand to allow me to line the splines up and slide the drive train of the baler onto the PTO shaft. Thanks.
Most ind pto tractors have a brake on the pto.If one shuts tractor off(safest way to hook/unhook an implement pto) then normally brake will release because of lack of hyd pressure.
My JD 467 rd baler has a coupler on the pto shaft that allows one to rotate pto about 10 degrees to align splines
Tx Jim is offline
post #6 of 8 Old 05-30-2011, 11:01 PM Thread Starter
My 5410 baler drive train will not turn so that compounds the issue. Our other tractor is a Case IH CX90 and th PTO shaft turns on it with engine off. The John Deere tractor even when off will not turn by hand. Frustrating.
kf54830 is offline
post #7 of 8 Old 05-31-2011, 09:35 AM
Have you ever tried turning 5425 pto shaft with the "engine off" with the aid of a pair of slip-joint pliers?
Tx Jim is offline
post #8 of 8 Old 05-31-2011, 09:02 PM Thread Starter
No not yet but I will try that next, but I am baling too much right now. We have a dry week in TN so we are cutting a lot. Once that is done and I disconnect the baler I'll try that. Thanks.
kf54830 is offline
