Farmall 560 with TA issues - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 5 Old 07-09-2009, 08:26 PM Thread Starter
keevel's Avatar
Greetings all,
I found a Farmall 560 with a loader about 100 miles away.
I haven't looked at it yet, but the owner says it starts and runs well. He also says "The TA works on the high side but not the low side." I'm a bit confused in that I thought the TA was the low side of each gear- the high side being direct drive. What could I be missing here? Anyplace you could recommend to me to learn all about Torque Amplifiers?
Thanks for your comments!
-Keevel
"My father kept me busy from dawn to dusk when I was a kid. When I wasn't pitching hay, hauling corn or running a tractor, I was heaving a baseball into his mitt behind the barn... If all the parents in the country followed his rule, juvenile delinquency would be cut in half in a year's time."
- Bob Feller Van Meter, Iowa - Pitcher Cleveland Indians; Baseball Hall of Fame Induction 1962
keevel is offline
post #2 of 5 Old 07-09-2009, 08:57 PM
xdiver86's Avatar
Re: Farmall 560 with TA issues
Keevel You are right. The high side is direct. For a better explaination see your friendly Case-IH dealer. At least this will let you know where you stand.
Aaron
Still looking at the green side of the grass Looked out the backdoor....My ain't it purtty out here!!
xdiver86 is offline
post #3 of 5 Old 07-09-2009, 09:55 PM
Grateful11's Avatar
Try here:
http://www.redpowermagazine.com/forums/
'11 John Deere 5065M /cab
'10 Kubota L3940 w/FEL
'09 JD X720
'91 CaseIH 5140 Maxxum w/cab
'78 IH 686 w/M&W Turbo 106 PTO hp w/canopy
Grateful11 is offline
post #4 of 5 Old 07-09-2009, 09:56 PM
Szrachnor's Avatar
When the Torque Amplifier is in direct drive(or the handle is forward) you get the normal 5 speeds of the tractor. When the T/A clutch is disengaged(handle pulled back) then you go into low gear. In the attached picture when you are in direct drive item numbers 1, 16, 31, 32, 35, and 36 all spin at the same time, speed and direction as the engine. When you engage the T/A, you are releasing the clutch disk #35 so that pressure plate #36 and flywheel #32 stop spinning along with the planet carrier #16. The power then goes from clutch disk #35 through the shaft #31 into the planet gears #22, gets reduced by 1.482 to 1 and then comes out the shaft #1. At this point what is supposed to happen is that over-running coupler #11 is supposed to keep planet carrier #16 from spinning opposite of engine rotation. If the planet carrier #16 spins in the opposite direction then no power gets to shaft #1 and the tractor stops.
So the problem that the seller is describing is typical of over-running coupler(#11) failure. Although it's an easy fix, the amount of time to get to it usually makes most people either live with it or replace/rebuild the entire T/A while they have it apart. The tractor will continue to function as a normal 5 speed as long as you don't pull the handle back.
-Leon
Szrachnor is offline
post #5 of 5 Old 07-09-2009, 11:17 PM Thread Starter
keevel's Avatar
Thanks for the replies- love the attached exploded view Szrachnor- and the explanation. If the rest of the tractor is pretty sound, I'll probably pick it up and do a rebuild over the winter. The other tractor I was looking at was an IH 330 with minimal issues. I'll nose around the redpowermagazine forums and see what else I can learn.
-Keevel
keevel is offline
