farmall 400 fluids - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 3 Old 06-05-2009, 10:32 AM Thread Starter
farmall 400 fluids
I am new to tracors, but I already love my 4oo. But, I cannot figure out exactly where to check and fill the hyfraulics or gear oil. I know where to chek the engine oil, but I am not sure where to fill it. What type of fluids does it use? Please help!
Thanks
barry t is offline
post #2 of 3 Old 06-05-2009, 06:29 PM
Member
Andy Motteberg's Avatar
Re: farmall 400 fluids
The engine oil filler is on the right-side on the engine, the filler neck/cap is on the timing cover. The hydraulic tower is under the steering column. There should be a plug on the side, it is the filler and there is also a dipstick on it to see the oil level. Hydraulic oil works well in the hydraulics, 10w30 or 10w40 works good in the engine, use 80-90 gear lube or hy-tran in the transmission. You should buy a owners manual, it will help a lot.
1943 Farmall H
1949 Farmall M
1938 Farmall F-20
1949 John Deere A
1941 John Deere B
Andy Motteberg is offline
post #3 of 3 Old 11-25-2009, 03:22 PM
IH addict!
TX1256's Avatar
Images: 3
I belive IH calls for SAE30 in the engine, and gear oil 80w90, in the transmission. Im pretty sure you do not want to use Hy-Tran in that transmission, but I could be wrong. As Andy said, an owners/operators manual is what you need.
Farmall 1256
Farmall 806
Farmall M
Farmall H (x3)
Farmall F-20
IH 3444 T/L/B
IH Cub Cadet 782
Massey - Ferguson 245
John Deere LT-166
TX1256 is offline
