IH 424 3 Pt Won't Work after Hydraulic Filter Change - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 4 Old 04-22-2010, 09:31 AM Thread Starter
I drained my hydraulic oil and cleaned the screen/filter on my 424, but after refilling it the 3 point hitch doesn't move. Moving the lift lever or the draft control levers have no control of the hitch. I can grab the 3 pt arms (while engine is running) and lift them all the way up its like some linkage is disconnected. The power steering works fine so the hydraulic pump is working.
Anyone have a good starting point on trouble shooting this?
IHC 424 Diesel
dieselscout80 is offline
post #2 of 4 Old 04-23-2010, 10:59 PM Thread Starter
Re: IH 424 3 Pt Won't Work after Hydraulic Filter Change
I popped the cap off the pressure line tee where it connects into the flow divider that separates the power steering from the 3 pt hydraulics and it shot oil out after a second or so,
Can the flow divider that separates the power steering from the 3 pt hydraulics stick?
I had very little flow out the orifice valve screen port when running and none out the auxiliary port.
IHC 424 Diesel
post #3 of 4 Old 05-01-2010, 03:57 PM Thread Starter
Well today a bleed it somemore (more like took a hydraulics shower ) at the flow divider and it started working.
IHC 424 Diesel
post #4 of 4 Old 05-12-2010, 09:26 PM
TheLawnRanger's Avatar
Air in the hydraulics will do it everytime.
I have has similar issues on occasion with my IH404.
TheLawnRanger is offline
