Gilson / Montgomery Ward wiring help. - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 11 Old 12-23-2009, 06:11 PM Thread Starter
wurkenman's Avatar
My turn to beg for help. I have a Gilson made Montgomery Ward Variable Speed 16.
I am having some wiring problems. I just put a new battery in it and started to
track down some of the loose wires and try to put them back. Does anyone have a
close up view of the back of the ignition switch? I have a manual, but the area
for the switch is not so readable. If anyone could show me a switch with the
terminals labeled, I would be grateful.
Thanks
Terry in Minn.
wurkenman is offline
post #2 of 11 Old 12-23-2009, 07:54 PM Thread Starter
wurkenman's Avatar
Re: Gilson / Montgomery Ward wiring help.
Forgot to mention model #GIL 33183A.
Thanks
post #3 of 11 Old 12-24-2009, 01:18 PM
JustinR's Avatar
All I have for stock photo's, hope this helps.
Original Bolens 1250 - Restored Bolens HT-18 - 1386 Water Cooled Yanmar Diesel Loader w/ Powersteering - Restored FMC Bean Cutler - Project 1477 - Troy Bilt GTX 20
http://huskylargeframes.blogspot.com/
http://www.youtube.com/user/jtube76?feature=guide
JustinR is online now
post #4 of 11 Old 01-07-2010, 02:48 PM
I have a 8hp montgomery ward tractor I am looking for the double pulley. Can anyone help?
dan79 is offline
post #5 of 11 Old 01-24-2010, 11:24 PM Thread Starter
wurkenman's Avatar
I'm still not sure. I have this switch on my tractor, but I can't seem to find a schematic for this switch. Could someone fill me in on where to connect.
Thanks
Terry
http://s421.photobucket.com/albums/p...rrent=ign6.jpg
post #6 of 11 Old 01-24-2010, 11:30 PM
CalifornianGravelynator
rustyrideon68's Avatar
i fried to electricle system on mine use a pair of chanel locks and a screw driver to start it and it doesnt charge batt got to hook it up every week.
Romans 1:16 "For I am not ashamed of the Gospel of Christ..."
My name is Mike and I own these tractors, a...
68 Gravely 430 (40" Comm mower)
80 Gravely 8163-T (L.S.D trans)
(Mighty Mac Shredder)
67 Gravely 424 (40" kidney mower)
66 Gravely C8, with Governor and soon elec start. Rotary Plow, Rotary cultivator, and 30" deck x2
48 Gravely model L ,G.R.Hs with rotary plow
?? Gravely 5660 30" finish mower
72 Gravely 814, cig lighter parts machine(NFS)
72 Simplicity Landlord 3410 H with MM grading blade.
7? Allis Chalmers 314 D with Electric lift 3pt, tiller and 42" MM mower
74 Wheel horse D-160, 3pt, rear scraper blade. in sad shape.
79 (MTD) Dayton 11hp but looks great, "Survivor" ,and a 72 (Gilson)Wards 16 hydro w 48" MM mower
78 John Deere 214, 38" mower + brass tag snow plow ( I dont really need the snow plow). project. will get Onan 18hp. when its repaired
79 Sears LT 10/36 MMM.... also have a 70s HAHN LTD 500 RER, Electric conversion, when I have $
78 Sears GT/19.9 Six Spd with a Loader, dually, WW, MMM, Waren elec 3pt, dump tote box, disc harrow, Front mount shredder, rear scraper blade, Onan N52M-GA. low hours machine
81 Sears GTV Custom. Will get Wisconsin 18.5 hp THD. may have a Turbo. Or a 27hp Kohler needs a bore and .10 oversize pistons ....Nothing runs like a deere running from my GRAVELYS.................................. THE
87 Pontiac Fiero GT V6 3spd...69 Dodge A-108 Sportsman ,318 ,3spd man. McCulloch 10 (MAC 10) 2 vintage backpack blowers, 1953 Briggs and Stratton 6S , a B&S 1950 5S too with Firestone plug. GO BUCKS! OHIO State U
rustyrideon68 is offline
post #7 of 11 Old 01-25-2010, 03:26 PM
Qtrmooner's Avatar
I will see what I can do for you. It may take until next weekend. I have one with the gas tank out to chase wiring. It's behind the shed in the mud and working Dark to Dark. I know the Manuals aren't very clear.
'08 JD LA165 48"
'73 MW Gilson 16hp Hydro Loader
'05 Cyclone Rake :]
Mac 10-10 16" bar
QtrMOONer... 'nuf said... It always cost me to sell anything!?!
Qtrmooner is offline
post #8 of 11 Old 01-25-2010, 09:04 PM
GardenTractorSue's Avatar
Wurkenman,
On the blades of your ignition switch they will be marked with a letter : B for battery -- goes to big bolt on battery side of solenoid, M for magneto -- magneto wire, G for ground -- to engine or frame, if engine mounted on rubber go from motor to frame, then frame to ignition switch, L for lights -- or load, such as horn, etc, S is for starter solenoid -- small nut/bolt on solenoid.
DO NOT USE a switch that is identical but has an "I" instead of the "M" on one of the blades! The "I" is for an ignition type (through coil) and will burn up the magneto if you try to use it.
Hope my girlie explanation helps...lol.
Sue
GardenTractorSue is offline
post #9 of 11 Old 01-25-2010, 09:07 PM
Dan79,
Do you need a double pulley for the engine? Is your Monkey Ward made by Gilson? Any more info you can give me? My Dad may have one but I need more info...
Sue
post #10 of 11 Old 01-25-2010, 11:19 PM Thread Starter
wurkenman's Avatar
Thanks everyone for the help. My switch is not the original. It is the one pictured in the link on my last post. I am happy to report, that through trial and error I got it wired. Good thing too, down to my last fuse. At least it will start and turn off with the key now without blowing fuses. I still have not checked to see if it is charging, but at least I can use it now. Not a moment too soon either, we are getting more snow here and it is not enough to justify gatting the Case out with the snowblower, so now I can use the old Wrads with the plow.
Thanks
again
Terry
post #11 of 11 Old 05-14-2015, 01:23 AM
freeonthree's Avatar
Thanks
Terry
Wheel Horse 430-662 Photo by mywoodennickel | Photobucket
Do you have an ohmmeter with a continuity buzzer ?
A test light and a battery will work too.
For starters, locate the two poles that are shorted in the crank position.
Next, one of those two poles you just found (crank) will be shorted to another pole in the on position.
At that point you have batt in, ignition (coil power), and crank (to S terminal of the selonoid. The remaining two are shorted in the off position for killing magnet driven ignitions. One terminal goes to ground, and the other to the ignitions kill wire. Dennis
freeonthree is offline
