Best way to calibrate my barometers? - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
The Weather Station Post your Weather related Threads here.
post #1 of 5 Old 04-06-2012, 12:05 PM Thread Starter
ggsteve's Avatar
I have four aneroid barometers that I have calibrated to the cheap Sharp electronic weather station I got for Christmas. I'm assuming this isn't super accurate way to set them.
I found the website localconditions.com and used my zipcode to get a pressure, which is currently reading 0.51 inches of Mercury higher than all of my barometers, but I don't know a) how often it updates or b) is the pressure where ever their barometer is likely to be the same as the pressure at my house? Is anyone familiar with the accuracy of this website?
Any other suggestions as to how I can get the best local reading to calibrate against? Thanks!
ggsteve
68 JD 112H 47 deck 43 blade
69 JD 110H 37A blower 50 cart
71 JD 140H1 80 Cart
72 JD 110 parts
78 JD 316K 49 blower
84 JD 214 39 deck 43 blade
Woods box blade
74 Concord (MTD) 990
ggsteve is offline
post #2 of 5 Old 04-06-2012, 06:50 PM
We're all friends here
APinNY's Avatar
Images: 5
Re: Best way to calibrate my barometers?
Steve, I believe the static barometer reading is not as critical in forecasting as the barometric trend. Having said that, do you have a neighbor with an accurate weather station that you could comare with?
Al
Kubota BX1860, 48" fine cut mulching MMM, FEL, snow thrower, cab, Heavy Hitch
TroyBilt LTX 13, (given away)
DR Lawn Vacuum. Review here
APinNY is offline
post #3 of 5 Old 04-08-2012, 02:04 AM
Martian Wx Moderator
Mark / Ohio's Avatar
Images: 7
I originally set mine per the airport about 6 mile away. I actually can pick up their automated weather channel on my police scanner. You could also go to WeatherUnderground.com and look at any other personal stations in your area. They also show time of last update there. Be careful though using personal weather stations instead of the airports. They are only as accurate as the time spent by the owner keeping track of them. A few of them are pretty bad so compare the closet reading to you with that of others in the area to see if it looks reasonable.
Best time to adjust it is during a long steady spell. With a mechanical barometer a steady 30.00" weather spell is ideal.
Mark -2002 John Deere LT150H
Mark / Ohio is offline
post #4 of 5 Old 04-08-2012, 07:31 AM
Banned!
You could also try this...
http://www.youtube.com/watch?v=NK5uF0soE5g
JimD is offline
post #5 of 5 Old 04-08-2012, 12:30 PM Thread Starter
ggsteve's Avatar
Thanks guys! I watched the video, then I checked the conditions at our closest air port, then compared that with information from Weather Underground (they were the same). So I calibrated to those figures. Pressure is dropping here. Possible rain tomorrow.
Boy, finding the adjustment screw inside the case on my newly acquired Chelsea barometer is a PITA. At least I shouldn't have to adjust it for awhile now.
ggsteve
71 JD 140H1 80 Cart
72 JD 110 parts
Woods box blade
ggsteve is offline
