Gravely Engine Swap - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 20 Old 09-22-2009, 01:21 PM Thread Starter
Gravely Engine Swap
I have a 430 Gravely with a 12HP Kohler that runs good and a 816 Gravely with a bad engine.Can I put the 12HP Kohler out of the 430 in the 816?
gburnett is offline
post #2 of 20 Old 09-22-2009, 01:24 PM
Bushbuck's Avatar
Re: Gravely Engine Swap
when you remove the two engines if the shaft and the mounting plate is the same than yes you can.
Bushbuck is offline
post #3 of 20 Old 10-02-2009, 02:30 PM
gravelymay's Avatar
Hi
Short answer is NO
The 400 engines will fit the 2 wheel tractors with turned down Crank.
The 800 8000 and all the 8 speed trans are a like
Their Cranks are 1 1/8 X 3 1/2 to 4.00
Thanks Bruce g
gravelymay is offline
post #4 of 20 Old 10-02-2009, 08:03 PM
eveled's Avatar
Images: 8
[QUOTE=gravelymay;834941]Hi
Short answer is NO
/QUOTE]
The 400 series engines will work on a walkbehind but not on an 800 or8000 series. Those engines are worth something as they are getting harder to find and there is no replacement. There are lots of engines that will fit an 800. Ed
Here's to our veterans past present and future
Machine of The Month link
eveled is offline
post #5 of 20 Old 10-02-2009, 08:41 PM Thread Starter
Thanks for the information.So the run of the mill engines will fit the 800 series? I have an 816 that needs an engine and I had the good engine in the 430 I thought I might use.
gburnett is offline
post #6 of 20 Old 10-03-2009, 12:52 AM
bluegoose's Avatar
Gravelymay is the resident guru on replacement engines for the 800 tractors and others. He's had great success mounting Honda engines to these machines - he's well-versed in the needed adapter/bushing parts.
bluegoose is offline
post #7 of 20 Old 10-03-2009, 01:34 AM
So you can't just put any K series on a walk-behind? I thought they all had the same shafts?
gm1276 is offline
post #8 of 20 Old 10-03-2009, 01:48 AM
bluegoose's Avatar
The shafts are roughly the same size, but the crankshaft gears are different between the 400 series riders/walk-behinds and the 800 series. The first being a two piece stepped gear and the latter being more a "spider" shaped gear. On the walk-behinds, I believe the adapter plates are the same for most of the common K-series engines. That might include up thru and including the 16HP models, but I'd have to check on that.
post #9 of 20 Old 10-03-2009, 07:39 AM
ex spelling bee champ
Ingersoll444's Avatar
Images: 14
Kohler made many diferent cranks, blocks, and oil pans for the old K's to fit diferent spec's.
Paul B
SUPER Of The Month 10/2011
Ingersoll444 is offline
post #10 of 20 Old 10-03-2009, 07:34 PM
Collector of many tractors
Kbeitz's Avatar
My crank for my 430 is stepped down for a polite bearing..
Kbeitz is online now
post #11 of 20 Old 10-04-2009, 12:42 AM
bluegoose's Avatar
The Tulsa Small Engine Warehouse is a pretty good source for replacement engine information - all the specs for the different K-series engines (and a whole bunch of others) are listed there.
post #12 of 20 Old 10-04-2009, 03:59 AM
eveled's Avatar
Images: 8
mine is too. Ed
eveled is offline
post #13 of 20 Old 11-03-2009, 01:36 AM
gravelymay's Avatar
They are completely different
The walk behind Kohler and the 400 or 4 Speed is a step down shaft 7/8 to 3/4 on 3/4 of the end.
The 8 speed transmissiom takes a 1 1/8 X 3 3/4 to 4. in long
The Rider has a larger counter bore also.
Thanks Bruce g
Name:	DSC08134Briggs  16 Hp with out adapter.JPG
ID:	81222   Click image for larger version
post #14 of 20 Old 11-03-2009, 08:11 AM
Kbeitz's Avatar
I did find a place that sell new engines with step down shaft for the 400's on the net...
post #15 of 20 Old 11-03-2009, 08:13 AM
Gravely bug bit.
Current largest HP engine that will fit the 800/8000/-G transmissions is the B&S Big Block Vanguard 35 HP Then you can go down from there to anything larger than a 10 HP with the right crankshaft size. It isn't hard to make an adapter plate for the 8-speed tranny. You also need to make sure that the adapter will seal the cranksaft to engine area or adapter to crankcase areas.
Fla Don is offline
