gravely governor - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 6 Old 02-04-2009, 04:41 PM Thread Starter
gravely governor
hello all, new to the forum. I have a mid 60s 7.5 convertable that has given good service for a long time. recently I started it up and would only run with the choke pulled out. It would rev high when not under load. the governor has a little fill spout the appears empty. does anyone know what weight oil/fluid is recommended for the governor. thanks
fleter is offline
post #2 of 6 Old 02-04-2009, 10:11 PM
Dan 2N's Avatar
Images: 13
Re: gravely governor
Welcome to the gang, I use #30 in all of my Gravely governors, should be a thumb screw to remove at the bottom of the case body for checking the oil level.
Dan 2N
Dan 2N is offline
post #3 of 6 Old 02-05-2009, 07:43 AM Thread Starter
thanks, we'll fill 'er up.
fleter is offline
post #4 of 6 Old 08-24-2009, 10:38 AM Thread Starter
what is the correct oil level? thanks
fleter is offline
post #5 of 6 Old 08-25-2009, 01:33 AM
bluegoose's Avatar
There should be a removable screw on the side/bottom of your governor unit - slowly fill the governor with 10W-30 until the oil starts to run out of the hole - then tighten things back up. I usually put a couple squirts of oil in the unit every couple of times that I use the tractor. I believe that some later governor units were sealed and supposedly perm. self-lubricated.
bluegoose is online now
post #6 of 6 Old 08-26-2009, 12:20 PM Thread Starter
thanks
fleter is offline
