Gravely C10A question - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 10 Old 10-16-2007, 08:08 AM Thread Starter
Coop's Avatar
Images: 5
I just picked up a C10A walk behind tractor. I have a question about the controls. On the left handle, there is the lever that is labeled Hi-Lo. This tractor also has the hi-lo control on the right side, on the dash. The lever on the right side changes ground speed, the control on the left side does not seem to change ground speed. Does the left side control change the implement speed?
Coop
You can't put a price on your fun, if you do it stops being fun...
Coop is offline
post #2 of 10 Old 10-16-2007, 12:13 PM
Gravely Fan
krislu's Avatar
Smile Re: Gravely C10A question
Yes . - Kris
krislu is offline
post #3 of 10 Old 10-16-2007, 01:42 PM
Dan 2N's Avatar
Images: 13
Whew Re: Gravely C10A question
The C10 and C10A is the first Gravelys to use a Kohler engine, the lever on the handle should change the tractor ground speed and the implement speed, the one on the dash shifts the ground speed only giving the tractor a total of four speeds in both directions,and called 8 speed.
Dan 2N
Dan 2N is offline
post #4 of 10 Old 10-16-2007, 05:42 PM
munderhill's Avatar
Images: 7
Dan 2N
Ditto, identical to my old 5660. The handles on the dash, left is pto and right is drive range.
MU
munderhill is offline
post #5 of 10 Old 10-16-2007, 05:57 PM
10,000 +posts!
That handy dash lever (2 speed axle) replaced the "Gear Reduction Wheels" which took a bit of time to install/uninstall. They made a true "beast" out of a mild mannered "L" though!
HydroHarold is offline
post #6 of 10 Old 10-16-2007, 11:45 PM
Andy R's Avatar
I'm not familiar with C10, but if the tranny is the Swiftmatic, then yes, the one lever is for speed range only, but the other should control the speed of both the PTO and the tractor, because even with the PTO disengaged, you have to have it on one position or the other (I know - the tractor will move if it is left in neutral - but not uphill!)
Anyway, both my tractors - the 430 and the L8 have the swiftmatic and the gear lever that controls PTO speed also changes tractor speed - to a smaller degree than the range lever, but it is noticeable.
That change in PTO speed is one of my favorite things with the Gravelys - in the low gear, PTO is moving slower, but NOTHING seems to bog it down in that range...
Andy R is offline
post #7 of 10 Old 10-17-2007, 06:47 AM Thread Starter
Coop's Avatar
Images: 5
Thanks for the replies guys. I had a chance to use the tractor last night after work, I mowed down some tall grass, got used to the controls, awsome machine, I'm going to like this machine...
Coop
Coop is offline
post #8 of 10 Old 10-17-2007, 07:29 AM
Gravely Fan
krislu's Avatar
Coop- When mowing tall grass put the axle in low and the pto lever in hi.
- Kris
krislu is offline
post #9 of 10 Old 10-17-2007, 12:37 PM Thread Starter
Coop's Avatar
Images: 5
Kris...That's what I did, worked graet..
Coop
Coop is offline
post #10 of 10 Old 10-17-2007, 02:32 PM
Andy R's Avatar
Putting the PTO in high makes it spin faster, but if you do start to bog down, put it in low - it will hold it's speed through even heavier stuff.
Also, if you're clearing brush, it tends not to throw stuff quite as far or as rapidly, so it's a bit safer.
Andy R is offline
