Snowblower For Gravely Servicing??? - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 7 Old 09-15-2012, 11:41 PM Thread Starter
Question Snowblower For Gravely Servicing???
I just picked up an MA210 snowblower for a Model L Super Convertible Gravely walk behind that has only been used to plow. I was told it was stored in a barn and has some grass and a little gravel in the impeller but I got most of it out. It spins by hand but it does take quite a bit of force. The auger has been adjusted as it was touching the housing and not moving now that too moves with some force with my foot.
I covered a lot of the moving parts with oil but I couldn't find any grease nipples. I want to service it properly. I was wondering how I could change the oil? As well as any other ways to service it to make sure its running properly for winter. Thanks!
jboyd12 is offline
post #2 of 7 Old 09-16-2012, 07:15 AM
Gravely Model L Guy
Gravely Model L Guy's Avatar
Re: Snowblower For Gravely Servicing???
There are no grease fittings on your model of MA210. You can change the oil in the gear box though. Remove the bottom plug and tip up the snow blower to drain the oil. Then refill through the top plug with 90W.
1951 Gravely Model L.
1964 L-8-currently under restoration.
1953 Model L with ring gear Ford type starter
1957 lI pull start
1957 li elec start
1961 L
1963 L-I
1970 Commercial 12
1963 L-I super convertible.
1987 Ford LGT14D
1960 bunton mower
1926 Ford Model T Tudoor sedan.
1985 Troy-Built Horse
1979 Troy-Built Horse
1950's Airens Trans a Matic
1972 MG MGB roadster
1997 ford f-450 5 spd 7.3 turbo
check out my youtube channel: http://www.youtube.com/user/64gravely?feature=mhee
Gravely Model L Guy is offline
post #3 of 7 Old 09-16-2012, 09:19 AM
I Love All Color Tractors
DJ in WV's Avatar
Images: 6
Welcome to the forum and congratulations on grabbing a blower. It looks very good.
The only thing that I can add is lubing the splines on the drive shaft and in the coupler behind the auger gear box. Mine shows some wear after never being lubed.
My YouTube Page
The Shops of Oak Point Farm
My Equipment:
1961 Gravely LI Postal
1967 Gravely 430
1970 Gravely C10A
1971 Gravely 430
1972 Gravely 816
1973 Gravely Model C8
Many other Gravely C's, L's, and LI's
1982 Gravely 8123
1983 Troy Bilt Junior
1988 Gravely Pro 12
DJ in WV is offline
post #4 of 7 Old 09-16-2012, 10:58 AM
Richard-tx's Avatar
Images: 7
I would use GL4 gear oil, not GL5.
Code:
                              Current Inventory
                              8183T (Onan B48)
Richard-tx is online now
post #5 of 7 Old 09-17-2012, 12:39 PM
One other thing to check is the large nut that is holding the slip clutch on the blower. That nut actually adjusts bearing play in the auger shaft. If you tighten that really hard you're just pressing those tapered roller bearings tighter together and eventually they stop moving... ask me how I know! It should be snug but not to the point where it stops moving.
You should remove that slip clutch anyway and service that as well. That will give you a chance to see the condition of the roller bearing underneath it. Ask us if non of this makes sense and we'll walk you through it.
Nate
tinsley207 is offline
post #6 of 7 Old 09-20-2012, 04:37 PM Thread Starter
Thank you everyone for the great tips and info! I do have one concern if i spin the clutch it turns the impeller and the auger, but i can hold the auger while someone else spins the clutch it wont mover.. also if i just spin the auger it will not turn the impeller.. is there a problem with the gear??
thanks for the Help guys!
jboyd12 is offline
post #7 of 7 Old 09-20-2012, 09:42 PM
DJ in WV's Avatar
Images: 6
It could be a problem with the gearbox, but I would say that it's much more likely that the reel clutch is worn out or need tightened up.
If you don't have it already, the manuals for this and lots and lots of other Gravely goodies are available for free download over at http://www.oldgravelys.net. The clutch adjustment is outlined in the manual rather well. I'd start there.
My YouTube Page
My Equipment:
1967 Gravely 430
1970 Gravely C10A
1971 Gravely 430
1972 Gravely 816
1982 Gravely 8123
1988 Gravely Pro 12
DJ in WV is offline
