Dual wheel spacers?? - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 6 Old 07-20-2012, 07:46 AM Thread Starter
jrd
http://www.ebay.com/itm/GRAVELY-DUAL...item2a2073b59e
Never seen ones that look like those. But they appear to be the right color. Were these yet another obcure gravely attachment?
'41 L (not running)
'43 L
'44 L
'50 L
'52 L (not running)
'58 LI (not running)
'59 LI
'61 LS
'61 LS
Mutt LS
'62 LI (not running)
'63 L8
'66 L8
'66 C8
'67 C8
'74 Comm 12
'75 C8
'73 812
'74 816
UFT Mountaineer 88E
3 parts/project tractors
Too many attachments
jrd is offline
post #2 of 6 Old 07-20-2012, 08:02 AM
Old Iron Connoisseur
Jimmy in NC's Avatar
Re: Dual wheel spacers??
I've never seen a set like that before and will venture a guess as third party attachment. See no reason they wouldn't work fine. They may be easier to install than the factory ones actually.
WANTED:
Time to finish all my tractor projects!
My name is Jimmy and I have G.A.S.
Click for an explanation if you need it....
Gravely 816s, 8182-T (Going back to 8183-T soon!), 526, Lots of "L"
Round Fender John Deere 110
Jimmy in NC is offline
post #3 of 6 Old 07-20-2012, 11:36 AM
I used to work at a Golf Course, and that type of Dual Wheel Adapter was used on Jacobson Equipment. I had modified the Hubs on a LI that I had and used a set on it for quite a while. But not as easy to install and change over as the Gravely Dual Adapters.
jskiba1 is offline
post #4 of 6 Old 07-20-2012, 04:20 PM
Richard-tx's Avatar
Images: 7
I agree based on the pictures. It would be a pain to install. Deflate the tires completely, remove all the bolts and studs, and then it goes downhill from there.
Code:
                              Current Inventory
                              8183T (Onan B48)
Richard-tx is online now
post #5 of 6 Old 07-20-2012, 04:32 PM
Looking closer, it looks like all of the mount bolt holes have broken bolts in them. I may be wrong as the pictures have a bit to be desired. I'm not 100% sure how they work looking at them either. There is no recess for the three bolts that hold the rim together, just 3 holes for the mount bolts. The spacer wouldn't pull up tight to the hub, it would always be held off some.
WANTED:
post #6 of 6 Old 07-20-2012, 06:14 PM
Gravely 408 Authority
jepics's Avatar
Images: 12
I've seen those on Jacobsen lawn tractors (4 wheel) for dual rear wheels. I'd say not a Gravely item.
John D
If you want to do what you want to do, you have to do what you have to do.
1945,1946 Cletrac AG-6 Crawler Tractors
1952 Ford 8N Sherman backhoe;Wagner FEL
1966 Gravely Commercial 10
1969 Gravely Commercial 10A
Gravely 408's:
. 1970 "First Series" w/ 34" Mower;
. 1972 "All White" w/ 34" Mower; snow plow
. 1973 w/ 34" Mower; parts tractor
. 1974 w/ 34" Mower
. 1974 w/ 34" Mower; extended hitch
. 1977 w/ 34" Mower; rear weight box
1978 Gravely 8162-T
1984 Gravely 8122
1994 Gravely 18-G
jepics is offline
