L8 Reassembly Problem - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 26 Old 04-06-2012, 03:11 PM Thread Starter
CTPhil's Avatar
I finally got my 1965 L8 to the assembly phase, but it's been apart so many years my memory fails me. My problem is the fan shroud, more specifically the two 1/2 inch studs where it attaches to the crankcase. What seems correct is to put the shroud on, then the accessories (governor, electric starter plate), then the rear hitch straps. My problem is that when I adjust the handles all the way up, the shroud is forced against the exhaust manifold, and I'm not at all happy about that.
Is my order correct? It was OK before I took it apart obviously, maybe the handlebars weren't all of the way up? If my order is correct, should I just grind a crescent shaped relief in the shroud?
Thanks.
Gravelys: 1951 L, 1952 L, 1954 L, 1956 LI, 1961 LI-SR, 1962 L, 1962 LI, 1963 LI, 1965 L8, 1965 LS, C 10, 524, 5460, 8102.
I can quit any time I want. I just don't want to right now.
The rest: 1969 WH Raider 12, 1983 WH A-111, 1985 WH 314A, AC 917H, 1978 Ford 2600, 1978 Ford 4100, 1975 Ford 3550 Industrial, 1959 Farmall 560, 1949 Case VAC, 1951 Case VAC Eagle Hitch, Troy Bilt Horse, Troy Bilt Pony. Mowers, rakes, balers, and far too much other old junk to list....
CTPhil is offline
post #2 of 26 Old 04-06-2012, 03:48 PM
Old Iron Connoisseur
Jimmy in NC's Avatar
Re: L8 Reassembly Problem
Maybe that helps? It's of my L.
WANTED:
Time to finish all my tractor projects!
My name is Jimmy and I have G.A.S.
Click for an explanation if you need it....
Gravely 816s, 8182-T (Going back to 8183-T soon!), 526, Lots of "L"
Round Fender John Deere 110
Jimmy in NC is offline
post #3 of 26 Old 04-06-2012, 04:44 PM Thread Starter
CTPhil's Avatar
That does help. That's what I was thinking, but the hitting on the manifold baffles me. I'll probably end up grinding in some relief. Is this perhaps a known issue?
CTPhil is offline
post #4 of 26 Old 04-06-2012, 07:36 PM
tracktortag's Avatar
Phil, I would'nt do any grinding yet. There has to be a reason why things did'nt go back together as they should. Not that I would know why, since I have'nt touched my '66 L8 since I picked it up last year. I WILL be following along though, for my own FYI.
tracktortag is offline
post #5 of 26 Old 04-06-2012, 07:49 PM
wjohn's Avatar
Same here.
Take a picture of your shroud/exhaust manifold interference and maybe one of us will have an idea.
'72 John Deere 110, '39 and '40 Allis Chalmers Bs, '41 WC, '56 WD-45, '80 Gravely 8102, '63 L8, '52 L, '63 LI, '73 CI, '68 C10A, '57 LI, '58 LI, '69 C8, '58? Wisconsin LI, '73 816, '72 816, '40 L SN 2958, '71 450, '70 432, '48 L, '51 LI, '66 C10, '79 5240, '81 UFT Mountaineer 120E
Looking for: Gravely LS/CS, various '40 L parts
wjohn is offline
post #6 of 26 Old 04-06-2012, 08:05 PM Thread Starter
CTPhil's Avatar
There doesn't seem to be anything to screw up. The bottom goes on the studs and the top position is determined by the handlebars. Unless there are washers that go on the studs first, but nothing like that shows on the parts list.
CTPhil is offline
post #7 of 26 Old 04-06-2012, 08:19 PM
I Love All Color Tractors
DJ in WV's Avatar
Images: 6
Correct me if I'm wrong, but aren't the studs off center in the brackets that mount to the lower engine block? If so, the brackets are quite possibly mounted upside down.
My YouTube Page
The Shops of Oak Point Farm
My Equipment:
1961 Gravely LI Postal
1967 Gravely 430
1970 Gravely C10A
1971 Gravely 430
1972 Gravely 816
1973 Gravely Model C8
Many other Gravely C's, L's, and LI's
1982 Gravely 8123
1983 Troy Bilt Junior
1988 Gravely Pro 12
DJ in WV is offline
post #8 of 26 Old 04-06-2012, 08:32 PM
Wow DJ,
I have noticed a slight offset side-to-side, but never measured them from the end tips to the centerline of the studs. I'll check some tomorrow.
Roger,
beaner2u is online now
post #9 of 26 Old 04-06-2012, 08:50 PM Thread Starter
CTPhil's Avatar
They look centered to me but I too will check tomorrow. However, I never took the brackets off the crankcase.
CTPhil is offline
post #10 of 26 Old 04-06-2012, 08:51 PM
DJ in WV's Avatar
Images: 6
I'm just going off of memory and could very well be wrong. I really can't think of anything else that could be the problem though.
My YouTube Page
My Equipment:
1967 Gravely 430
1970 Gravely C10A
1971 Gravely 430
1972 Gravely 816
1982 Gravely 8123
1988 Gravely Pro 12
DJ in WV is offline
post #11 of 26 Old 04-06-2012, 10:10 PM
Gravelyyard.com
arcam8123's Avatar
I just checked. The one I have on the parts shelf seems to be equal distance from the center of the bolt to the holes. If there is any offset, it's only about a 1/16". They are offset from side to side.
Ron C
www.gravelyyard.com
www.gravelytractorclub.org
My Equipment: You're kidding, right? Not enough bandwidth on the planet.
arcam8123 is offline
post #12 of 26 Old 04-06-2012, 10:47 PM
DJ in WV's Avatar
Images: 6
Well that confirms it, I'm wrong. I had to have been thinking about the side to side offset instead. Thanks for checking Ron.
I can't think of anything else that would be causing things to not line up.
My YouTube Page
My Equipment:
1967 Gravely 430
1970 Gravely C10A
1971 Gravely 430
1972 Gravely 816
1982 Gravely 8123
1988 Gravely Pro 12
DJ in WV is offline
post #13 of 26 Old 04-07-2012, 03:56 AM
Phil,
Can you take a picture of the exhaust side and your fitting problem?
Roger,
post #14 of 26 Old 04-07-2012, 08:32 AM Thread Starter
CTPhil's Avatar
Originally Posted by beaner2u View Post
Phil,
Roger,
Yes, will do, but right now it's together wrong, with the hitch straps on first. That way there's about 1/8 inch clearance to the manifold. I realized after I'd redone it that I wouldn't be able to attach the governor or starter plate that way.
CTPhil is offline
post #15 of 26 Old 04-07-2012, 01:12 PM Thread Starter
CTPhil's Avatar
Well here's a pic for what it's worth. With the straps on first as in the photo (wrong) there is a gap between the shroud and manifold, with the shroud on first, it presses against the manifold.
CTPhil is offline
